Akai 1150 keeps blowing 5 amp fuses
4 Suggested Answers
Grubhead
  • 5391 Answers
SOURCE: My amp has lost sound in one channel.I need a circuit diagram.
No you don't really. The good channel will tell you everything about the bad channel as it should be the same. For instance you can measure voltages and compare them and if you prod the good channel and get a loud buzz at various stages. Then you should also get the same results with the bad one. Work backwords from the speaker terminals. Buzz on good Buzz on bad section is working. Buzz on good nothing on bad. Faulty stage. It's not likely to be the power supply as that would affect the other channel.
Posted on Apr 05, 2009
  • 211 Answers
SOURCE: the two 5 amp fuse inside the amplifier keeps blowing
That must be the inrush current.
Maybe you are using the wrong fuses.
Please check if those are fast or slow types.
You need slow types.
Good luck,
Gerard
Posted on Jan 17, 2010
AJIN G
  • 6694 Answers
SOURCE: Akai AM-U1 blows fuses 1 & 2, 2.5A, transformer to
hi,
If you are from USA then You have to use F1 and F2 3.5A/125V fuse instead of 2.5A.
and F3 and F4 3A/250V. This will solve the problem of blowing fuse when cold start.
If you you can give your email address then i will sent you the Service manual.
OK
Posted on Sep 22, 2011
What size fuse would I want on my cd receiver head ? I was blew them and thought it was 5 amp but they keep blowing after I put in 5 amp fuses ..would it hurt to try 15 amp?????
I would say that if you are blowing a 5 amp fuse and are not pushing the system hard, then you have an issue. You could try a larger fuse, but make sure you look for hot spots and smoke. I would bet you either have a shorted wire or will need to replace the unit.
Aug 12, 2015 | Cars & Trucks
How can i get a replacement 5 amp 125 volt fuse for a holmes twin widow fan
It's worth noting here that it's more about the physical size & shape of the Fuse thats needed to fit your Fan.
You don't have to use exactly a 5 amp @ 125v fuse.
Any fuse that Fits and is in the range of 5,6,7,8,10 Amp and even 230v is ok.
The fuse is like a piece of soft metal that will melt if too much current is being drawn by the device. The Amps & Volts only define approximately when the fuse link will melt (blow). But as the fan gets dirty and older the LOAD it draws might get slightly higher. Enough to cause the fuse to slowly melt. So a small to 6, 8, or 10 Amp should work just fine. A wiring short will still cause the 10 Amp fuse to blow thereby keeping things safe. The manufacturer uses a fuse that fits in the space he has allocated & allows the unit to run continuously without blowing on a slight load.
But it is only a safety device to protect the device from internal shorts.
It stops a shorted motor or shorted internal wiring from getting too hot and possibly causing a fire.
But a 20 or 30Amp fuse would still blow if it is shorted.
For example...If the 5 A fuse keeps blowing then you could try say an 8 or 10 Amp fuse. If that blows then their is definitely a problem with the circuit. Don't put anything larger than 10 Amp in.
It then needs to be looked at by a service technician.
The voltage rating on a household fuse isn't that critical.
It's actually the wattage it takes to melt the fuse link. It's based on the mathematics of Ohms Law (Watts =Volts x Amps)
But thats another story....
Cheers
Trevor
Jul 16, 2014 | Holmes Products Dryers
Sony receiver keeps blowing 5 amp fuses
You have shorted output transistors in the amp that need to be replaced.
Feb 14, 2013 | Sony STR-DE425 Receiver
My kenwood reciever kr-a4070 keeps blowing a fuse
have you tried a different outlet? something my be wrong internally
Jul 31, 2012 | Kenwood Audio Players & Recorders
All the lights work except the dash lights. The 5 amp fuses keep blowing and if I put a 15 amp it doesnt blow but no dash lights
DASH HAS A SHORT CIRCUIT.DASH NEED REPLACING BUT CHECK FOR SHORTS IN THE WIRES TO DASH.DONT PUT A LARGER AMP FUSE IN A CIRCUIT TO KEEP FROM BLOWING FUSE BECAUSE IF FUSE DONT BLOW WIRES GET HOT IN THE CIRCUIT THAT HAS A SHORT IN IT AND CAUSE A CAR FIRE.
Nov 04, 2010 | 1992 Ford Thunderbird
The two 5 amp fuse inside the amplifier keeps blowing
Good luck,
Gerard
Jan 17, 2010 | Audio Players & Recorders
Im having trouble i keep blowing fuses on my amp?
you have you gain and freq knobs turned up too far, try turning them down and turn down subb level from deck
Apr 13, 2009 | Rockford Fosgate P3001 Car Audio Amplifier
My sd-533hd5 keeps blowing the 5 amp 125v fuses
Yes! it sounds like a power supply problem! or the flyback in the main board needs replaced ( part is in the $70.00 range
Dec 12, 2008 | Pioneer SD-533HD5 53" Rear Projection HDTV
3amp fuse keeps burning out
when a fuse blows, its telling you that theres a fault. this could be a loose or broken wire.
or alternatively, the fuse rating is too low. you could check the wires are tight. and also possibly try fitting a 5 amp fuse. check first that the fuse is rated correctly for the appliance. usually 3-5 or 13 Amps.
Mike @ compurepair.
Nov 17, 2008 | Goodman GMS90703BXA Heater
 Grubhead
Grubhead
