Question about Wacom Bamboo Create Pen Tablet CTH670
"Supported Tablet Not Found"
Everytime I plug in my tablet and use the pen, the cursor lags. When I click the Wacom Preferences, it says, "Error: Supported Tablet not Found". Touch works but the pen causes the cursor to lag. I use Windows 7 and i have updated to the current driver.
SOURCE: My tablet pen occasionally stops responding.
what you need to do is go into cmd prompt and type this: /configtab (you need to type it correctly, sometimes you may need all caps or no caps, it depends your software). get the 7 digit code that appears next to "confm" and go to your tablet settings and enter it into the confirmation input. and you are set to go!
Posted on Apr 19, 2009
  • 22 Answers
SOURCE: ERROR message "A Supported Tablet was not found on the system"
I have encountered this message a few times, usually if I have tried to plug'n'play the tablet. A restart with the tablet connected usually fixes it for me, but I would suggest removing the driver and software and reinstalling them, making sure you have the most up-to-date version- freely available from wacom.co.uk (though I note you have the latest versions so just reinstall those).
I think, however, your problem might be something to do with the following note from wacom:771c281.png Do you know if you are running a 64-bit setup? There may be a workaround even if you are, so do let us know.
Posted on Oct 29, 2009
SOURCE: My Wacom Bamboo Pen and Touch tablet isn't picking
That happens to mine too! I might contact wacom, because i spent £100 on this!
Posted on May 09, 2010
SOURCE: Wacom tablet pen right click always active.
I'm having this same problem with my original Graphire (ET), with a replacement pen that's less than two years old.
I don't think it's a driver issue, based on the indicator light on the tablet itself. It turns green like it's detecting a click when either end of the pen is brought near the tablet. To me, that suggests an issue with the pen hardware. The mouse has no such problem.
I'd be very interested if anyone has a solution to this.
Posted on Jan 08, 2011
SOURCE: I own a Wacom Tablet.
http://www.wacom.com/en/CustomerCare/Drivers.aspx
get the drivers from the above site
hope this helps :-)
Posted on May 04, 2011
Why won't my wacom grip pen click when it touches the tablet instead of hovering and selecting text?
Have you tried pulling the nib out (the end bit you draw with)? It could be that something is sticking the nib further inside the pen than it should, which is telling the pen you are applying pressure. As far as I know there is a little spring inside the pen that the nib pushes on when you touch the pen to the tablet. Perhaps the spring is permanently squished in.
May 26, 2014 | Wacom Intuos3 Grip Pen
My Wacom Tablet won't recognize the pen.
you have to install the pen on the CD you have from the box you got it in
Apr 21, 2010 | Wacom Intuos3 Graphic Tablet
Wacom Bamboo Fun Tablet-Mac. Yellow box pops up under pen cursor.
Your tablet is set under the handwriting setting. Go to system preferences and select ink under hardware. Then turn off handwriting recognition.
Jan 20, 2010 | Wacom Bamboo Fun 5.8" x 3.7" USB Tablet...
My pen tablet is on and running, when I bring the pen across the tablet it moves the cursor on the screen, but in my art program, it isn't painting - but if I click with my mouse, that will paint.
You may need to set it up in preferences in the programme (without knowing which programme you're using). It will work if you remove the mouse.
Aug 31, 2009 | Wacom Computers & Internet
How do you put the pen in "Mouse mode" on a Genius?
Please follow those steps:
  • Select "Preferences" under the "Options" menu .
  • Under the Digitizer Input section select for input "Digitizer only" and click OK
  • Now configure the menu and screen area and save configuration
  • Select "Preferences" under the "Options" menu and set in the digitizer input section input back to "Digitizer/Mouse"
Jul 24, 2009 | Wacom Bamboo Fun 8.5" x 5.3" USB Tablet...
Wacom tablet clicking noise!!!!!
ok... so i've just been fiddling around with my wacom settings... and i noticed that while i didn't see any sound options when i go to the wacom tablet settings through the windows control panel, i do have them in the pen office program... i had the sound box ticked, so i just unticked it...
Feb 09, 2009 | Wacom Graphire 4 "Silver" 4x5 (WMM132369)
Initial Delay of tablet pen
I had a similar problem with Vista which made the pen/cursor freeze just as the tip was placed on the tablet face.
The problem turned out to be a Vista setting.
I went to Start > Control Panel > Pen and Input Devices.
Then in the Pen Options tab highlight the "Press and Hold" pen action and then press the "Settings..." button. In the dialog box that opens uncheck the "Enable press and hold for right-clicking" check box. Hit "OK".
Worked for me.
Feb 02, 2008 | Wacom Intuos3 Graphic Tablet
Wacom tablet stopped working, blue light on.
Hey I had this problem too with my Bamboo too, I'm not sure if it was anything I changed or whatever but either way the blue light was on but it wasn't registering the pen.
I found a way just minutes ago to fix it however!
Go into 'start', 'all programs', then look for 'pen tablet'. Hopefully you should have this. If not then download the latest driver for your tablet from the wacom website and that should install it.
Next choose 'pen tablet preference file utilty'. Then under 'my preferences' choose to remove. Bingo! All was well in the world again.
This worked for me so hopefully it will for some of you guys too! Good luck!
Jan 15, 2008 | Wacom (PTZ930AC) Graphic Tablet
Wacom Bamboo Create Pen Tablet CTH670 Logo
57 people viewed this question
Top Wacom Computers & Internet Experts
toddmat
Level 1 Expert
jasbo
jasbo
William F. Bryant Jr
Level 1 Expert
Are you a Wacom Computer and Internet Expert? Answer questions, earn points and help others
