Question about Nokia Cell Phone Headset N65 Universal Headset
Reset bluetooth headset n65 - Nokia Cell Phone Headset N65 Universal Headset
2 Suggested Answers
SOURCE: i have lost my n65's
Hi,Friends
I Am PRADIP BAMANIYA
N65 bluetooth password is 0000.
Posted on Oct 21, 2011
Lost my pin for my Bluetooth headset. How do I reset it.
In this HX550 Reset to factory default You will find the information you need to reset your device. Hope that helps.
Regards,
Maya
Motorola Support
Oct 12, 2016 | Motorola Mobility H550 - Bluetooth Headset...
How do I reset my samsung hm1500 bluetooth headset
Please anyone who has samsung bhm1500 bluetooth headset manual,upload it to a file sharing server.
Thanks
Aug 01, 2012 | Samsung HM1500 Bluetooth Headset
I have lost my n65's bluetooth passcode. how can i reset it?
Hi,Friends
Mar 12, 2011 | Nokia Cell Phone Headset N65 Universal...
My blackberry curve recognizes the LG HBM-570 headset, but the headset keeps telling me it is terminating. It has worked for 3 months and just started doing this.
Hi, to solve this problem, you will have to do some troubleshooting.
First you will need to disconnect the pairing of both the blue tooth headset from your black berry phone.And pair again with the below instruction.
Instructions
Pair Your Blackberry with a Bluetooth Headset
Turn on Bluetooth headset and Blackberry hand-held.
Enable the Bluetooth radio by going to the options window and clicking on Bluetooth. Click on Enable Bluetooth in that window.
Add your Bluetooth headset to your Blackberry by clicking on Add Device in the Bluetooth window.
Find and select the name of your Bluetooth headset from the list that appears. The Blackberry will search for all Bluetooth devices within range, so other devices might show up on the list.
Click Activate Bluetooth device if you receive a call and the Bluetooth headset does not pick up automatically.
Use your Bluetooth Headset with your Blackberry
Make sure the Bluetooth radio on your Blackberry is turned on before you try to use your Bluetooth headset.
Use the voice-dial feature to call contacts if your headset has that capability. Not all headsets support voice dialing, but more of the newer models do.
Press the on/off button on your headset to end a call or use the end button on the handheld.
Tips & Warnings
Pair your Blackberry with any Bluetooth-enabled device using the same steps as those for connecting a Bluetooth headset.
Remove your Bluetooth headset from the list of paired devices on your Blackberry by selecting and clicking on Delete Device in the Bluetooth window.
Configure your Blackberry to connect to a paired Bluetooth headset without asking for authorization in the Bluetooth Device Properties window. That will allow your headset to automatically reconnect even if you take it out of range temporarily.
Only configure a Bluetooth headset to your Blackberry once. Once you configure the pairing between the two devices, the settings are saved and you do not have to repeat the processes each time you use it.
Turn off the Bluetooth radio on your Blackberry when not in use for security reasons.
Adjust volume on your headset or hand-held to a comfortable level. Excess volume from in-the-ear headsets can cause hearing damage.
After that if still does not work that means you will need to test if the bllue tooth headset is really not damaged by using it on another phone to confirm.
You can also reset the blackberry cell phone if still not working. Blue tooth might be corrupted and will not connect to headset. You can use the below instruction to reset cell phone:
How to Reset a Blackberry
There are three main types of Reset that apply to the Blackberry. These are listed in order below. Instructions for Blackberry Pearl are slightly different - see bottom section of the Tip.
1) Soft Reset - simply press the ALT+RIGHT SHIFT(CAP)+DELETE keys.
This reset stops all applications that are running on the Blackberry and will help if you are having problems connecting the device to computer. This reset will not erase any information from your device.
2) Double Soft Reset - this reset is almost equivalent to a full hard reset. First perform a Soft Reset as outlined in Step 1.
As soon as the screen is no longer black - repeat the steps once again exactly as before.
This takes you to another screen showing an hour glass. Allow the device to reset. This helps if the device has suffered a more serious error. Be aware you may loose some information from your device. A backup is advised prior to proceeding if at all possible.
3) Hard Reset - this is the full blown reset and will fully reset the device to help resolve critical errors with software or hardware. Again back up important information before proceeding if possible.
Note: For RIM models 850, 857, 950, or 957, you must insert the end of a paperclip or similar blunt object into a small recessed hole on the back of the unit and depress the switch inside. The device will reboot and be hard reset.
Other Models: With the device turned on - remove the battery for 30 seconds or more. Now replace the battery. The device will reboot and be hard reset.
Blackberry Pearl: To reset to factory defaults enter 'Options' from the main menu. Scroll to Security Options and press the trackball. Choose 'General Settings'.
Press the left soft key, then scroll to "Wipe Handheld" with the trackball and press the trackball. To initiate the factory reset, your phones security code may be required in order for the process to complete. Your phone will now be restored to its original settings on leaving the factory.
A hard reset can be achieved with the Pearl in the same way as outlined at Step 3 by removing the battery.
Be aware that resets such as these may erase data, such as contacts, ring tones, pictures, text messages and stored Internet files and emails. Make sure to back up important information beforehand if at all possible. You can obtain software to back up the device to your computer directly from Blackberry Below.
software112.com/products/blackberry-desktop-software.html
When you are through with that and still nothing happens, then you blue tooth headset needs replacement..
Hope this Tip helps. If so please do leave a vote for the solution.
Thanks.
Feb 18, 2011 | LG HBM-760 Bluetooth Headset
Bh-105 bluetooth headset not pairing with win7 operating system..pls help
U must RESET the Headset.
Switch OFF the Headset.
HOLD the answer/end key + power key (for about 5 second).
Red + Green indicators lights start to alternate.
Then Ur Headset is RESET.
Connect / Pair it as normal.
Nov 06, 2010 | Nokia Bluetooth Headset BH105
I need a manual for the bluedio N65 headset so I can synch it to my phone!! I followed generic instructions and it doesnt seem to work!
Hold down the mulitifunction switch for at least 2 seconds and the sync will start. Make sure you activate the bluetooth function on your phone.
Sep 11, 2010 | Cell Phones
How do I reset my bluetooth headset to sinc to another device instead (and can it link to an Ipod touch)
Just turning the device off then back on is the only type of reset there is.
To be able to pair your headset with two Bluetooth devices the headset must have Multipoint technology. The Explorer 330 does not have this technology. Also for use with devices like the iPod touch the Bluetooth headset must have A2DP technology for streaming music. Unfortunately the Explorer 330 is an older model of headset and does not have the A2DP technology.
Below is a link to newer Bluetooth headsets if you would like to upgrade.
New Bluetooth Headsets
Good luck from Headsets Direct!
Apr 09, 2010 | Plantronics Explorer 330 Headset
How to reset a bluetooth
If you're resetting it one you're phone just delete the device in your bluetooth setting and set it up again. If trying to reset the bluetooth headset, hold the power button until the blue light stays on. That should do the trick.
Mar 16, 2009 | Motorola Mobility H350 Wireless Headset
Bluetooth connection
First I would need to know the model Bluetooth you have so I could tell you what to do to reset the headset. You can always reset a bluetooth headset to repair it to another device. Normally though to reset a bluetooth headset, you would have to power the Bluetooth device off and then press and hold the device to get it in pairing mode. Usually when in pairing mode the device's light usually stays lit a solid color such as red or purple, or it flashes two different colors simultaneously. At that point you can get your device to find the headset (make sure that you device is bluetooth capable, is on, and is visible to devices) and then pair it. There is always a passcode or pin associated with the headset which creates a secure connection between your device and your bluetooth headset. The default pin code is 0000. Hope you get it working, if it doesn't shoot me a message with the make and model of the bluetooth headset and I can walk you through it.
Dec 17, 2008 | Cell Phones
Nokia Cell Phone Headset N65 Universal Headset Logo
57 people viewed this question
Top Nokia Radio Communications Experts
shaun taylor
Computer Repairing
Computer Repairing
Are you a Nokia Radio Communication Expert? Answer questions, earn points and help others
