Question about Motorola TalkAbout T5000 2-Way Radio
What is the AC adapter specs on the charger for the T5000
    Problem Solver:
  • 14 Answers
No polarity. The adaptor puts out AC , low voltage. Just traced the schematic and found out.
Posted on May 17, 2014
  • Ravi Jagtiani
    Ravi Jagtiani May 17, 2014
    If u use DC just one of the cradles will work
2 Suggested Answers
vrc_tech
  • 109 Answers
SOURCE: motorola t5000 charger polarity
The Polarity of Motorola's equipment is always Center Positive.
Pat
Posted on Aug 21, 2008
I broke my ac adapter for my acer I don't know what kind of acer it is or what year it was made but I need to know how to charge it whithought a ac adapter
You can't charge it without a proper cord/charger of the same spec. The model should be on the bottom of the laptop with the power specs. You can buy one online with the Make (Acer), model fo the laptop.
Nov 22, 2012 | Computers & Internet
Voltage specs for ch 600 Motorola talk about charger
Hi Patti,
Best I could do is suggest you take your radio to your nearest Radioshack or similar store and I'm sure they will assist you.
I hope this is helpful to you.
Cheers,
Peter
Sep 14, 2012 | Motorola Mobility T4800 T5000 T5500 T6500...
DV4 won't charge
Maybe it's the charger or dc jack that was broken. Just test with a known working adapter connected, see if it charges, if yes, then your charger is broken, while if not, then you have to resoldered your dc power jack.
Specs of HP DV4 AC Adapter:Output: DC18.5V 3.5A
DC Connecter (Barrel) size:
Internal Diameter: 5.0mm
External Diameter: 7.4mm
With central smart-pin inside
Dec 26, 2011 | Computers & Internet
Replacing the OEM 18.5 V 3.5 A ac adapter with an 19V 4.74 A adapter for my c551nr compaq, should not give me problems, will it? It should be within spec, hopefully.
Specification of Compaq Presario C551NR AC Adapter:
Power: 65W
DC Connecter (Barrel) :
Internal Diameter: 1.7mm
External Diameter: 4.8mm
But it's OK to use a 90w 19V 4.74A adapter on your laptop only if the connector tip fits your laptop.
Thefollowing three conditions should be met for you to use an ac adpater safely. 1)Output Voltage is within +/- 5% of your old charger's output.
For example, ifyour old charger provides 19.5V, then you can use a charger that provides 20.5Vor 18.5V.
2) Output Current is the same or higher than that of your old charger.
For example, ifyour original adapter provides 3.42 Amps, then you can use a charger thatprovides 3.42 Amps, 3.9 Amps or higher.
3) Connector tip must fit securely into your laptop.
Mar 29, 2011 | Compaq Presario C551NR Laptop Charger...
My dell inspirion ac charger will keep computer running but will not charge my battery. A pop up will inform me that the system doesnt recognize the charger.
it could be a couple things: Are you using the standard 90 Watt ac adapter, or the Travel auto/Air adapter. The travel adapter is only 65 watts can will charge the battery
If using the standard ac adapter, see if you can try another Dell D series adapter and see if you get the same error.
If same with another adapter, the issue is the charging circuit. If another adapter works, then replace the adapter.
If the charging circuit is bad, it will be the chargerboard or if intergrated, the motherboard
Sep 25, 2010 | Dell Inspiron 1545 Notebook
Can I use ther Targus Adaptor for Inspiron 1525
On the long term, a power adapter with a bigger amperage can damage battery and battery charger.
Better to get an adapter with same specs as the 65/70W one , or an original replacemant:
Dell Inspiron 1525 New AC Power Adapter Supply $14.29 - Buy.com Dell Inspiron 1525 65 Watt Original AC Adapter $25.00 - parts4nb.com Dell Inspiron 1525 Power Cord PA-12 $16.95 - AmeriMax Advance
DELL Inspiron 1525 DC Power Laptop Adapter ... £25.23 - B2C Shopping UK DELL Inspiron 1525 Laptop AC Adapter power adapter £38.99 - Very Good Battery Dell Inspiron 1525 Ac Adapter Charger Power ... £16.50 - eBay UK
AU/NZ - DELL INSPIRON 1505 E1405 E1505 AC Adapter Power Supply
Dell : Lind Electronics 70-Watt DC Power Adapter for Dell Inspiron
Apr 22, 2009 | Dell Inspiron 1501 Notebook
Accurian Model APD-3955 Portable DVD player
I had the same problem. It turns out that my adapter for my Dell Digital Jukebox mp3 player works great. You might be able to order one from Dell. I hope this helps.
Aug 29, 2008 | Radio Shack Accurian APD-3955
Motorola t5000 charger polarity
Pat
Aug 13, 2008 | Motorola T5000 Two Pack 2-Way Radios with...
Lost power supply
If the desktop charger is the version that can accommodate two radios simultaneously similar to the T5000, then the AC wall adapter or the power supply is 9 volts AC.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
May 26, 2008 | Cobra Radio Communications
Motorola TalkAbout T5000 2-Way Radio Logo
132 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
Greg Cann
Greg Cann
SHARCNET-USA
SHARCNET-USA
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
