Question about Samsung SCH-a310
Phone wont power on properly.
Hi, I have a Samsung A310. Earlier today I was on a call and ended it no problem but then it sounded like a key was being depressed so I powered it off to see if that would solve the problem. Now when I try to turn it on it says downloading mode and wont go anywhere?? Can someone help? My husband is oversees and this is our main communication!! Thanks so much!!
SOURCE:
SOURCE: key tone volume
press the down button on the left hand side of the handset, this controlls the key volume
Posted on Nov 05, 2008
SOURCE: How do I turn my Samsung Juke All sounds off mode back on
Press the Volume Down button on the side of the phone. That'll do it!
Posted on Dec 30, 2008
AmrSabri
  • 59 Answers
SOURCE: forgotten privacy lock password
Hello jakaleman,
Remove the sim-card and switch on the phone .. and press this code *2767*2878# .. the phone will restore the factory settings.
Thank you for using FixYa.
Posted on Apr 09, 2009
sWatti
  • 188 Answers
SOURCE: Samsung SGH-a707 solid red screen and says download! PLEASE HELP!
mAn i've gOt dA same pRoblem.............mA sgh a707 wAs fallen in water n aftR tHat i hAd da sAm eRror.........i took out da battery....n aFtr 2dAys mA cell was wOrkin..........
Posted on Aug 17, 2009
  • 7 Answers
SOURCE: Samsung Tocco Ultra wont charge or turn on.
you have probly blowed your battery (aka) a battery leak check your battery to see in you can squese it if you can then its leaked and you need to buy a new battery from amazon or somewhere else for about 5 pound plus P&P
Posted on Jul 22, 2010
Doesn't enable virtualization
To determine whether your PC supports hardware virtualization:
Step 1. Does my PC have a CPU with support for hardware virtualization?
Download and run the Hardware-Assisted Virtualization Detection Tool
If you receive the message This computer does not have hardware-assisted virtualization, your computer does not meet the hardware requirement for Windows Virtual PC, but you can still use Windows 7 XP Mode by running this hotfix. Be aware that XP Mode will run much better if hardware-assisted virtualization can be enabled.
If you receive the message Hardware-assisted virtualization is not enabled on this computer, go on to Step 2 below.
If you receive the message This computer is configured with hardware-assisted virtualization, download and install Windows Virtual PC and Windows XP Mode.
Step 2. Does my PC BIOS support hardware virtualization, and is it turned on?
Instructions to turn on hardware virtualization in your PC BIOS are specific to OEM models. It is important that after changing your BIOS settings the PC is completely shut down at the power switch before restarting so that the new BIOS settings can take place.
Examples for some models of some computer manufacturer's BIOS settings are below:
Sample instructions for your PC
Expand all
Dell systems
Depress the F12 key when boot menu text appears at startup
Select BIOS setup and depress the Enter key
Using the mouse, expand the Virtualization Support menu item by clicking on the plus to the left of Virtualization Support and select Virtualization
Check the Enable Intel Virtualization Technology checkbox
Click Apply
Click Exit
Fully shut down (power off), wait a few seconds, and restart your computer
HP systems
Depress Esc key when prompted at startup
Depress the F10 key to Configure BIOS
Scroll to System Configuration using the arrow keys
Select Virtualization Technology and depress the Enter key
Select Enabled and depress the Enter key
Depress the F10 key to save and exit
Select Yes and depress the Enter key
Lenovo ThinkPad systems
Depress the blue ThinkVantage key when prompted at startup
Depress the F1 key to enter the BIOS setup utility
Using the arrow keys, scroll to Config and depress the Enter key
Scroll to CPU and depress the Enter key
Scroll to Intel Virtualization Technology and depress the Enter key
Depress Enter key to continue
Depress F10 key to save and exit
Acer
PCs capable of supporting Windows XP Mode have already been enabled and do not require additional configuration.
Asus
Samsung
Panasonic
Depress the F2 key when boot menu text appears at startup
Select Advanced menu in Setup Utility
Change "Intel Virtualization Technology" setting from Disable to Enable
Depress F10 to exit Setup Utility
Select Yes in confirmation menu
Depress Enter to exit confirmation menu.
Please note the instructions above may not work in all cases and consulting with your computer manufacturer may be necessary. Additionally, we expect hardware virtualization to become more available when Windows 7 is shipped, particularly in business-class PCs. For those PCs that come pre-installed with Windows XP Mode we recommend the computer manufacturer turn on hardware virtualization before shipping the PC.
Once you have confirmed your PC supports hardware virtualization
Download and install Windows Virtual PC and Windows XP Mode
hope this helps
Aug 08, 2012 | Computers & Internet
Samsung flight will not power on - battery charged
The problem is a software problem.
All you have to do is to flash the phone with the appropriate software and cable.
The phone will be in good condition again.
Take care
Jun 22, 2010 | Samsung Cell Phones
How to use AlphaNumeric keys while talking on the phone (Samsung JET S8003). It is required when calling an IVR for enquiry and it required information in alphanumerics
You simply depress them while you are on the phone, you will hear the "Tones" when you press the keys, this will be "Heard" by the "Other End" and decoded, no problem.
Feb 13, 2010 | Samsung Jet S8000 Cell Phone
Keys 7 and 8 from the bass side are lower than
In Casio Chord mode, the bottom keys up to the second F plays Bass Chords. The Keyboard is just putting the keys you play back into bass when you get up that high. If you read along the plastic edge above where they keys come out of the keyboard, it shows you where the Chord keys end and the Keyboard begins. If you want use of all the Octaves, slide the power switch to the first setting (normal).
Jul 14, 2009 | Casio Ctk 496 Electronic Keyboard with 61...
I cant shift from park to any gear?its locked.
There is a brake interlock that makes sure the brake is depressed before you are able to shift out of park. It sounds like the switch has gone bad.
Nov 20, 2008 | 2004 Lexus GS
Samsung fridge freezer
sounds like the defrost thermostat is the problem. since it's located in the back of the fridge, behind the access panel, i would have a technician look at it.
Sep 13, 2008 | Refrigerators
Start up screen
Yup... find a reliable electronics tech to resolder/ solder in a new power jack.. Replacement jacks all over ebay.. not too hard, but you need good equipment and a steady hand.. Pay about $50-$100
Nov 20, 2007 | Samsung V25 XVC 2800 Notebook
Canon A310 Won't Power Up.
Try checking this... on the battery door (the outside door) along the top edge (over the CF card pointer embossed in the back of the door) you should see a little plastic piece that pokes out... tis is supposed to push a small switch located in a slot over the battery compartment. It's the sensor that tells if the battery door is open or closed.. if the plastic part breaks off or gets chipped it wont push the button and the camera will not turn on when the shutter door is opened.
Jun 09, 2007 | Canon PowerShot A310 Digital Camera
Samsung SCH-a310 Logo
222 people viewed this question
Top Samsung Cell Phones Experts
Felizardo Erilla
Felizardo Erilla
Bill Long
Donni Steen
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
