Question about Kenmore White Electric Stove
Kenmore c970 656421 , error message F11
Error message f11
How do I fix beeping F11 error code on my frigidaire stove?
The F11 error code stands is a shorted keypad. I suggest performing a reset on your range and you can do that by flipping the household circuit breaker off for at least 5 minutes. If that does not work you may need to have a professional technician
Sep 28, 2016 | Frigidaire Stove/Oven/Range Black Glass...
Had power outage & when electric company put new transformer on, stove came on with this error f11 error, when open oven door it mesg goes off & on, oven wont work now
I appreciate your post, Katherine!
Based off the information you have provided your Frigidaire range is displaying an "F11" error code after a power outage. An "F11" error code stands for a shorted keypad. I would suggest performing a reset on your range and you can do that by flipping the household circuit breaker off for at least ten minutes. If that does not work you may need to have a professional technician out to provide proper repairs. This will prevent you from any unnecessary part purchases. Hopefully this is helpful. -Matt
May 02, 2015 | Frigidaire Stove/Oven/Range Cooktop -...
I continue to get code F11 on my Kenmore Elite Gas Range Oven and therefore, I am unable to unlock / open my oven door. I have pressed and held down the STOP button as well as the oven light button.
Your model number should be much longer than 790 30 Open drawers and doors to look for the whole model number around the frame.
With the whole model number you can get more information at Sears Parts Direct. There are parts diagrams and user manuals and you can order parts.
http://www.searspartsdirect.com/
This site gives instructions for repairing F11 and recommends checking the temperature probe and tells how to do it.
How to fix Frigidaire oven error code F10 F11 F30 F31 etc AskGene com
Sep 10, 2014 | Kenmore ELITE 790 30 FREESTANDING DUAL...
Error message
try resetting the 40 amp double breaker in the panel
Nov 19, 2013 | Kenmore Frigidaire Glass Cook Top...
F11 reading on control panel of electrolux induction range
Go to the Electrolux website on your computer and look up the model of your range. Th owner's manual should give you what you need...download it!
Dec 25, 2012 | Electrolux EW30IF60IS | 30" Induction...
I have a kenmore gas range and on the display is says EO F2
The "F2 - E0" error code means "Shorted keypad".
Remove power from the range, open the control panel and unplug the membrane switch ribbon from the control board.
Reconnect power to the range and observe for an hour.
If the error code reappear - replace the control board.
If not - replace the membrane switch.
If I get the model # I can help you pind the right parts.
Good Luck and please rate 4 thumbs for the free answer
Apr 17, 2010 | Kenmore 30 in. 32384 / 32385 / 32389 Gas...
What does code F11 mean? How can we get teh beeping to stop?
F11: Disconnect power, wait 30 seconds and reapply
power.
If fault returns upon power-up, replace EOC.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Feb 04, 2010 | Kenmore Elite 44173 30 in. Electric...
Kenmore Elite Induction Cooktop Error Code 41
I realize this is over a year old. I have the same unit with the same error code. Last night, mine made a popping noise followed by smoke and then displayed the 41 and all E's. I pulled the breaker immediately. I'm sure that at least one controller board is toast.
I called Sears and it is under warranty but for parts only, so I guess I will give them a call and schedule the repairman. This should be fun.
Anyone else experienced this failure??
Feb 01, 2009 | Kenmore 42800 Stainless SteelCooktop
Kenmore White Electric Stove Logo
60 people viewed this question
Top Kenmore Cooktops Experts
Dan Webster
Dan Webster
jdthefixer
 Fix Your Board
Fix Your Board
Are you a Kenmore Cooktop Expert? Answer questions, earn points and help others
