You can get the unlock code from the online website like Unlocking4U Unlock Kyocera Rise Phone Unlock Code Unlocking 4 where they will provide the unlock co0de and the instructions to input the code.
In order to help, I need to ask you some questions. Did you tried to disable ECO mode and after that there was no change to the quality of print? Or you don't know from where to change this setting? Which screen "won't come on"? Do you refer to the printer display or the PC one? You can disable ECO mode directly from printer driver, from Printing Preferences.
Go to this link at Kyocera, select your carrier (Virgin Mobile) and then your phone (Rise C5155/C5156) from the drop down lists and a list of PDF manuals will appear. Best of luck! Kyocera Phones Support Page
I have the same problem. I have a Kyocera Rise sitting in a box, brand new. I need to know how I can convert it so I can use it with my Paylo account. Any step by step will help.
you guys are idiots! it's a Kyocera not a Motorolla! The Kyocera Hydro's bootloader is Locked down, same with it's twin the Rise. So until someone figures out how to unlock the bootloader your stuck. have you tried reseting to facotry defaults? If not here is your instructions and this might help you ^_^
First you remove the battery and reinstall it. With the phone turned off, Press and Hold the Volume Down and the HOME Touch Screen Button (The one theat looks like a little house), and without releasing those two press the power button long enough until you see the Kyocera Hydro logo, when this happens you may release the power button BUT NOT the Home and Volume keys. After a couple of seconds you will see a big android logo on your screen, NOW you can release both buttons. With the volume keys scroll down to WIPE/FACTORY RESET (This will erase everything on your phone except the contents on your MicroSD card). With your power button you select the option of WIPE nad after that it will prompt you with a lot of NO and one YES, scroll with the volume button then choose with the power button. After this you will return to the previous menu, so you just choose the REEBOT NOW with the power button, and voila MASTER RESET.
quit messing with the battery for starters. you want to startup into safe mode. If you can get into safe mode then its a software problem, if not then it is a hardware problem. also if the power cord is plugged in and the battery is out of the computer and the problem persists then it has nothing to do with the battery.
