Question about Plumbing
I HAVE A flotec pump model FPT20515 IT SAYS WIRE NETUREL WHEN I HAVE 2 HOTS FOR 220 NO NETRUEL IT SHOWS l2 =COM,l1 HI A IS LOW WERE DOSE THE 2 HOTS TIE INTO
3 Suggested Answers
  • 832 Answers
SOURCE: flotec 1/2 hp pump won't run. 124v line voltage.
Thanks for your reply.
Posted on Nov 09, 2009
SOURCE: have 2 black wires n
The TWO Black Wires are Phase and neutral and it's irrelevant which way they go on the motor, the Other is the earth and that MUST connect to the case.
Black, L1 & L2 the other green EARTH.
115 or 120 doesn't matter
Posted on Aug 09, 2010
Replacing a waterway 56 executive spa pump 3 hp with 4 hp. how do I wire plug into 4 hp pump
The pump motor should have a label on the side of the motor showing a diagram for Common, High speed, Low speed and the right positions for the connections.
Common is always the white wire
High speed is normally red
Low speed is Black
Green wire is always green
Oct 02, 2015 | Waterway Pool & Spa
Proper wire hook up
black goes to L1 white goes to L2 make sure to look on side of motor to change from 220 volt to 110 volt either a knob or changing wires brown and white to different locations hope you didnt fry motor
Jul 26, 2013 | AO Smith 1.5 hp 3450rpm 48Y Frame 115/230...
I thought I remembered how to wire a flotec 5182 pump, but obviously not. I put a new impeller kit into it and now it just clicks when I turn it on. The manual and the diagram on the pump are unclear. The...
try www.freeadjunction.com>wiring>wiring-dia
I found that site by going google and typing---schematic diagram for wiring a flotec 5182 pump
there are other sites if that is not suitable
Nov 18, 2017 | Flotec Pool & Spa
230 volt waterway spa pump model#sd-20-2n22cd electal scamatic
check voltage if 220 between two hots its 220 if only 120 low voltage if 220 ok then 1st hot to L1 then 2nd hot to L2 then green to ground or case if white you might have 120 volt then see side of case of motor for low voltage wiring
Apr 20, 2013 | Waterway Pool & Spa
White whire
if 220 2 hots and a ground 120 volt black to L1 white to L2 see side of motor for wiring must change to 120 volt
Feb 17, 2013 | Hayward SUPERPUMP 2.0 HP, 115/230V
I am trying to wire a dayton booster pump. it shows a L1 and L2 connection on the 115v connection. L1 goes to P1 L2 goes to T4. on the 220v connection it shows L1 and L2. L1 goes to wire P1 and L2 goes...
The power cord has a green ground wire; two hot wires, which are black and red; and a white neutral wire. Attach the neutral to the middle connector and the two hot wires to either end of the terminal.
In order to safely ground the machine the green ground wire must be securely connected to the dryer frame. There may be a screw on the frame where you can attach the ground
Jul 17, 2011 | Kitchen Ranges
Hi just wondering about 240 volt.What is the black wire and what is the red one and green and yellow....Which one is L1- N- E
The black wire is Half of the 240 volts. Both the black and red wires carry 120 volts to make 240 volts. The green wire is going to be your grounding wire. The yellow wir is more than likely your neutral wire (although that goes against the electrical code). Tie in L1 to either black or red. Attach the yellow to n. I hae no idea what the E stands for. What color and how many wire are coming from the oven?
May 08, 2011 | Ovens
Does it matter if use 220 or 115... looks like i have 25 amp in the box with gfi.. need connect the wire to back of the motor.. outside i have the big circular 3 pronged connection to the outlet... do i...
220 VAC is more efficient ... so there is some cost savings in the money department. Volts X amp = watts generally ... there is still a savings because you will actually consume fewer watts at 220 (watts is what you are purchasing form the power company)
Wiring depends ...you going to use 110 or 220? if 110 ... black is hot and goes to L1 ... white is nutral and goes to L1.
If 220 ... black is hot and goes to L1 - white is hot and goes to L2.
Your owner manual has a good picture and description of this.
In the plug ... 110 - neutral should go to the left slot.
Is your breaker 110 or 220 (single pole or double pole - one slot or two slots)
These voltages are not compatable!
I suggest you use this pump at 220.
Jun 04, 2010 | Hayward 1.5hp Pool Pump Motor Motor A O...
Flotec 1/2 hp pump won't run. 124v line voltage. But L1 to L2 shows -00.1 to -00.4 Power supply line is 12/2 to a on/off switch and 14/2 to pump from switch. Distance to service is less than 100 feet
With your volt meter, check the voltage at the circuit breaker or fuse to the neutral bar. If you have 120 volts there, then go to the switch and check the 12/2 hot wire to the neutral wire, if you have 120 volts, then check the 14/2 hot wire on the switch to the neutral wire.
if you have voltage going into the switch and existing the switch, then check all the connections between the switch and the pump.
When you're testing for voltage, do not test the hot wire to ground. You have to make sure that the neutral wire is not broken someplace in the circuit
Nov 08, 2009 | Flotec Corrosion Resistant Shallow Well...
Problems wiring Flotec sprinkler pump
L1- L2 doesn't care if blk or red. Make sure there is 220vac (240vac) on the supply wires. If there is there is something amiss with the pump. Eric
Jun 21, 2009 | Flotec 1 - 1/2 Sprinkler Pump Composite...
Plumbing Logo
208 people viewed this question
Top Plumbing Experts
Paul Carew
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
