Ge whdsr109j5ww washer
Makes scraping noise while agitating
dididsaythat
  • 291 Answers
SOURCE: Washer agitates, but makes horrible grinding noise. Spins okay.
thanks for posting problem solve :0)
Posted on Sep 03, 2007
  • 12 Answers
SOURCE: My Capacity Plus Admiral Washer will spin and agitate, but it makes a loud grinding noise.
Well, Sounds to me like the Bearings are going out, but it could make that noise a good while, before it goes completely out.. Replacement would possably be more cost effective, Kinda hard to beleive !!!!!!
Posted on Oct 26, 2008
  • 66 Answers
SOURCE: ge top loader washer agitator does not work
To check the agitator. Start the washer into wash cycle. Once started Push down on top of agitator. If it catches some times or all of the time when pushing down, then then doggets are worn, under the agitator. You`ll have to remove the agitator to see these. If by pushing down on the agitator, nothing changes, Then you probably have a transmition problem. Check this and let me know what you find.
Posted on Nov 27, 2008
Macintoast
  • 4 Answers
SOURCE: GE washer won't agitate
I had this same problem with our GE top load washer.  I just needed to pull harder.  (Note: The agitator is held in place by about a dozen L-shaped clips in a ring around the agitator's base that will release more as you pull harder on the agitator.)  Everything from the base below the large fins on up comes out together.  Grab the shaft above the fins and pull slowly and hard. I had to take the entire tub out, lay it on the porch, put my feet inside of it, and pull the agitator assembly out.  I wasn't able to pull it out while it was still in the washer.  BE CAREFUL! DON'T **** IT OUT; that might injure your back; just pull out slowly and as hard as you can without hurting yourself.  I was able to get it out successfully, but I am currently stuck at removing the bell below the agitator.  Good luck!
Posted on Feb 28, 2009
SOURCE: GE washer (wjsr4160gww) makes loud noise during spin cycle
Remove the front panel and you will see two metal guides attached to the front of the frame. One of them will probably be bent and the transmission assembly will have jumped over one or the other of the guides. You need to manually pull it back to center then straighten the bent guide. May have been caused by load being out of balance or machine not properly leveled. Good luck.
Posted on Mar 12, 2009
GE washer making scraping noise as it agitates, but clothes are clean and spin is normal
remove the agitator and check underneath for bra wire , coins , and any othering that are left in pockets
Aug 20, 2016 | GE Washing Machines
I have a top load fridgidaire washer model fwsc445rfs0. During the wash cycle it makes a high pitched scraping noise.... Struggles also while it winds down before rinse. Bearing maybe?
How To Fix A Washing Machine Making Noise During The ...
removeandreplace.com/.../washing-machine-making-noise-during-the-sp...
Jul 27, 2015 - Agitator directional cogs aka "agitator dogs" (top load washers) ... If you hear a rubbing sound or the drum spins uneven, then the ... A washer making a loud noise during spin cycle can also be caused ... The clutch in a washing machine connects the inner wash tub to the ..... May 8, 2015; High Water Bill?
Dishwasher Making Loud Grinding Noise During Wash Cycle
removeandreplace.com/.../dishwasher-making-loud-grinding-noise-durin...
Apr 11, 2014 - Dishwasher Making Loud Grinding Noise During Wash Cycle ... GE, Whirlpool, Frigidaire, KitchenAid, Maytag, Kenmore, and LG) this is a .... Our Amana dishwasher is making a loud, high-pitched squealing noise throughout the wash ....Out Of A Washing Machine - Top Load & Front Load September 30, ...
All comments on Loud dishwasher Frigidaire Gallery mode ...
https://www.youtube.com/all_comments?v=v-arYb20kOk
Dec 03, 2015 | Washing Machines
My GE top loading washer is making a clunking noise during agitation. Everything else okay
The problem may be in your agitator. The spline may be worn out. It is located under the spindle. Are your clothes becoming clean. That noise might be the agitator not fully engaged.
Feb 06, 2013 | GE Washing Machines
Whdsr109j5ww, this is a ge washing machine. Can you tell me the size of the machine (capacity)?
The GE Appliances support page describes this as a 3.2 cubic foot Super Capacity washer.
I hope that was helpful to you, good luck and take care.
Aug 07, 2011 | Washing Machines
I have a GE Clothes Washer WBSR3140G2ww when the washer machine starts it agitation there is a loud scraping sound to the left side of the machine. What are the possible problems associated with this...
I have the exact same unit in a 2nd home we just purchased and when the repair guy came, he said "it was in perfect working condition". Mine also has next to no agitation, I think a goldfish swimming around in a bowl makes more motion. I absolutely hate this washer and will replace it asap.
Nov 02, 2010 | GE WBSR3140DW Top Load Washer
Terrible noise while agitating
THAT COULD BE A BROKEN or LOOSE SCREW THAT HOLDS THE INNER TUB in the Center mast, hope this helps AJ
Oct 25, 2007 | GE WHRE5260E Top Load Washer
My GE WDSR2080G makes a metallic rubbing noise during agitation
Take front off and watch while it agitating useing a good light and see if you can tell where the noise is coming from 52c26ee.jpg
Oct 21, 2007 | GE WDSR2080D Top Load Washer
Washing Machines Logo
47 people viewed this question
Top Washing Machines Experts
