Question about RCA DRC220N DVD Player
When loading a DVD into the player, the blue info screen comes up and states: THE DVD EXCEEDS THE RATING LIMIT FOR THIS PLAYER. It then presents me with two options (cancel) and (override), but in order to override I am being asked for a password. I never assigned a password in the begining. I can't find my manuals What do I do? This disc works on every other player..............what can I do to correct this problem?
Try 0000
Posted on Feb 12, 2008
RCA DRC-285 DVD Player won't respond
hi, 2 things usually cause this kind of behaviour 1-the dvd+r have been burnt at a high speed 2-the dvd player itself is a bit old when you burn your dvd+R always burn them at a lower speed lowest if possible it'll take longer but it's well worth it and you wouldn't have a problem playing them back
Aug 22, 2007 | RCA DRC-285 DVD Player
Rca dvd player stuck
There are a number of possibilities, jammed gears caused by a disc or gears out of time, some have a very small loading belt located under the draw in most cases, excessive ware and tare on plastic gear linkage.
Sep 05, 2012 | RCA Televison & Video
For anyone who has an RCA DRC 8335 with dvd Recorder, here is a suggestion.
If your tapes have been recorded in SLP Mode, om another player, I can tell you they will NOT play on this thing!!
So, merely take another VCR, and a blank tape, Place the blank tape into the RCA DRC 8335 VCR side, and then, go to its Set-Up Menu, and go to OUTPUT. On the "ACTION BAR"Change the the RCA's output to "FRONT" and then, play the VCRr you stuck on top of the RCA!!
When the inage on the "Source tape is shown,
Record onto the RCA, in SLP Mode, Now, it will play, just fine.
Hope this helps. Jon (Found BY Accident!!)
Jul 31, 2009 | Televison & Video
User Guide for RCA DVD RCR 110D A1
The manual for this remote control is embedded in the operating manual of the DVD Player DRC 220.
icon_arrow_download.gif RCR 110D A1.pdf
Apr 16, 2009 | RCA (DVDCP33) Media
RCA drc286 screen flicker
it sounds like the vertical hold on your tv set needs adjusting also with your tv and dvd are there a set of three plugs usually red,white and yellow in colour ?? if so connect these with a cable as this by passes the tv tuner hope this helps regards JIm
Mar 12, 2009 | RCA DRC-285 DVD Player
System stuck on "hello"
I had this same problem and held down the play button after unplugging the player. What i found was that i could boot up, but that shortly after the screen would scramble and alternate between static images and a green screen that flickers. I believe the single chip that drives this has failed.
Dec 23, 2008 | RCA DRC-285 DVD Player
Language Selection for RCA DRC 220N
try to find an original remote in a pawn shop, sometimes they have extra remotes because broken dvd players, or other reasons they only know.
May 04, 2008 | RCA DRC220N DVD Player
RCA DVD player model DRC285
try sticking a knife on the top of the dvd slot. don't put a lot of pressure to break it though. turn the dvd player on, and it may open. If this solves the issue, try not to put items on top of the dvd player because it will cause it to stick and not open.
Apr 02, 2008 | RCA DRC-285 DVD Player
Can?t power on
You have a power supply problem,
  • Secondary look for faulty diods
  • look for a part pc817 opto coupler small squar 4 pins
  • look for tl421 transister
  • Look for any bloated caps
Hope this will help
Nov 03, 2007 | RCA DRC220N DVD Player
RCA DRC220N DVD Player Logo
194 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
