Question about Frigidaire Model: GLHS65EHSB
GLHS66EJW-O fan in middle rear of freezer buzzes when run nunning. When I removed rear covers there was ice
5 Suggested Answers
  • 15 Answers
SOURCE: Freezer coils get covered in ice about once a month
If the fan is running, replace the defrost thermostat!! Make sure the heater is working... see blog on testing the timer and heater!!
Good Luck!!
Posted on Aug 17, 2008
  • 147 Answers
SOURCE: FREEZER IS WORKING BUT REFRIG IS SHOWING "SPOILAGE"
Dont know about your model but some fans wont run if door is open.. Hold the light switch as if the door is closed. My best guess if the defrost timer or the mullion heater is shot..
Posted on Sep 24, 2008
rpbuice
  • 161 Answers
SOURCE: ice is forming around fan in back of freezer compartment
The defrost system is not doing it's job. I bet if you took the panel off below the fan you will see more ice on the cooling coils. There should be a light coat of frost on the coils but not a heavy ice build up. There is a heating element at the bottom area of these coils which should be defrosting all this ice.
1. A defrost timer turns this heating element on.
2. The heating element melts the ice.
3. A thermo disc attached to the coils will turn the heater off.
One or more of these are not doing it's job.
Posted on Dec 16, 2008
  • 56 Answers
SOURCE: ice accumulation touching blower wheel
ice build up is probable caused buy water overflowing from ice maker tub and get in back wall
Posted on Jun 03, 2010
Frigidare freezer making buzzing sound like a motor
You hear the evaporator fan that is probably rubbing on some ice buildup. Remove the rear panel in the freezer to confirm that there is ice buildup and post back to me.
Nov 17, 2012 | Frigidaire FRS23KF7AB Side by Side...
I hear a higher pitched solenoid buzzing for about 10 seconds every 30 minutes or so. It is a new sound and it seems to be coming from the lower right side of the fridge but I don't notice any...
is your ice maker hooked up?if no water is going to the ice maker and the arm is down it will buzz.also check the fans one in the freezer and one in the rear for the compressor and condenser,maybe a piece of paper is hitting the fan blade when the fan starts or it could be vibration in the frame,ytou can remove the bottom kickplate and you say every half hour or so it makes the sound and listen to see if you can pinpoint the noise,when you open the freezer door the evap fan will run,you can check that fan motor like that.you have to do a little detective work to find the noise but if the ice maker isn't hooked up to the water source and the arm is down it will buzz.good luck.
Jun 06, 2011 | Amana Side-By-Side Refrigerator 26 cu. ft....
Fridge freezer making a loud buzzing noise
My Samsung refrigerator (rf263aebp) was making an awful buzzing noise in the rear after only 1 year. I solved the problem by loosening the rear panel that covers the fan. Apparently, it was too tight and was rubbing on something (the fan?) and causing the noise.
May 24, 2011 | Samsung RS2630SH Side by Side Refrigerator
FP E381T, lights won't stop flashing, fridge not cooling properly
There is another fan to draw air into fridge compartment- access via fridge: remove back panel (long plastic cover- just clips off). Remove control housing (again, just clips off- careful of wiring though). Fan is located up in this channel between fridge and freezer compartments. However, from what you are describing, I think you have a blockage in the freezer drain, causing a build up of ice in the freezer which blocks the air flow to fridge.  To check, remove rear panel of freezer (clips off- you need to press down two clips at top of panel, they can be tricky to get off!!). Disconnect fan motor wiring by unclipping plug connection, and remove sensor wire(white wire) so panel can be removed completely. Now have a look in the trough underneath the evaporator, and check for ice buil up- there should be no ice in this trough. If it is iced up, you need to defrost ice and then pour some water in the trough and see if it runs away. In the middle of the trough there is a small hole where the water should run down and away to collector tray at rear of fridge- if this hole is blocked, water won't run away, so builds up and freezes and blocks air flow to fridge. If hole is blocked, poke a wire down to unblock.
If in doubt, call in the experts- F+P fridges can be a bit fiddly getting apart, as everything clips together ( I worked for F+P for 10 years, and I still sometimes have problems getting panels off easily!!)
Good Luck!!
Mar 10, 2010 | Fisher Refrigerators
I've had my samsung bottom freezer counter depth fridge for just over a year and in the last 5 to 6 months it's started to periodically make a very loud humming noise. Should I be concerned that there is...
The freezer compartment fan may have Icing or the motor is going.....Remove the trays and remove the rear cover. The fan and Freezer evaporator are behind that cover.
The fan doesn't run all the time.
If you have an ice maker it too can make buzzing sounds. Just turn off the Ice maker to eliminate it as a source.
Here's a link to the service manual for the 215
http://www.ajmadison.com/ajmadison/itemdocs/DA68-01778A-EN.pdf
Mar 08, 2010 | Samsung RB215LASH
My refrigerator was working then we moved it to another apartment now it is not getting cold.
Good day,
Assuming the lights are working, and you hear it running,
Check the most common problems first.
1. Open the freezer door and see if you hear the fan motor running. If not remove the rear panel in the freezer panel and inspect motor.
2. Most common, another fan motor motor in the bottom rear behind the rear cover was jammed while moving. Remove rear cover, inspect, and repair.
3. Check for wire damage elsewhere in the bottom area where that motor is located.
4. Make sure controls are on and set to normal.
Nov 05, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
FREEZER AND REFRIGERATOR NOT COLD
Is the compressor motor running.If no check starter/overload relay.
Check to see if the condenser fan at the back underneath near the compressor is running. If no check fan.
Are the condenser coils near there warm or room temp. should be warm
How to check stuff>
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Below the evaporator fan behind the rear cover inside the freezer is the evaporator coils. Remove the back cover in the freezer to observe the frost pattern. Light frost everywhere(NORMAL) or a partial pattern of ice(LOW ON FREON) or nothing(LOW FREON OR COMPRESSOR PROBLEM). heavy buildup of ice (defrost problem)
Aug 19, 2009 | Refrigerators
Buzzing noise from back of freezer
need to remove rear panel inside of freezer section. check for normal operation of evap fan motor. check for ice build up on evap.
Apr 21, 2009 | Amana ARS2464B Side by Side Refrigerator
Frigidaire side-by-side model # FRS26H5ASB4 making humming or buzzing noise
I had the same problem. I found the buzzing noise was caused by ice build up around the fan motor inside the freezer. I believe water must have leaked down around the fan during a defrost cycle. I removed the ice maker, the ice cube bin and ice dispenser auger motor. It sounds complicated, but it isn't too bad. The ice maker and auger are connected with quick connect plugs. So just unplug, remove the screws and remove them from the freezer. You will need to remove several other screws as well, I believe 11 in total as well as the top freezer rack. This will give you access to the white aluminum panel that runs from the top of the freezer to about halfway down the back of the freezer. After you remove the aluminum panel you will see the fan about half way down the freezer. I found a lot of ice around my fan. The fan blades were hitting the ice causing the buzz. Remove the ice and the buzzing is gone. It took me an hour to complete this repair. I hope this helps.
Nov 08, 2008 | Frigidaire FRS26H5AS Side by Side...
Hotpoint FFA70
Remove the plastic venting box which feeds cold air over the top of the freezer drawers,There are 4 hexagon headed self tapping screws,two at top.and two bottom.Now defrost all ice off rear of freezer and back of vent box.Now replace and door will shut with draws in.Make sure no ice left round fan housing.
Jan 21, 2008 | Hotpoint FFA70 Bottom Freezer Refrigerator
Frigidaire Model: GLHS65EHSB Logo
20 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
