I just bought a Sanyo 42 inch tv DP42841 model and the sound is super weird. Kind of fuzzy and scratchy especially if we turn it up past like 10. I have called the company and they already told me how to adjust it on the tv but no matter what we do it doesn't sounds normal. How do we fix it? We bought it from Wal Mart and I guess we only had 15 days to return it, and it has been past 15.
    Top Expert:
  • Televison & ... Master
  • 74,198 Answers
Check its speaker first. If it is OK, there should be some problem with its audio output circuit. If you wish to get more details, surf the following link. There are over two thousand and four hundred posts. All are related to television and other domestic electronic equipment service help. You can get a solution there. More than Hundred Thousand viewers cannot be wrong.
Posted on May 05, 2013
  • 58 Answers
SOURCE: Vizio 42 inch tv Power Not working
power supply problem sounds right to me.
Posted on Dec 08, 2008
SOURCE: polaroid television dead
I fixed my dead FLM-2632 by replacing the large black 150uf 450 volt power supply capacitor. I used a $4.09 Digi-key PN P14080-ND 420 volt 150UF Cap since I only power the TV on 110 vac. ( http://digikey.com. )The Rubycon 450 volt 150 uf Cap is no longer manufactured because it has poor life in a high ripple current switching power suppy application like used in many TVs. If you are not experienced in soldering, don't attrmpt this repair on your own. You have to cut the leads on the old Cap before you can carefully pry the old cap loose from the RTV. Use solder wick to clean the terminals before installing the new Cap. Hope this helps!
Al
menne@roadrunner.com
Posted on Jan 08, 2009
SOURCE: DP42746 Sanyo 42'' Plasma TV-CLASS ACTION STARTED
Sorry you wont get any help from Sanyo or Wallmart. Buy another TV repair people will take your money.
Posted on Jul 15, 2009
  • 188 Answers
SOURCE: Sanyo flat screen broken
Check back light inverter.
Posted on Jul 20, 2009
SOURCE: Missing owner's manual!
http://www.sanyotv.com/ownermanuals.html
Posted on Aug 25, 2009
Volume keeps going down
This is a problem with the sound select board, and there is no real solution. One thing to try is to press the manual volume up or down buttons on the side of the TV and keep them depressed to see of remote volume control is restored. This over rides the volume creep issue. I solved this by shorting the UP control to ground and the creep went away, but there is no manual volume control any more, but the remote still works.
Jun 23, 2014 | Sanyo Televison & Video
New (2012) DP42841 Sanyo no sound
Check all the cable connections to audio board for any loose connection. During long term storage, this might have happen. Reset all that cables comes to go out from it. If it do not help you, check the speakers. If all found OK, replace the audio output card. If you wish to get some details, check the site linked here. http://electronicshelponline.blogspot.com/Pull up older posts. Check the site in 'Mosaic' view.It will make search easy. Check its audio settings too. Whether it is muted or not.
Jan 05, 2014 | Sanyo DP42849 42 in. HDTV
Why my 42" sanyo DP42841 HDTV LCD SCREEN GOES BLACK ON THE LEFT SIDE?
That sounds like a faulty LCD panel tab. The only true fix is to replace the screen. This usually isn't cost effective.
Jan 19, 2013 | Sanyo DP46849 46 in. HDTV
I just bought a sanyo dp42841. I used to have the same tv in a smaller size. The first tv was hooked up to the cable and worked fine. When I attached the same cable to the new tv it's not able to find...
Be sure your cable is hooked up good and if you did not auto scan you must do this (auto scan) Found in the menu setup. Use the remote and press menu and it is usually found easily. Highlight the auto scan and start the scan usually by pressing volume +
May 20, 2011 | Sanyo 42 in. LCD TV
Hello my Sanyo dp42849 42 inch has no picture and no sound. when i turn on the tv a green light in the bottom right hand corner comes on and occasionally flashes off and then back on.
First, you need to know the sub-model of your TV.
It is called "chassis" and is shown on the back of the TV on the label where the model number is shown.
For example it can be "P42849-00" or "P42849-01".
Then search at www.coppelltvrepair.com/search or just go to www.coppelltvrepair.com and enter the link for SANYO DP SERIES to search for that.
Here's an example of a repair service (note it may NOT be the one for your exact model though!):
http://www.coppelltvrepair.com/p/41/sanyo-dp42849-p42849-00-does-not-power-on-repair-service
Hope this helps!
Jul 16, 2010 | Sanyo 42 in. LCD TV
Sanyo 42'' DP42848 Weird sound issues
You should get an extension of warranty usually is 3 months or until end of warranty if is more that 3 months.
Dec 04, 2009 | Office Equipment & Supplies
Jun 23, 2009 | Sanyo DP42746 42 in. Plasma Television
Televison & Video Logo
87 people viewed this question
Top Televison & Video Experts
Electro Med Services...
