Question about Nokia Cell Phones
1200 no backlight
Disply light
  • Nokia Master
  • 2,148 Answers
Hi, this problem occur because the led of the keypad or the socket of the LCD has frequently short circuit.So, as far as I know please check that keypad led is OK or not.If not Ok then you need to change the damaged led.LCD light and Keypad light are connecting parallel, so if the key light doesn't comes the LCD light will remain the same.If you think that you can repair it by yourself please leave a comment so that I will instruct how to do.Thank you
Posted on May 05, 2013
My cpu is front light on but not go to disply powr fan is ok runing but not show the disply plz help me any on
check the display monitor cord to CPU if attached perfectly/check on off switch of display screen
Feb 23, 2015 | Computers & Internet
Lcd light problm disply
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
In some models of LCD displays; the backlight inverter and its T'Con board will be a part of the panel itself, and will be a built-in type inside the LCD panel. If so, they can't be replaced. In this case; a panel replacement is the only repair. For some other models, the backlight inverter section circuit will be a part of the main power supply regulator [SMPS]. To such sets, the power supply section circuit too should be troubleshooted. Contact any service technician. The circuit will differ with models and versions.
Type in the brand name of your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
Feb 19, 2015 | Computers & Internet
Display
blank disply problem
Sep 14, 2010 | Jabra Earwave for Nokia 1200/...
Only power on in lcd.no disply and etc
This might be a sign of a faulty LCD cable or screen inverter board.
The LCD cable transfers data signal from the motherboard & video card to the LCD screen. It also supplies high voltage DC power to the screen inverter board. The screen inverter board works as a power supply for the backlight lamp mounted inside the LCD screen. It converts low voltage DC power to high voltage AC power needed for the backlight lamp.
Jun 14, 2010 | IBM ThinkPad T30 2366 Notebook
BACKLIGHT WILL COME ON AND TAHT IS IT. RESET HAS
the ribbon cable from the screen to the board might need to be reseated or the lock on the ribbon might of broke...
Jul 04, 2009 | Magellan Roadmate 1200 Car GPS Receiver
Having display light but display is not working
The display circuit is broken even if the LCD-panel seems to be ok. the only circuit working in the display is the one for the backlight.
This is a very common Nokia display problem.
Only solution is to change the display.
You need a T-6 Torx skrewdriver to do the job.
You can find displays for fair prise at:
www.mytrendyphone.com
This is your solution! Please vote!
Jun 27, 2009 | Nokia 3120 Cellular Phone
My phone on but never display
Use your main board, swap another phone step by step find down problem.could be keypad or display faulty or cable conector,but my expet display faulty.
Sep 30, 2008 | Motorola Mobility L6 Cellular Phone
Dark LCD
no.. its the backlight or the inverter.. both located at bottom edge of lcd under plastics.. the backlight is a mini fluorecent light tube in the lcd dotn try to fix it its hard. the inverter u can fix . inverter is easier and its 25$ in ebay
May 20, 2008 | Dell Inspiron 1200 14.1 XGA LCD...
Cell Phones Logo
63 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
