Question about Video Game Consoles & Games
My beatbox portable wont turn on - Video Game Consoles & Games
Where is the fuse in a dr dre monster beatbox?
If there is one it will be inside. The manual tells you how to reset.
Monster beatbox Manual And Warranty Page 19
This shows you how to get inside it and how to replace a faulty on-off switch, which may be your problem.
beats Beatbox portable disassembly and power button replacement by CITIROM
Oct 05, 2017 | The Audio Players & Recorders
How can I play music from my phone to my polariod beatbox
If your phone has bluetooth and the beatbox has aux audio in, you could connect a bluetooth receiver to the aux in on the beatbox. Then set your phone bluetooth on and follow the connect instructions you get with the bluetooth receiver. These units are available on amazon and Ebay for about $10.
Dec 07, 2016 | Audio Players & Recorders
Beatbox will not turn on
did you fix this problem? I now have the same problem. It worked perfectly one minute, and tyhe next minute it just won't turn on.
Apr 30, 2014 | Beats By Dr Dre Beatbox iPod Dock
My beatbox won't pair with my iPad
Try removing Dre Beats from Bluetooth settings (forget device) then reset your iPad. I just had the same problem and after that method they now work.
Feb 10, 2013 | Beats By Dr Dre Beatbox I Pod Dock
Batery wont charge
This is one of two things.
a) if the portable wont turn on at all then your plug-in is damaged.
b) If it powers on with external power but will not charge the battery, then the battery must be replaced.
Oct 12, 2009 | Polaroid 7-in Portable DVD Player,...
I have an amana portable electronic air conditioner wont turn on
try draining the water. Mine did the same thing. Started right back up. There is alot of water be careful.
Jun 30, 2009 | Amana Portable Air Conditioner
My portable air compressor turns on but wont turn
Check the operation of the relief valve. This is usually located near the regulator and gauge and has a small ring that you fit your finger in and pull outward. When you do so, compressed air should be released. If this is stuck or cant be released, there is your problem. It is quite dangerous to let the tank reach pressures beyond that allowed by the relief gauge. Usually 120-150 PSI.
Mar 06, 2009 | Coleman Air Tools & Compressors
Portable DVD player spins disc wont read
Doyou clean the laser lens maybe thqat is all the problem
Feb 14, 2009 | Teac DVP1010 Portable DVD Player
Screen gone out
My portable wont turn on?
Dec 15, 2008 | Durabrand Portable DVD
Video Game Consoles & Games Logo
320 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
