E2 message blinking on water boss
I unplugged unit because my display wouldn't change now it has blinking e2
2 Suggested Answers
hvac1960
  • 2133 Answers
SOURCE: the display panel on the
E-2 means indoor coil sensor not effective. Better clean with salt paper or replace it. Hope you wouldn't had cooling. Am I right? Thanks.
Posted on Dec 11, 2010
My water heater is a "Marey" propane and the water won't get hot and it keeps saying "E2" I lost my manual so I can't see what that means. Do you know?
An E2 code is often an indicator of an electrical problem inside the water heater. The most common problem is with the inlet water temperature sensor. Often a reset will fix the problem. To achieve the reset unplug the unit. Open the unit being careful of fragile electrical wires. Next remove the computer board and then disconnect each plug in wire and reseat them one at a time. Reassemble the unit and plug it in. It should be in working condition, without the E2 code.
Marey electric heater E2 error Marley Water Heaters
and also another idea here
found this helpful answer from plumber on JustAnswer com
and finally, how I found the answers.
E2 Google Search
Apr 26, 2017 | Water Water Heaters
Just installed, shows error code E2, is not heating water
May 22, 2015 | Water Water Heaters
How to change the door switch
Hello.
Some Washer ranges are equipped with electronic displays that indicate the time of day and the oven's temperature when it's in use. The display also alerts users to error codes including PF, or power failure, and various letter and number combinations that correspond to issues ranging from electronic control malfunctions to problems with the oven door latch.
Related Searches:
F2 Faults
Washer F2 faults relate to temperature problems in the oven. In the case of the error E2-F3, F2 is the general fault code and E2 is the specific error code. An E0-F2 error indicates that the oven's temperature sensor is open; E1-F2, that the temperature sensor is shorted; E2-F3, that the oven temperature has exceeded the maximum rated 575 degrees Fahrenheit in "Cook" mode; and E2-F3, that the oven temperature has exceeded the maximum rated 950 degrees Fahrenheit in "Clean" mode.
Clear Error Code
If your oven display shows a letter/number combination, washer advises clearing the display. Press "UPPER OFF" or "LOWER OFF" on double oven models. On single oven models, press "OFF/CANCEL" to clear the display. If the code reappears, the manufacturer recommends contacting a professional service technician or contacting the Washer producer
Professional Service
The Tech Sheet included with Whirlpool ovens is meant for use by professional technicians servicing the unit. To address an E2 F3 error, a technician can check the oven's temperature sensor connection, measure the sensor's resistance and, if necessary, replace the sensor.
Thanks.
Dec 07, 2011 | Washing Machines
What does it mean when your air conditioner has e2 on the display and is not working was just purchased on 5/28/11?
Unfortunately, you failed to mention which model GE AC unit you have. But, in most cases, E2 indicates a Sensor Failure Shutdown. Try turning the unit OFF & unplugging it it for 15 minutes. Then plug it back in and turn it ON. Hopefully, during the timeout, the electronics reset and reverted back to the original factory settings. If so, set the controls as you like and see what happens. If the E2 code reappears, contact GE Customer Service. The number should be in your Owner's Manual.
Hope this helped you and thanks for choosing FixYa.
Jul 23, 2011 | GE Heating & Cooling
PRINTER mp145 is displaying E2 error message saying that no paper, how ever im not going to use printer, instead i want to use scanner but with E2 error message i cannot scan so pls give me one solution.
Do you mean E,2,2 indication? It means Carriage error.
Replace the following parts in the given oder
Timing **** strip film Logic board ***'y Carriage motor (Main unit) Carriage unit (Main unit)
May 15, 2011 | Canon PIXMA MP150 All-In-One InkJet...
Got a message of an E2 and a smaall phone on my computer on the unit
An E2 Code indicates the drive motor is stuck in position IE: the main piston/sealpack is jammed. The piston is probably bent in the sealpack. This needs to be replaced. Try unplugging the unit for several minutes and plug it back in to see if it will reset. If not bypass the softener until it can be repaired.
RJ
Jan 07, 2011 | Culligan Sediment Water Filter Heavy Duty
What to do with an E2 error message.
that means the water condensate tank is full, you must unplug the unit, take it outside, unscrew the condensate tank plug cap, pull out the black rubber plug and let the water flow out until empty. then replace the plug, screw cap back on, roll inside, plug in and resume cooling. good luck! :)
Jul 19, 2010 | NewAir ACP-1000E Portable Air Conditioner
E2 -F 1- MESSAGE APPEARS ON MY DISPLAY
F1 = analog to digital failure. unplug the unit for 30 seconds if the clock does not reset replace the control board.
E2 = Check Door / Switch. Replace door switch if defective.
Repairclinic.com has the parts that you will need.
Feb 20, 2009 | Whirlpool GR465LXLS Electric Kitchen Range
E2 error code
In reading the manual for this coffee pot, it needs to have the descaling procedure run. The manual lists running a mixture of 6 cups water and 6 cups vinegar in a normal brew cycle...twice to clean hard water deposits from the machine. It says to make sure to remove the filter basket. Once the procedure is complete, unplug the unit and replug in to remove the E2 code.
Jul 26, 2008 | KitchenAid Pro Line Coffeemaker Coffee...
Heating & Cooling Logo
173 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
