Question about Randell (84111NPCB)
Randell 84111...Box stopped cooling. Rail works. Fans run, but TXV looks rusty and scary.
2 Suggested Answers
bobicehouse
  • 1524 Answers
SOURCE: I have a Randell 5ft
This unit uses Thermostat/Solenoid Valve Combination's to control the temperature
1. Rail 2. Bottom Storage
The way it works is the thermostat senses the need for cooling and energizes the solenoid valve. This allows refrigerant flow which cools the area it is controlling. Once the thermostat is satisfied the contacts open and the solenoid is de-energized closing the valve. If the solenoid is bad, the valve remains closed, no refrigerant flow, warm unit.
Test the solenoid coil (two wires) to see if voltage is present either with a volt meter, or remove the coil off the valve and place a screwdriver (insulated) through the coil hole and you should feel the pull like an electro-magnet (what a coil is).
Posted on Dec 05, 2010
Plif my cooling fans stop working ,is it most likely the fan moto or reley switch
look at temp control switch that turns fans on its a sensor mounted on motor or close to fans
Oct 07, 2014 | 1999 Oldsmobile Cutlass
Bottom section not cooling but rail is cooling fine.
Hello Roytorboli,
I understand that your make table is not cooling the bottom. However the rail is cooling just fine.
The rail is cooling because it sets above the evaporator coil. The evaporator coil fan is not working you should be able to here it running when one of the bottom doors are open. The fan is located in the bottom compartment and has to be accessed threw there. You will take the front panel of the back plate off. One you locate the fan remove the wires and label and go to your local hardware store to purchase. Be sure to take the old one so that they can match it up.
Thank you for choosing FixYa.com
Justin
May 08, 2011 | Randell RAN-8383N Refrig Raised Rail Prep...
We have a hot compressor (very hot) and no cooling in our Randell 9040k. Any ideas?
could be bad condenser fan motor or bad start components for compressor
Mar 01, 2011 | Randell 9040K-7
Installed new compressor. Pressures on rail only run about 25 low 250 high. When cabinet calls for cooling, pressure on low side climbs to about 45 roughly. Fresh food cabinet alone runs 18-22 on the low...
First check to see if the fans are running in reverse because on there way out they sometimes do that ,also check to see if the coils are dirty ,that goes for both condenser and evaporator.
May 17, 2017 | Randell Refrig Raised Rail Prep Table 60"L...
I have a Randell 5ft Pizza Prep table that's not working correctly and was wondering if someone might be able to help me? The top rail is cooling like it should but the bottom storage area is NOT cooling...
Dec 05, 2010 | Randell Refrigeration 60'' Refrigerated 2...
What controls the defrost of the evap coils, I have a S/N T27208-1 M/N 2020FRM On ocasion the two evap coils ice up, My charge is correct, My Evap fans all run. I see a two wire brown leads that go to a...
That should be The defrost termination. What controls the defrost is a defrost clock. It shows the time of day and the center will turn to start or terminate the defrost. Clock should be in a rectangular box.
Jun 10, 2010 | Randell 2020FE Freezer
I just had a bryant a/c installed (txv) should it have a hard start kit as well.
Anytime you have TXV they do need a hard start kit. The TXV shut down on the off cycle and does not allow unit to equalize. Rusty
Jun 11, 2009 | Goodman CLQ36AR49 Air Conditioner
RUUD 13 SEER HEAT PUMP MALFUNCTION 2009 MODEL
I sell Rudd equipment. You have air in the system or faulty TXV. Replace TXV and evauate system. No more problem. Rusty
May 27, 2009 | Heating & Cooling
RUUD 14 seer heat pump makes loud squeeking noise after cycling.
Your problem is the TXV. I just had person with the same problem. Replace TXV no problem Rusty
May 01, 2009 | Ruud UAMB Air Conditioner
Randell (84111NPCB) Logo
Top Randell Refrigerators Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
Are you a Randell Refrigerator Expert? Answer questions, earn points and help others
