Question about Sony FD Trinitron WEGA KV-32FS100 32" TV
Half Picture We can only see the bottom half of the picture. The top part of the screen in black.
  • 398 Answers
I have seen this caused by 2 different problems. The vertical output IC could be bad but it is usually the CXA jungle IC that fails to cause this. Either way the set should be serviced by someone experienced in repairing Sony TV's.
Posted on Aug 10, 2007
SOURCE:
Bottom half of screen is black
The display strip is not properly seated in the connector base. That is a hardware problem so dont think of a software error.
Oct 07, 2014 | Samsung Un46eh6000 46-inch 1080p 120hz Led...
When i turn on the tv, the bottom half of the screen is black. after a few minutes, i have a full picture.
set uses two boards to drive the picture, one for top and other for bottom half---sounds like one is bad in this set.
Mar 30, 2012 | LG Televison & Video
My JVC model AV-20F476 has a black-out box that covers most of the bottom half of the screen.
Go into menu and under CLOSED CAPTIONS look to see if TEXT is engaged---if it is set to text 1 turn it off or to text 2,3,4, etc
Text was a feature never really used but it is there, some cable boxes also have this setting/feature.
Let me know if you have questions.
Jan 11, 2012 | JVC Televison & Video
Bottom half of screen black-out
I would replace the lower Y buffer. Part number 996500032640. Goodluck.
Jul 05, 2010 | Philips 42PF7220A 42 in. Plasma Television
I am having a problem with my picture on the top
NEED REPLACED SU BOARD Manufacturer Panasonic Part Number TXNSU1HNTU Description PC BOARD
Feb 17, 2010 | Panasonic TH-42PX75U 42 in. Plasma...
Screen was going red on the top half of the screen, then..
The Y buffers were going bad, sounds like they went , you should get the Y upper and Y lower also the Y main. be aware the screen may be bad but tou won't know till you try the Y boards,
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
Jul 23, 2009 | Samsung HP-R4252 42 in. Plasma HDTV
Half of the screen is black; picture only on the right side of the screen.
your tv has one the Y buffers defective.which half is black,the botton or the top? i believe that you have to call the repairman .
good luck
May 21, 2009 | HP PL4260N 42 in. Plasma HDTV
Phillips 42 inch Plasma -Screen Issues!!!
intermittent loss of picture on either bottom or top half of screen is specific to y buffer boards located on left side of screen going from top to bottom when looking at back of tv. the y lower buffer would be the board to replace to resolve the loss of bottom half of picture. if the top half also is going out intermittently could tied to upper buffer as well but just a note the y main board to right of these buffers drives those two boards so in some cases could also be part of the problem. if only bottom half is affected i would recommend replacing lower buffer only
Aug 07, 2008 | Philips 42PF7320A 42 in. Plasma HDTV
Model 42mf231d/17 42" plasma
If the loss of picture is either on top half or bottom half of screen. there are y buffer boards that go from top to bottom on left side of screen when looking at back that control those sections. when there is loss of half of picture then buffer associated with that area would be at fault and would need to be replaced. when i see a degrading symptom such as loss of picture on top half or bottom half leading to no picture issue normally you would check heat syncs on y sustain board and if not heating up after a few minutes of being turned on would recommend replacing y main and both y upper and lower y buffer boards as they complete a circuit
Jun 04, 2008 | Philips Magnavox 27MS343S 27" TV
Screen split with black bar through center, top of picture shows in bottom
It sounds as you desribe, the vertical output IC and or the b+ feed capacitor off the Hi voltage transformer feeding the vert. IC its required voltage. Not a really hard job to replace, but not for a handi person to do. This should be left to the professional, as there are no user serviceable parts inside this set and with the HI voltage and the safety issues its best to call somesone to assist you with this repair. Good Luck
Jun 14, 2006 | Sanyo DS31520 31" TV
Sony FD Trinitron WEGA KV-32FS100 32" TV Logo
114 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
