Question about Garden
Qualcast quadtrak 30
Hod do you adjust the cutting height on this model?
5 Suggested Answers
SOURCE: MODEL 5521 RS
hi have a 550 horsepower lawnmower and the height adjuster handle has broke where do i get my hands on a new one anybody out that can help please let me know thanks mossieirwin@hotmail.com
Posted on Oct 27, 2008
heatman101
  • 43501 Answers
SOURCE: I can't adjust the cutting height. I trun the knob
That adjustment is a "fine" adjustment and will not usually make a noticeable difference...to make a bigger adjustment you will need to change the position of the wheels on the back corners of the deck....lower the wheels to raise the cut and raise the wheels to lowers the cut... then fine adjust with the knob....
heatman101
Posted on Jun 05, 2011
SOURCE: how to assemble a qualcast
Yoy posted this in the Telescope Forum.
Posted on Jun 10, 2011
  • 6468 Answers
SOURCE: how to adjust grass cutting height on
some old mowers you need to unbolt each wheel and move them to a different hole
Posted on Apr 22, 2012
How do you higher or lower the blades of qualcast hover mower
There are not any levers or anything to adjust blade height.
You change blade height by placing spacers above and/or below the blade. You have to remove the blade and relocate the spacers on the blade bolt to move the blade up or down.
Jul 01, 2014 | Garden
I need to adjust my scag mower deck
The mower deck can be adjusted from a height of 1.0 inch to 6.0 inches at 1/4-inch intervals. To adjust the cutting height:
1. Disengage the power to the cutter blades.
2. Push the cutting height adjustment foot pedal all the way forward using your right foot until it locks in place
3. Insert the lanyard pin into the cutting height index at the desired cutting height. Push forward on the deck lift foot lever, hold in place and pull back on the deck release lever. Slowly release the foot pedal. A deck height decal is located on the cutting height index as an aid in adjusting the deck to the desired height.
Aug 18, 2013 | Scag STT61V-27CH Hydrostatic, Gas Turf...
Front wheels on manual mower lock when pushing for awhile.
1 Locate the height adjustment lever on the inside of the left rear wheel.
2 Kneel next to the mower and push the left height adjustment lever toward the center of the mower. This will unlock the lever from the locking pin on which the height is currently set.
Read more: How do I Adjust the Height on a Great States Reel Mower? ' eHow.com http://www.ehow.com/how_6834215_do-great-states-reel-mower_.html#ixzz21NOr1e8d
3Rotate the lever toward the front of the mower to lower the height of cut, or toward the rear of the mower to raise the height of cut.
4 Release the lever over the locking pin closest to the desired height of cut.
5 Repeat these steps with the adjustment lever on the right-side rear wheel. Be sure to set the right wheel lever to the same position as the left-side wheel's lever for an even cut.
Jul 22, 2012 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Height adjust
The rollers are fixed. The feet are threaded to adjust for level. If you need extra height, cut some board the right length to fit from the front roller to the wall behind and run the fridge on to it.
Jul 06, 2012 | Whirlpool Refrigerators
Please advise on where to puchase replacement parts for old Qualcast punch classic 30s lawn mowers
Hi howardandjan, You call it "old Qualcast punch" if it's called Qualcast punch it's not that old, it was originally called Suffolk punch (after the horse) and came in 14" and 17" cuts, the 30s (30cm approx 12") was originally called suffolk colt. when Qualcast took over just about all the british cylinder mowers Atco,suffolk,webb etc they started swapping names about but you should be able to get parts from any good mower shop try winchester garden machinery in hampshire always found them helpful
Aug 30, 2009 | Garden
My mower is not cutting level. I have a new base
If the baseplate meets the cutting cylinder across the entire cutting width, it's adjusted properly.
Check that the front roller is level - it usually IS as simple as that.
If the roller has ben replaced with wheels, check that they are the same height.
Aug 22, 2009 | Garden
MODEL 5521 RS
Oct 14, 2008 | Husqvarna 160 CC Honda OHC Engine 21 in
Garden Logo
18 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
