Question about Black & Decker Black and Decker FIRESTORM 18v 18 volt hammer drill NEW
Forward reverse not worki ng
Forward reverse switch
Water pump not worki ng
the water pump is located in the front of the engine behind the waterpump. you'll need to remove the accessory belts,crank pulley, timing covers, and timing belt. this is about a 6 hrs job if you know what your doing.
Feb 24, 2014 | 2002 Kia Sedona
My g1 serial no. j31-149828 runs fine in reverse but has weak spark in forward & does not crank, any help would be appreciated.
Hi Larry,
There should be a micro switch for forward and reverse. Look underneath seat directly where gear selector goes through body. You should see a switch to activate forward and a switch to activate reverse. If unit cranks and drives well in reverse but not forward, I would start here. The G-1's I have fixed have this set up. Yours may be slightly different depending on the year. But I would find the micro switch that clicks when you put it in forward and replace it. They are fairly cheap and easy to switch out. Let me know how it goes for you. Good luck and happy wrenching!
Sep 25, 2013 | Yamaha G1 G-1 2-cycle Gas Golf Cart Tune...
Sagisag ng kromatiko
This doesn't seem to translate very well, but it seems like you might be wanting to switch your display to black and white or the reverse of that. This is typically done by adjusting the saturation to zero, and it will likely need to be done via adjustment of manufacturers display driver vs the Microsoft driver.
Ito ay hindi tila napaka-translate na rin, ngunit ito ay tila tulad ng sa iyo ay maaaring kinakapos upang ilipat ang iyong display sa itim at puti o ang reverse ng na. Ito ay karaniwang ginagawa sa pamamagitan ng pagsasaayos ang saturation sa zero, at ito ay malamang na kailangang ma-tapos na pag-aayos ng mga tagagawa display driver kumpara sa mga driver ng Microsoft.
Jun 09, 2013 | Computers & Internet
Hi screen goes black while worki.ng mostly after 20min
Check your power saving options by going into the control panel and then Power Options. You can tweak the settings to turn off the display after a determined period of time or to never turn off at all.
May 06, 2011 | Computers & Internet
There is no power to the wall switch resulting in the heater not worki ng
check the breaker. then get an electrician in to repair
Aug 09, 2010 | Water Heaters
2002 4x4 s10 zr2 4 wheel not worki ng
sounds like the 4 wheel drive
switch in the transfer case is bad.
Feb 06, 2010 | 2002 Chevrolet S-10
Black & Decker Black and Decker FIRESTORM 18v 18 volt hammer drill NEW Logo
Top Black & Decker Drills Experts
JOHN LAPIER
Are you a Black & Decker Drill Expert? Answer questions, earn points and help others
