Question about Sentry Safe Fire-Safe Home/Office Safe
Need the factory code for the sentry safe sbw3500 please
SOURCE: sentry safe msw3517
I have a Sentry Safe MSW3517 and forgot my code.
Posted on Nov 19, 2008
  • 10 Answers
SOURCE: defalt code for sentry safe 5 digits
You'll need to go here:
https://www.sentrysafe.com/customerCare/retrieveCombination.aspx
There is no "default code", but they do keep the serial number and code on file, for just this purpose.
Posted on Feb 18, 2008
SOURCE: Sentry Model 1610 Won't Open
I am a Safe Specialist i have been reading some of your problems and this should help there is no code if you have lost yours only the default code for the model 1610 the default code is: 77,22,09,11,64 try that if you havent changed it and with this problem with people not getting the handle open with the green light happening i suspect this is a issue with the lock mechanism i have had many of the same problems with people bringing them in when you get you safe open it and where the lock is put some lubricate on the lock regulary as the lock sticks and wont open if you havent done this then you cannot get it open see you local safe specialist and tell them what i have said and they may or may not be able to get your safe open i hope this has helped Rob Safe Specialist World.
Posted on Aug 21, 2008
SOURCE: Changing the code on my Sentry Safe S3877
how to change the on sentry safe s3877
Posted on Jan 20, 2009
SOURCE: know combination, but cannot open sentry safe 1250
If you know the combination:
1) Turn the dial to the left a few complete rounds, then stop on 1st number.
2) Turning the dial to the right, pass up the 2nd number once, then stop on it on the next round.
3) Turn the dial to the left directly to the 3rd number then stop.
The handle should open now.
Posted on Mar 18, 2009
Can't open safe!
If it still doesn't open after you replace the batteries then it is probably do to it being Jamed. I'd suggest tapping it with a bit of force but if it still doesn't open to go and see if someone can fix it.
Aug 12, 2016 | Sentry Safe Fire-Safe Home/Office Safe
How do I change the combination on SENPL048E sentry portable security safe
Open your Sentry safe by typing the five-digit factory code (found in your owner's manual) on the keypad. It's always a good idea to change your combination while the safe is open, so that you don't inadvertently lock yourself out.
  • Delete any existing codes by pressing the "P" key and entering the factory code, followed by "00000." On older safes, press the "PROG" key and entering your factory code twice to delete old codes.
  • Press the "PROG" or "P" key again on your Sentry safe's keypad.
  • Enter your safe's five-digit factory code.
  • Enter a five-digit code of your choosing within 5 seconds. This is your user code. While the factory code cannot be changed, your user code can be changed as often as you like, and that should be your primary code to open the safe. Only you should know your safe's factory code.
  • Mar 24, 2016 | Home Security
    I have lost the combination for my safe model V330 my model number V330 Sentry safe
    • Open your Sentry safe by typing the five-digit factory code (found in your owner's manual) on the keypad. It's always a good idea to change your combination while the safe is open, so that you don't inadvertently lock yourself out.
    • Retype the user code to verify it is working, and then close the safe.
    Mar 19, 2016 | Sentry FIRE-SAFE Combination Safe DS3431,...
    How do I open a sentry s3877 safe when the battery is dead and safe is closed
    The factory code combination to your electronic lock will remain in the memory of the unit - even if the batteries go dead. Any use programmed codes will be lost if the batteries lose power. The Sentry programmed factory code is always your default code.
    If you do not know your factory code, you can follow this link for your combination retrieval:
    http://www.sentrysafeshop.com/Lost-Combination-Sentry-Safe-Combination-p/lost%20combination.htm
    Sep 23, 2012 | Sentry Fireproof Safe
    Lost factory code for sentry safe model #d8W5840
    did you ever find the factory code? I lost mine also. if you have the factory code for this model please message me on facebook.com/vernhartjr
    Sep 09, 2012 | Sentry Safe Sentry Fire-Safe Combination...
    What is the code in enterfactory
    Hi.
    Hi. There is no factory fixed code. Thieves would be the first to benefit from such feature! The factory code is uniquely associated to the safe serial number and it is stored in Sentry protected database. When original code is lost the only way to unlock the safe is bay following Sentry's procedure.
    Contact Sentry immediately. They will first try an emergency unlock code, and then they will give you instructions in case the safe must be serviced. Here the contact: Call or Email Us
    Here general instructions about what to do when combination does not work. Instructions are addressing lost combination.The procedure is the same in all cases when combination does not work (malfunctions, lost combination etc.) . Please contact sentry and follow procedure to get the safe open.
    Regards.
    Ginko
    Oct 05, 2011 | Sentry Fireproof Safe
    I have a sentry safe model A3821 need factory code to reset my code does anyone know the code?
    Welcome to fixya
    Hello
    I have a solution for this
    Press Ok, Accept or replay so we may get started
    Your pre-solution is coming up shortly
    PLEASE REPLY OR LEAVE COMMENT TO CONFIRM YOU RECEIVED THIS EMAIL
    My name is Bruce
    Jan 16, 2011 | Sentry Safe Fire-Safe Home/Office Safe
    Need factory code for Sentry Safe Model 1610 - know its 5 digits but cant remember - never changed it from factory code but cant find the darn owners manual!
    If you need your lost combination, you must send a notarized letter stating you are the owner of the safe. The link below will tell you everything that you will need to get your combination back:
    Jun 13, 2010 | Sentry Fireproof Safe
    Need to open a Sentry keyless combination safe
    First, has the factory combination been changed? Sentry has the code for the factory combination that they can supply you.
    If the factory combination has been changed to something else, then Sentry won't have it.
    In that case you need to ask Sentry for a 'reset' code combination. There is (at least) one back door to your safe -- a reset code.
    The reset code will not tell you what your combination is, it will simply reset the combination to the factory combination.
    You can take it from there.
    Now, this isn't as hard as it may sound. There is an actual department that handles this at Sentry because you aren't the only one that cannot open his safe.
    They'll want some proof of ownership, some $$ for the service, the safe serial number, and probably a notarized form claiming that the safe is yours.
    Get 'hold of Sentry on the web and the rest is just process.
    BTW -- this is exactly what the locksmith would do.
    Apr 10, 2009 | Sentry Fireproof Safe
    Sentry Safe Fire-Safe Home/Office Safe Logo
    701 people viewed this question
    Top Sentry Home Security Experts
    Jim London
    Jim London
    Computer Repairing
    Computer Repairing
    Joseph Vernice
    Joseph Vernice
    Are you a Sentry Home Security Expert? Answer questions, earn points and help others
