Question about Dishwashers
Samsum upper arm sprayer part ppt20 for dmt300rfw dishwasher
Need to replace the ppt20 upper spraw arm for the dmt300 rfw samsung dishwasher
SOURCE: upper dishwasher arm not spraying water
Have you looked at the spray arm fixing nut at the back top arm as this has just gone on my machine
Posted on Sep 27, 2008
  • 9 Answers
SOURCE: GE Profile Max Dishwasher
I,m not familiar with this make or model but all spray arms should be removable bottom normally pulls off top quarter turn and pull and the back water feeding tube can also be removed usually by clips.rinse through thoroughly and hook out food stuffs with needle from the eyelets.the cause is general build up but mainly pips seeds rice etc.solution is to rinse plates before going in machine also checking filter is firmly in place before wash cycle.remove and check filters regulary. hope this helps
Posted on May 18, 2009
MNfisherman
  • 11896 Answers
SOURCE: upper spray arm on dishwasher does not move
you most likely have gunk inside the arm or holes not allowing the water to spray out and turn the arm. Otherwise, the arm bearing may be stuck and will need a gentle push to loosen up.
Posted on Sep 22, 2009
  • 97 Answers
SOURCE: we have a GE dishwasher with upper and lower
try c.l.r. to clean dishwasher check and clean lower and upper spray arms out, run no detergent you can also run vinegar in it as well about a cup full,let the machine start to run then stop dish washer for a few hours then restart see if this works for you use a short cycle.
Posted on Dec 01, 2009
SOURCE: The upper sprayer arm fell off on my Frigidaire FDBB4365FC0.
I just had the same thing happen and fixed it! You might need to remove the upper rack first. In the "Roof" of the dishwasher, you should see what looks like a plastic gear wheel. It will screw off, but you will need to put a little force to get it started. Inside of the gear is a free floating plastic ring with 2 small teeth on one side. Make sure the teeth are facing down through the center hole of the wheel. Hold the ring with one finger, and snap the spray arm back in place. Just screw the assembly back into the washer and all is good... Until it falls out again...
Posted on Oct 10, 2010
How do I reset a samsung dmt300 dishwasher
i have a samsung DMT300 Series. The heavy light keeps blinking. How do I reset it? It was leaking water and I believe we fixed it. What can I do?
Sep 12, 2012 | Samsung DMT300RFW Builtin Dishwasher
How do I replace the drain hose on a Samsung dmt300 dishwasher?
Flip the unit onto its face (put down towels first to protect the face and catch the water that will spill out. Remove the square white access cover on the bottom by removing the 2 screws and gently prying the tabs. Now you see the connection to the drain pump. Disconnect here and route the hose out by removing the metal side cover and snapping open the plastic hose guides. The hose is 13 feet long and routes up the side to prevent water from draining to your d/w from your sink, so a universal replacement won't work, you have to get a new one from samsung.
May 02, 2012 | Samsung DMT300RFW Builtin Dishwasher
Upper spray arm keeps falling off. Samsung Parts.com and their 3PL provider cannot ID the part. I don't have a parts breakdown drawing. Any suggestions. The Part Number on the Spray arm is DD62-00062A
The problem on my Samsung was not the spray arm but the part it hangs from. This part is a small grey socket with a part number of POM it costs about $12 including shipping from here:
http://www.searspartsdirect.com/partsdirect/part-model/Samsung-Parts/Dishwasher-Parts/Model-DMT300RFWXAA/1482/0130000/50037802/00005?blt=06&prst=&shdMod=
After the spray arm falls off or you remove it by pulling it down and off... take a butter knife and pry the small grey plastic clips off the left and right side of the small part the sprayer arm hangs from. You will see it may have significant wear. Just pop the new part on and clip the sprayer arm back on. The part in the above link is no. 5If the aboe link doesnt work... go to www.searspartsdirect.com and search Holder PART NUMBER: DD61-00228A
Hope this helps.
Charles
Aug 19, 2011 | Samsung DMR57LF Builtin Dishwasher
Dishes on top shelf do not get clean.
Your sprayer arms may be clogged.
The upper arm attaches to a tube in the back of the dishwasher. If the support clamps come loose, the upper spray tube will not be flush with the tube and can't carry water to the sprayer arms. Also the sprayer arms can become clogged with paper remnants, bone fragments, or pieces of peeling. You'll need to remove the sprayer arm and flush it at your sink. If there is a jet that is clogged, tweezers will help remove the residue.
I hope this helps. If it does, please come back to Fixya and rate my answer
Jun 13, 2011 | KitchenAid Dishwashers
Top shelf glasses are all foggy and not getting cleaned-mdb-5000AWW
Jun 13, 2011 | Maytag MDB5100 Dishwasher
Little water to top rack
Jun 12, 2011 | GE Dishwashers
MY DISHWASHER DOES NOT APPEAR TO BE CLEANING MY DISHES
Finally, the bottom of the door INSIDE the washer often get covered with gunk. Be sure and gently wash the bottom of the door INSIDE. You can open the door, spray some window cleaner on the bottom and then gently brush away the 'gunk.' Rinse with hot water from a pitcher or your sink sprayer and this can eliminate some of the residue that is showing on your dishes.
Jun 11, 2011 | Kenmore PRO 24 in BuiltIn Dishwasher with...
Upper spray arm falls off during operation, even after snapping
the clips that hold it in place are worn. you will have to replace it. they are not very expensive. to remove it simply unscrew the round disc above the arm
Feb 04, 2010 | Frigidaire Professional Series 24 in....
We have a GE dishwasher with upper and lower sprayers. The upper sprayer (one located right under top rack) won't spray or turn which leaves the dishes in upper rack dirty, any suggestions on how to fix...
Dec 01, 2009 | GE 24 in. Profile PDW9880JSS Built-in...
Dishwashers Logo
197 people viewed this question
Top Dishwashers Experts
Owen Barnes
