Question about Pico Technology PP337 ACE Misfire Detective Kit w/ Pico Labscope
Codes nissan i have a 1996 nissan Quest.i have some codes i need to check out..po.300,po.325,po.731
    New Friend:
Nissan Altima 3.5 2002 code p1102 and p0057
whats theses mean.
Posted on Apr 04, 2014
Hard starting, stalling
Check the fuel pressure, make sure it doesn't bleed down after the car sits, that causing long crank times/hard starting.
May 06, 2016 | 1996 Nissan Quest
How do I check engine codes on a '93 Nissan Quest?
Here is a general description on retrieving codes.
You will need to check online for the actual codes and their meanings. Systems built before 1996 will not show much compared to OBD2 systems built after 1996.
Turn ignition key on.
On Pathfinder, Pickup and Van models, proceed as follows:
    1. Turn diagnostic mode selector on ECU to ON position and wait until inspection lamps flash.
    2. Note number of flashes, then immediately turn diagnostic mode selector to Off position.
Feb 19, 2014 | 1993 Nissan Quest
2004 Nissan Quest error code P0223
CODE PO 223 IS REFERRED TO THE THROTTLE POSITION SENSOR OR PEDAL SENSOR.
Aug 29, 2012 | Nissan Cars & Trucks
My 1996 Nissan Quest car stereo stopped functioning
YOU MAY WANT TO TRY DISCONNECTING THE BATTERY OVER NIGHT I KNOW IT WORKS ON FORDS
Mar 04, 2010 | 1996 Nissan Quest
1996 nissan quest blower wont work. checked
There might be some heavy resistance with one of the wires leading to it. Have an electrician check it out.
Jul 14, 2009 | 2002 Nissan Pathfinder
Nissan quest 1996 cigarette lighter fuse locati
Check the cigar lighter fuse for blown.
Jun 05, 2009 | 1996 Nissan Quest
Can you please tel me how to reset my check engine light off?
with a obd 2 scanner or code reader or try disconnecting the battery
Mar 09, 2009 | 1996 Nissan Quest
Diagnostic codes
744 is to do with your torque converter clutch circuit, intermittent malfunction. 325 is knock sensor malfunction. Has vehicle been shifting different, probably at highway speed? (cruising) Have you noticed engine "ping"/"rattle" on acceleration? These would be common occurences with these codes.
Mar 06, 2009 | 1996 Nissan Quest
I have a 1997 Nissan Quest . Check engine light is on. Diagnostic codes PO744 and PO325. What do these codes mean?
if you can get the codes... why don't you have a book that comes with the code reader
get yourself a Haynes manual #64200 at your local parts store or online
Feb 22, 2009 | 1996 Nissan Quest
Nissan Quest 1996 minivan
you need to remove the lower balljoint and the center nut and it should come right out. use pb buster or wd-40 on the splines. they tend to rust up
Oct 02, 2008 | 1996 Nissan Quest
Pico Technology PP337 ACE Misfire Detective Kit w/ Pico Labscope Logo
115 people viewed this question
Top Pico Technology Science & Laboratory Experts
Tom Chichester
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Pico Technology Science and Laboratory Expert? Answer questions, earn points and help others
