Question about Coffee Makers & Espresso Machines
Delonghi ec330 steam wand not working
jonniewalker
  • 1029 Answers
SOURCE: steam wand not working
The steam wand ejects steam in order to froth the milk. The steam wand should be cleaned after it is inserted into milk and at the end of each day. Do not allow the steam wands to soak in water overnight since some of the dirty water can be sucked into the boiling tank inside the machine this may cause the steam not to come out
Unplug the machine, take the case off, disconnect the switch wires and test it with a continuity meter. If you don't get any continuity, or if it is constantly closed and never open, the switch is bad.
this could have been prevented by regular maintenance and proper use. The usual suspect is a gummed up wand or brew line or user error. Here’s what to look for and how to avoid it.
First, notice what kind of wand you have. Most semi-automatic and porta-filter espresso units will have wands that resemble those on bottom or right, although the tips may be different. Some tips do not slide up and down to alter the aeration, as the one on the bottom does. If your wand is from an older (1990s) unit, it could have a more bulbous tip and a smaller hole in the tip. wandte1.jpg wandte2.jpgSome of the new wands give you a manual/automatic control.
wandte3.jpg Many of the new super automatics come with an automatic frothing unit, like this one from Jura-Capresso. The nice thing about the frothing wands on Jura-Capresso's new units is that they allow for even more control.
The "Dual Frother Plus" (top) works like the traditional frothing wand. The metal sleeve goes up for steam, down for foam.
The "Froth Xpress Plus" is a very handy device which can be used with the included sleek milk container or a distinct milk container, like a 1/2 gallon jug. The Froth Xpress has a tube (hard for using the included container, flexible for using a different container) that fits into the frothing tube behind the dial shown in the picture above. After selecting froth or steam, the milk is siphoned into a cup below the steam wand. We recommend steaming the milk first, then adding the espresso.
Whatever sort of wand you have, it is essential to keep it clear of solidified milk which can gum up the tip and even the wand shaft. Here are some symptoms of a clogged wand:
  • Little or no steam comes out of the wand
  • Hot water drips from the tip of the wand
  • A squeal or whistle comes out of the wand when the steam function is selected
  • A deep humming is heard when the steam function is selected*
*This is also a symptom of another more serious problem, particularly if you have a pump espresso machine; so if unclogging the wand does not solve it, you should contact a technician.
A good preventative measure against the clogging of a steam wand is regular rinsing in warm, soapy water of the tip and any other removable frothing part. This should be done after each steam wand use. If your machine has a Froth Xpress, it is important to clean all of the hoses, valve, and connectors (be very careful with the plug, however, because it is delicate). All wands should also have steam jetted through them after a frothing cycle is run.
Another preventative measure is to run a steam cycle for about twenty seconds before each new use. This will eject stray particles before they can build up and cause serious damage. There is also a cappuccino cleaner available which can be used in the automatic frothing devices. The solution is placed in a reservoir, and a full cycle is run until the reservoir is emptied. This can be done every few weeks or every few months, depending upon use.
Aside from prevention, there are treatments for a clogged wand. First, remove the tip, if the tip is removable. Usually they are, as in the case of the plastic tips above. The holes are usually big enough to run a pin or even a small paperclip through (emphasize small) to remove the gunk. If these items are too large, do not attempt to use them; instead try using a thin gauge wire from an electrical wire strand. Next, the metal wand itself can have a pipe cleaner run up into it. Start out by putting just about a half inch of the pipe cleaner up the wand, rubbing it around, then pulling it out. Gradually work more of the pipe cleaner up the wand, but never let the length of pipe cleaner in the wand exceed the wand length. We recommend the pipe cleaners with the stiff barbs attached, as opposed to the mostly soft ones. Do the same for all of the hard hoses and connectors. With respect to rubber or soft plastic parts, rinse them in soapy hot water. If flexible hoses form holes, replacements are available (give us a call) or we've even had some luck at aquarium supply stores.
PLEASE NOTE: if you own the Jura X7 or the Froth Xpress Plus, the diameter of the tiny holes is very important. We recommend trying not to put pins into these holes. However, if they must be cleaned and soaking won't work, a smaller gauge wire, a single strand, should do the trick. Always use a strand that is smaller than the diameter of the hole.
Frothing wand technology is advancing at a breakneck speed, but along with these advances come serious precautionary measures for dealing with these very delicate mechanisms. Follow the steps above, and your machine should be producing full-fledged froth for its entire life.
Posted on May 26, 2008
When I got my X1 (used,) the steamer was clogged. I unscrewed the end of the nozzle, and a big chunk of calcium(?) came out. I had to poke it with some wire with the steamer on. The way I got the end off is: I wrapped it with a leather glove first, then turned it with a pair of pliers. I still managed to scratch it a little bit though. Maybe you can turn it by inserting a needle in the little hole on the side of the nozzle. I've been thinking of using distilled water to avoid the calcium build-up in the future.
Posted on Oct 08, 2008
EsWorld
  • 1618 Answers
SOURCE: Lost a piece of the black plastic steaming wand
Check with WholeLatteLove, yes I know the only have gaggia parts, its the same thing.
Posted on May 12, 2009
co7196
  • 3433 Answers
SOURCE: steam wand doesn't work
High pressure air using a blowgun?
Posted on Aug 24, 2009
  • 143 Answers
SOURCE: wega mininova - steam wand not functioning
try cleaning steam tip with small paper clip. if coffee is hot then steam wand is blocked. Try using a de-scale solution.
Posted on Sep 20, 2009
Steam is not strong on my ec702 delonghi. I have cleaned the wands. The wand spits out a lot of water with a strong steam, bu the steam gets weaker as I am trying to froth.
The steam temperature control (Thermostat) is not functioning.
The small quantity you get at the start is the steam pressure build up with hot water. Water steam cannot keep up the pressure.
Replace the steam thermostat.
Dec 24, 2016 | DeLonghi Coffee Makers & Espresso Machines
Espresso part is working, hot water/steam draining into drip tray.
I had the same problem on my Delonghi ESAM3300; you need to replace the "Tap" #7313216621 you can buy at eReplacementParts.com and search on how to install on Youtube. Its easy. No more leaking. Good luck
Oct 07, 2015 | DeLonghi ESAM3300 Magnifica...
Why is my delonghi EC 250.W steamer does not work at all?
If it's just the steam wand, it's probably clogged. Remove it and soak it in hot soapy water for an hour or two, rinse, and run it through a few steam cycles in a tall cup of plain water to clear it, with the steam valve wide open. Note, the water may splash, so take appropriate precautions when steaming it!
Sep 06, 2014 | Coffee Makers & Espresso Machines
Steam wand pops off
You are correct in associating the pop off is relative to the pressure. If the steam wand as you called it comes free when pressure builds, the problem can be the wand is damaged, not completely free of debris, or misaligned. I suggest you contact the company directly and have a technician run you through some tests to locate the problem.
Mar 25, 2014 | DeLonghi Coffee Makers & Espresso Machines
Water leaking from underneath my delonghi ec330s
There could be a loose hose, or a hole. Try to call the number the expresso came with.
Feb 08, 2014 | DeLonghi EC330-s Pump Espresso Maker
Ec330 steamer smells of burning
Either the outlet is short circuiting or your power cord is bad. You should try and plug it in to a different outlet. If problem consist, then you should call the company of the steamer and explain what happened.
Feb 07, 2014 | DeLonghi EC330-s Pump Espresso Maker
Delonghi ec330
Open the steam knob and turn on the pump
May 28, 2013 | Coffee Makers & Espresso Machines
I have a De'Longhi EC330S Pump Espresso Maker, 15 Bar it has been making great coffee for a year, but now the seals have blown and water just pours out from everywhere. Can it be repaired?
The problem seals on my EC330S are the one on the steam frother shaft and the connecting pipe from the pump to the boiler. The steam frother shaft seals are available from Buyspares.co.uk but the ones on the pipe from the pump are not available from them even though the pipe is. Mine are leaking badly so will have to look for some from a seal manufacturer if DeLonghi can't supply them.
Feb 09, 2011 | DeLonghi Pump Espresso Machine Stainless...
Coffee Makers & Espresso Machines Logo
90 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
