Question about Canon Buy Cheap Dealers Buy Cannon Copier Photocopier Imagerunner
I can'nt connect canon IR 2870 via cat 5 cable
I have canon IR 2870 i use it as a printer from USB port but i am unable to connect it with my pc through network wire (i.e. cat 5 wire ) over tcp/ip
spinal
  • 287 Answers
SOURCE: Canon iR C3220 Control Panel
Hi Ing,
I am not "at" a 3220 but I will try to visualize. On the "op" panel to the right of the display is a button that looks like an asterisk and says additional funcions.Press it. Bottom left tab says "system settings". Press it. New menu,right side , second tab, says network settings. Press it. At that point you should see tcp/ip settings. Press this tab and you will see the ability to manipulate many of your network settings."NOTE" this device is indeed capable of supporting being set to DHCP. You of course understand the pitfalls of having a printer set to dhcp. It is almost always recommended that a printer/scanner/fax/document server/ have a static ip address. However the right IT person in the right network enviromentwill have no trouble at all with this device. hope this helps, and if I did help please let "FIXYA" know it .Good luck and take care. .....................SPINAL........
Posted on Mar 25, 2008
  • 521 Answers
SOURCE: Canon imageRUNNER C3200 Copier network setup parameter needed
through the keyboard in printer features,after entering ip address you must go to maintenance?restart printer?? give copier up to 5 mins to spit out config page..job done?
or or
If I understand your question properly I can help you. Press the "additional functions" button which is located to the right of the display about halfway down the the keypad. It has an asterisk look to it and what I believe is supposed to be a "look" of a human head. LOL. Press it and you will see a menu. Two columns appear. The last item of the left column should say system settings. Press it. I am doing this from memory so you may have improvise as my memory sucks. Once you press system settings you should see a new menu, unless you IT guy has blocked access to these features as many do. In which case I cannot help. In the event you indeed do have access you should see a new menu. Since I do not have a machine in front of me we can struggle together. Once you have selected system settings you will see a new menu that the second column in the right should say "network settings".Press it. Then you will see on the second tab tcp /ip settings. Press it. At this point you can change the IP address settings. The area where you are now will also allow you to change the DNS server settings and just about everything you might want. Once you have made the changes you wish to make......back out by pressing reset till you get back to the main copy screen. Now in order for the changes you have made to take effect you must turn the machine off and back on using the power switch located at the right side of the copier, at the rear of the right side, about halfway down the machine.Turn the power off, wait a few seconds , then back on. Within 60 seconds the copier will accept the the new network changes . i hope this helps you and take care
Posted on Aug 12, 2008
SOURCE: canon ir 2016 cannot/wont connect to computer via usb
I have a machine it write DOWNLOAD STANDBY.Hw may i do it.
Posted on Apr 20, 2009
SOURCE: Canon ir 330-400 copier
it is supposed to use a separate scanning board (Interface Board-D1) with SCSI connectivity and TWAIN software.
Posted on May 19, 2009
SOURCE: Network ScanGear can't discover Canon IR 3220
Had the same problem with my Canon IR2018i... After spending about all day stuffing around and ready to give up... I read in the Color Network Scangear User Manual that
"Only scanners on the same subnet (network with the same network ID) as your computer are displayed in the list"
So I went the the TCP/IP settings on my copier and changed my subnet mask from 255.255.255.0 to 255.255.255.255 and magically my scanner appeared....
Give it a go...
Posted on Sep 01, 2009
How to Clear Error- 000716-0010 in Canon IR2870 Copier?
E716 - There is an error in the communication with the pedestal.
After the presence of a pedestal has been detected, the communication fails to be normal for 5 sec.
1. Check the cable. Replace the DC controller
2. PCB. Replace the pedestal drive PCB.
http://www.smoothprinterservice.com/
Sep 22, 2014 | Canon Ink Cartridge GPR15 for iR 2270, iR...
How do I solve Error Code - E000716-0010 In Canon IR2870
Failure of the communication with the 2-way unit
Description
When the communication with the 2-way unit is faulty after detecting the connection with the finisher.
Remedy
1.Install the 2-way unit.
2.Check the cable.
3.Replace the DC Controller PCB (PCB4).
4.Replace the 2-way unit driver PCB.
How connect a tcp ip printer.
Hi Kumar,
You can modify or change port in the printer driver to connect it through LAN cable. Please notice whether you use static or dynamic ip address. Please follow below step.
In the following step we will modify your existing USB connection. Check it out!
Step:
  • Open printer driver list.
  • Right click on the printer drive name (e.g Canon IR2270).
  • Select Properties.
  • Click Ports tab.
  • Click Add Port, then select Standard TCP/IP Port.
  • Click New Port.
  • Click Next on add port wizard menu.
  • Type IP Address (for static ip setting) or Printer Name (DHCP), then click Next (computer will search the printer).
  • When the printer has been found, finish the wizard.
  • Close Add Port menu.
  • Now you have new port represented by IP Address or Printer Name (with checked box active) in port list .
  • Click Apply.
Bingo! Now your printer ready to print via LAN. Sometimes printing right after setting this new port not always succeed. Don't be panic. Restart both of printer and the computer.
Next time you want to connect the printer via USB port so you change port back to USB. Just simply check on the check box next to USB Port in port list and click apply. You may need to restart both printer and computer too :)
Have a nice day!
Printer Clinic
Jan 13, 2014 | Canon iR2270
Canon ir2870 e000732-0010
your problem might be faulty connection on your DIMM modules.
Take it out and clean the contact area with a brush, place it back and start the machine.
If this dose not solve your problem it means the Reader Controller PCB is faulty and needs replaced.
Oct 29, 2012 | Canon Ink Cartridge GPR15 for iR 2270, iR...
How i connect my massing to computer?
if u wanna connect to single computer then u can connect via USB port . insert the cd .run the driver it will ask to connect the machine and rest will be easy. if u wanna connect to network then u have connect the cable to lan port and then enter ip address in the ip address settings of the machine and wola turn on/off machine its done.but make sure to load the driver in the server
Jun 28, 2011 | Canon imageRUNNER 2870 Copier
The iR2016 has a printer cable connection at the back. Why doesn't my iMac see this when I connect the cable via USB?
the USB port on backside of the iR2016 is ONLY for service support tool, cant be used as printer.
Aug 25, 2010 | Canon iR 2016i Black and White Copier
Hi, I have brand new Canon MP140 3 in 1. I am getting the error message &cannot communicate with scanner. Cable may be disconnected or scanner may be turned off. Check status. scanner driver will be...
1. If you are connected correctly (via a USB cable), first be certain that the cable is snug on both sides (PC and Canon MP140).
2. If still a problem, remove the Canon MP140 icon from Printers and Faxes.
3. Then, disconnect the USB cable.
4. Restart your PC and log into Windows.
5. Connect the USB cable.
6. The PC should recognize the Canon MP130 and ask for a driver.
7. Install the driver.
If #6 does not happen, your USB cable could be faulty or may be a problem with USB port or your Canon. Move USB cable to a different USB port on the PC. Replace the USB cable. Try to install the Canon on a different PC to test.
Hope this helps.
Aug 11, 2009 | Panda ANTIVIRUS ED PLT 7.0 1YR 26-50...
Unable to print to canon IR 2020 when connected through router.
Try to conect directly with cross utp cable to an pc, if every thing works, its your network problem (maybe privilegies, banns,...) if not ... good luck :-)
Try to reconect the pcb s
Dec 10, 2008 | Canon imageRUNNER 2020 All-In-One Laser...
Mar 15, 2008 | Canon imageRUNNER 400S Copier
Canon Buy Cheap Dealers Buy Cannon Copier Photocopier Imagerunner Logo
old marine
old marine
