Question about Garden
EXmark mower 48 i try to engage blades and it dies
GM Elec
  • 1000 Answers
SOURCE: Craftsman riding lawn mower...engine dies when blade is engaged
Push the clutch all the way down and try to start, does it crank over?
Let me know.
Regards,
Posted on May 10, 2009
lester482529
  • 226 Answers
SOURCE: Knocking in mower deck or belt clutch when engaging blades, motor bogs / slows down
YOU MAY HAVE A BENT BLADE OR EXESSEIVE BUILD UP UNDER THE DECK
Posted on Jun 01, 2009
wadembly
  • 475 Answers
SOURCE: Craftsman riding mower blades will not engage
maybe the safty switch under seat might be starting to go out if that switch doesn't work the blades wont come on at all for safety
Posted on Jun 28, 2009
  • 133 Answers
SOURCE: Craftsman riding mower noise when blades engaged
With blades on and engine off reach under and wiggle each blade up and down. If you have excess play you will need bearings.
Posted on Aug 13, 2009
wireguy212
  • 1627 Answers
SOURCE: john deere gt 235 electric blade engagment but
One of two possible causes;either the PTO switch is defective or the switch for the reverse peddle is out of adjustment .The only other thing i have seen cause the PTO to shut down is a lack of battery power due to the machine not charging.
Posted on Mar 21, 2010
Poulan pro engine dies when blades are engaged
Something may be wrapped around the blade shaft under the mower deck or maybe the shaft bearings are bad.
Aug 10, 2014 | Poulan Garden
Why exmark loses power when blades are turned on
Check for clogged deck.also inspection of mower deck belt. Check for glazing or cracks in belt. That will slow blades down.
Jul 28, 2014 | Kohler Engines NEW 25HP KOHLER ENGINE...
Mower runs fine turn on blades it will die
MikeMake sure that the blades will turn by hand (key out of switch- unplug the sparkplug wires!!!!) there could be a dirt mound or rock jammed in there. OR-
if you\'re in the seat and the engine dies just as soon as the blades are engaged, the engine may need a tune-up. It sounds like it starves for fuel or air under load.
May 04, 2014 | Husqvarna Riding Lawn Mower Yth24v48ls 48...
Mower runs fine.when u turn on blades it will die
There is a switch under the seat made to turn off the engine when the blades are "on". You have to be sitting on the seat to engage the blades. If you are, check to see if that switch is plugged into the harness. If it already is, you probably need a new switch, or less likely, but possible, the harness is damaged somewhere up the line.
Exmark 44
When you say 'going forwaed', is that while mowing or does it do it without the blades engaged or 'not mowing'?
Jun 13, 2013 | Kohler Engines NEW 25HP KOHLER ENGINE...
My Xmart 0turn mower blows a fuse every time I pull yellow knob to engage blades
unplug the clutch and try it? if it doesn't blow then the problem is the clutch if it still blows follow the wires to see where they are rubbing on metal
Apr 17, 2012 | Encore EXMARK LAWN MOWER HEAVYDUTY STEEL...
I have a husqvarna riding mower and when i turn it on and release the brake the mower dies and when i put the blade on or give it gas it dies, but for the most part just releasing the brake after letting...
It sounds like the seat switch is not working. This switch must be made by a person sitting in the seat for the brake to be released or for the blades to be engaged. It is possible to start the mower with the switch open.
Gary
Jul 03, 2011 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
My 48 inch riding mower shuts off when I try to engage the blade. It runs until I try to engage
mine has a reverse cut out when blades are running....maybe the switch is bad and thinks mower is in reverse therefore shutting down the mower when the blades are engaged....
Aug 21, 2010 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
2007 Husqvarna Riding mower blade will not engage when switch pulled out. Fuse blows & mower dies! Help!
Sounds like you electric blade clutch is bad. I just had the same thing happen to my exmark mower. I was cutting grass and the engine just shut down. It would not crank over. Checked the fuses and replaced one blown fuse. The engine wanted to crank over but it was locked up. I looked the engine over and seen that the bearing in the electric clutch seized up causing the clutch to melt.
Apr 25, 2010 | Husqvarna 23 Hp 48" Deck Yard Tractor
Engine dies when i engage the blades on my craftsman 24hp 48" deck model dyt4000
There is a safety switch that is connected to the seat, so that if you get out of the seat with the blades running, it will shut the mower off. That switch may be bad, or disconnected. Look for a pair of wires running up under the bottom of the seat. As a short-term fix or a test, you could connect those two wires together.
Mar 07, 2010 | Craftsman 24 Hp 48" Deck Yard Tractor
Garden Logo
105 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
