Aeware hot tub
"P1Er" flashes on my tub.. And then "STBY"... I filled and heated my tub, after getting everything dialed in, I went to get in it that night and it was 6" low and dropping..
5 Suggested Answers
cpenzes
  • 1102 Answers
SOURCE: washer tub will only fill on the hot setting
Is the tap to te cold water turned on
I would check that
Posted on Jan 18, 2009
  • 6 Answers
SOURCE: hot water stream when tub fills & how full tub gets super wash
there should be a knob connected to your water lines that come from the wall, turn the hot to the left.
Posted on Jun 22, 2009
WonderTech
  • 268 Answers
SOURCE: Washer was empty and off. Tub filled with water
Could be sediment build up in the water inlet valve. Replace water inlet valve.
Hope this helps you.
Posted on Aug 14, 2009
  • 64 Answers
SOURCE: i can't get the cold water to fill the tub/rinse. the hot works.
IT SOUNDS LIKE A SILENODE ON THE INLET VALVE
Posted on Sep 21, 2009
Heat suspended flashing hot tub loosing temp. Down from 104 to 84
just a guess but id say your temperature controller has failed and it went over temperature , the safety cut in to save the tub (heat suspended) could be anything in heating circuits from heat elements to temp probes
Jan 22, 2016 | Pool & Spa
My Aeware hot tub wont heat the water what is the problem?
Is the water pump delivering water to the jets? If not, then you may have an airlock. Prime the pump and check again. If you have water coming from jets but still no heat, then it may be time for a new heater section.
Dec 06, 2014 | Pool & Spa
Cant find the filter for my Aeware Hot tub
Take the filter to a hot tub shop and they will be able to identify it for you. Any shop that sells pool or spa equipment should be able to help as most manufactures use aftermarket filters for cost reasons.
Apr 26, 2013 | Televison & Video
Bosch exxcel washing machine not heating water
Are you sure it's not heating the water? The only time it heats is when it takes the detergent, all rinses are in cold water only. To test the heater, put the dial to the OFF position, press and hold the start button whilst turning the dial one click to left (30 easycare) when the two middle lights come on or 888 in display (if there's a display), take your finger off the start, turn the dial to 90 cotton (the long way, counterclockwise, not thro the OFF) press start, the tub will fill and it will do a stationary heat, you should hear the element/water making a noise like a kettle boiling. Leave the machine like this for a few minutes. Put dial to off until the door lock disengages and touch the water to see if it's warm. Put the machine on drain to clear water. If there is defo no heat repost and I will give you step by step of changing element.
Cheers Roni
Mar 01, 2013 | Bosch Exxcel WFO 2264 Front Load Washer
Dishwasher keeps getting stuck on wash programme
Hi, it's most likely pausing in wash cycle because it is not heating, most d/w timers will loose power to the timer motor until the wash tub has reached a desired temperature, if its not heating the water it will not advance, although it still could be the timer it self but most likely a faulty heater element or thermostat, does the timer advance at all?
If so where timer dial pauses (gets stuck) open door and check water temp (just feel) and close door give it 10Min's or a bit more and water should get alot hotter (anywhere from 45°c to 75°c) note if it is hot fill water may be hot but not hot enough to trigger temp thermostat to activate timer, if your handy and can see its not heating try to check the Resistance of thermos and heater
Jun 27, 2011 | Dishwashers
Motor will not come on. flashing OH on tub display dial. Dream maker Model #8003 x 400 series 86L Just purchased used spa and have no manual or directions. thanks
OH stands for Over Heat situation.
If the motor is not working at all, you are getting the OH code because of that. The OH happens when there is not enough circulation in the hot tub which causes the water near the heater to overheat the sensor located in that area. It sounds like either the pump has failed, the wiring has shorted to the motor, or the control board is not telling the pump to come on.
Its probably a bad motor since the heater is obviously activating, which it wouldnt if the pumps motor was getting no power. Replace motor and all should be well again.
Apr 14, 2011 | Dream Maker Spas Dream Maker Ez Spa Hot...
I just installed my new X400 Dreamaker Spa. I filled it with water (although cold) and it has been warming up for approx. 18 hours and is only at 80 degrees? Is this normal? How long should it take to...
This is normal with the dream maker spa. The dream maker spas are poorly insulated, and only run 120 volts with a very small heater.
When the unit is first filled, the hot tub will not heat full time either. Most new hot tubs will have freeze protection below 50 degrees F. They will recirculate automatically using the friction and the pumps heat to warm the water above 50 degrees, and then the heating unit will kick on. These hot tubs do not heat while the jets are on high either, so once you are in it using the jets on high, the temperature will start to fall.
Now that you are up to 80 degrees, it should heat up fairly quick however.
Nov 19, 2010 | Dream Maker Spas Dream Maker Ez Spa Hot...
Water not heating
It sounds like your inline heater has stopped working. The only way to test it is to drain the water back out, remove the inline heater, and hook power to it to see if it heats up.
If it doesn't you can get one at a discount supply house (like Home Depot or Lowes) for less than $150.
May 28, 2009 | Home
Heater light flashes but heat will not come on on its own
sounds like the heating element is going bad, have someone come out and change it, it will be fine
Apr 16, 2009 | Water Heaters
Washing Machines Logo
Top Washing Machines Experts
