Login linda 6013@verizon.net - Computers & Internet
Tip
How to Reset Password on Latitude?
We have usually had no idea on problems, such as: help reset password on Dell Latitude laptop , Dell Latitude admin password hack, bios password reset Dell Latitude, how do I reset my dell Latitude notebook back to the factory, etc. Once problem comes with password, we will hopefully get easy and quickly solutions supported for us! Now, we collect some ways to reset Dell Latitude password if forgot password again.
1. With created Dell Latitude password reset disk to recover lost Windows XP, 7, etc. password.
Though it maybe the most efficient way to help us in case we meet such password problem, most of us may not make sense of the importance of the disk for us PC users. The disk needs to be created before we forgot Dell Latitude password or once we set the account. If you did not have one, now look for Dell Password Reset Disk.
2. Unlock Dell Latitude password in Safe Mode (in XP)
Step 1. Press F8 when Latitude laptop starts. Select "Safe Mode with Command Prompt" and Enter.
Step 2. At the login screen with computer user accounts, choose an available account to login. Please note that the Administrator account (default/built-in) password is blank if never set password for it before.
Step 3. In Safe Mode, Dos command displays. Input "net user" and press Enter to list all the user names in Windows XP computer. Then input "net user Linda 123456" (Linda is the locked account name and 123456 is the new password set on this account) and press Enter. Then we will see "The command completed successfully."
Step 4. Input "shutdown -r" and press Enter to restart the system, then we can access "Linda" account in normal logon mode.
3. Easy to recover lost Dell Latitude Windows password by DIY a password reset disk.
DIY password reset disk is just to say, burn an .iso image file into a bootable CD/DVD/USB Flash Drive for the lost account after forgotten Windows password. The .iso file can be mainly got from professional password recovery software. Take one of the most popular software - Windows Password Recovery Corporation as example:
Step 1. Download Windows Password Recovery Corporation and burn .iso file to a bootable CD/DVD/USB via an accessible PC.
Step 2. Boot the target computer from CD/DVD/USB.
Step 3. Retrieve lost Dell Latitude password with the burned CD/DVD/USB.
In case we forget our Dell Latitude password or need to remove or break password on Dell Latitude, the above three methods may make sure that we get out of Latitude password reset problem easily and quickly!
Source: http://windowspasswordrecovery.net/article/dell-latitude-password-reset.html
on May 25, 2011 | Computers & Internet
Tip
I cannot access my Verizon mail _ Verizon.net server responded: Authentication...
Hi.
The following tip applies to users that want to access Verizon mail using an e-mail managing software as for example Outlook, Outlook Express, Eudora and similar.
The checkup procedure and server settings can also be used to setup your verizon email on a mobile or on a PDA.
If the Verizon server responded: Authentication failed, that means that either your ID, or your password had not been recognized.
Ensure that Caps Lock is not on.
ID and password are case sensitive, ensure that you use capitals only if needed.
Ensure that you entered the right user ID and password for your mail.
The ID must be your Verizon email address, or the first part of the Verizon email address (before @ sign). Password must be your Verizon email password.
If for example the address is MyMail@verizon.net , then try first putting id MyMail@verizon.net , if that does not work, try again with MyMail as ID.
The format that is supposed to work on Verizon is MyMail@verizon.net.
Ensure that the server settings you are using are correct:
1. Incoming mail server (POP3) - incoming.verizon.net.
2. Outgoing mail server (SMTP) - outgoing.verizon.net.
Ensure that you have not set the Log on using Secure Password Authentication (SPA)
Ensure that ports are POP3 PORT: 110. SMTP PORT: 25
Turn off any active firewall or security software. Also ensure that your router is not blocking port 110 (for POP server) or port 25 (for SMTP).
If all that does not work, then there may be an issue that depends on Verizon server. Also try calling Verizon online to find out if there is any additional issue that can affect your account.
Regards.
on Mar 12, 2010 | Microsoft Office Outlook 2007 for PC
JKrywult@Verizon.Net
You should not post your account details here.
Something is wrong with your login. Try clicking the link for "forgot my password", and see if that gives you something helpful. If not try this
http://www.verizon.com/support/residential/contact-us/index.htm
Jan 25, 2014 | Computers & Internet
Changed e-mail address from ginny@mminternet.com to vsuiters@verizon.net. Forgot what password is
go to www.paypal.com and click on "problem with login?" then follow the instructions.
Jun 02, 2011 | PayPal Accounts
I received a security alert this morning from a verizon.net address threatening closure if I do not give login details. is this genuine?
Hello and thank you for using Fixya's services.
No, this is not genuine. No services would ever ask you for passwords or login information (this is stated in the privacy policy). You should foward the email to customer support via their website so they can catch the one whom sent it to you.
Hope this helps!
Nov 23, 2009 | Yahoo Mail
Since our switch to FIOS we are unable to email from the machine. The log says "invalid from address" but this didn't change during the conversion. Any thoughts?
You probably are using a POP3 mail client like outlook or incredimail or the like.
You'll need to change the profile IN that mail client. Relatively simple to do. The information is INCOMING.VERIZON.NET and OUTGOING.VERIZON.NET.
If you had DSL service with them previously then it may be that your screenname was NOT scrubbed across into the FIOS network. In this case you'll need to contact the tech support people (good luck) and ask them to scrub your old id across.
To check to see if the s/n (screenname) was deleted. Go to verizon.net and attempt to login there. If your e-mail pops up then your s/n exists and it's merely the pop3 mail client settings that are botched.
Lemme know.
Jul 17, 2009 | Toshiba (GM1030) for E-Studio 200L Print...
Ihave had an email account on Verizon.net on my Horrible Dell Inspiron 1501. I have opened a Gmail account on google. Google claims I can move everything over from Verizon-I have tried all their...
there are several pieces here. gmail can use "pop" access to try to retreive your verizon email by pretenting to be a mail program, logging on ( you give it your sign on info) and downloading all your mail. you need your exact log in name, passwrd, and pop server from verizon. some internet companies have started to encrypt all their customer email to make it safer. you may need to check "use SSL" at gmail.com to make sure it has all the login info needed to retreive your verizon email. make sure you dont have a popup blocker when you access gmail so the interface loads properly.
i,e, see
http://lifehacker.com/376367/consolidate-multiple-email-addresses-with-gmail
Jan 31, 2009 | Computers & Internet
Computers & Internet Logo
16 people viewed this question
David Payne
David Payne
