Aquadyne pool controls
Radio control remote shows power but won't turn lights off
robotek
  • 1512 Answers
SOURCE: Need radio shack remote control code.
It will be one of these codes.
Orion 0236, 0463, 1463
http://www.remotecentral.com/cgi-bin/files/rcfiles.cgi?area=other&db=devices&br=radioshack&dv=universalremote&md=1521473in1easytouse&kw=&st=&ar=&dt=&so=&pg=3&file=others/radio_shack/152147-manual.zip
you can go to the manual direct at. Good luck
Posted on Jan 29, 2008
PartsCenter
  • 125 Answers
SOURCE: Jandy Aqualink RS4 controller won't turn lights on/off
AquaLink Trouble shooting guide
Posted on Feb 26, 2009
SOURCE: my X10 Pro pool lighting controller worked for a while, then quit
Most likely the pool motor or other devices are making the powerline noisy. I suggest either getting an x 10 tester or unpluggin hosehold devices until you find teh source of the noise.
Stephen Lerouge
Home Automation Inc,
Southwest territory Manager
Posted on Mar 21, 2009
  • 10865 Answers
SOURCE: Remote won't control the TV
Time warner will swap you for anew one. Call them and find out where to take yours for a swap.
Posted on Apr 11, 2009
SOURCE: Lights flicker when turned off by remote
I had this same problem with a Hampton Bay fan with a remote light switch. I call the manufacturer of the of the switch and was told that the model switch I had would not work correctly with CFL bulbs. The problem is with the dimmer function. You either need to change the bulbs to incandescent, or change the remote receiver in the ceiling. Hampton Bay was kind enough to send me a new receiver that works with CFL. The CFL units are white, and the incandescent is black. Hope this helps you.
Posted on Nov 20, 2009
Value position to heat pool
turn the valves so ALL the water goes through the heater and back to the pool
Apr 17, 2014 | Hayward Pool Products Pool & Spa
You can as long as you don't exceed the power specs for the controller.
Aug 04, 2013 | Hayward Pool Products Pool & Spa
Remote control won't turn on radio
Have been to the audiovox home Page type in your model number and go to trouble shooting there you will find how to program the remote back to factory settings
Nov 16, 2012 | Audiovox Xpress R XM Satellite Radio...
My remote control for my lg flat screen tv not working i changed the batteries and the light won't go on
Take the remote to any working radio, change radio band to SW, press various buttons of the remote and if you can listen to some clicking noise on the radio, the remote is ok. The problem might then be on the sensor and might need attention by a qualified service technician. You can also try switching off the TV, removing the plug and retry after 48 hours.
Aug 02, 2012 | LG Televison & Video
My RCA Truflat T.V won't turn on and the FPA lock is turned on, I have the original remote. what should i do?
TV won't turn on • Press the TV button. Make sure the TV is plugged in.• Check the wall receptacle (or extension cord) to make sure it is "live" by plugging in something else.• Something might be wrong with your remote control. Press the POWER button on the front of the TV. If the TV turns on, check the remote control solutions on page 26.• The front panel controls may be locked (disabled). Use the remote control to unlock the front panel controls by selecting the Lock Fr. Panel in the PARENTAL CONTROL menu and press OK (box won't have check mark).Buttons don't work
• If you're using the remote control, press the TV button first to make sure the remote is in TV mode.• The front panel controls may be locked (disabled). Use the remote control to unlock the front panel controls by selecting the Lock Fr. Panel in the PARENTAL CONTROL menu and press OK (box won't have check mark).• Unplug the TV for two minutes and then plug it back in. Turn the TV on and try again.TV turns off unexpectedly • Sleep timer might have been activated. Go to page 24 for instructions.• KidPass might have been activated. Go to page 21 for instructions.• Wake-Up timer turned on the TV and no remote or front panel buttons were pressed for two hours.• Electronic protection circuit may have been activated because of a power surge. Wait 30 seconds and then
turn on again. If this happens frequently, the voltage in your house may be abnormally high or low.
• Unplug TV. Wait five minutes. Plug it in again.
Sep 16, 2011 | RCA 20F420T 20" TV
My ceiling fan/light goes on when I am not in the room. The remote is on the bureau. I sometimes put the remote in another room but the fan/light still goes on. Model 327185-060
The simple solution is to turn the wall switch OFF when, the fan is not in use. I really don't think the remote alone is the culprit. Because, you say it happens even when it's in the bureau or in another room. Remote controls for ceiling fans have a very short range and are generally infrared remotes, rather than radio frequency remotes. So, if the infrared signal does not reach the receiver's sensor in the fan, it won't function. If it's a radio frequency remote control, do you have any other remote controlled fans in the house? If so, does the suspect fan seem to turn ON after you have activated the other fan? If that happens, it means both remote controls are on the same frequency. Changing the frequency of one, should solve the problem. See your Owner's Manual for directions on how to reprogram the frequency codes.
If none of the above solves the problem, maybe you should contact the "Ghost Hunters" TV show.
Hope this helped you troubleshoot and solve the problem. Thanks for choosing FixYa.
Jul 23, 2011 | Hunter Heating & Cooling
My Toshiba flat screen won't turn on with the remote control. There's a red light showing but no reaction. I have checked the batteries and put in new ones, definitely the right way round. Is...
Can you turn the TV usin g the power switch on the TV?
Testing remote control:
The remote control puts out IR (InfraRed) signal that human eyes cannot see, to find out if the remote is sending out the signal or not you just point the remote at the digital camera's Lens (Digital Camera can detect IR), you should see flashing light on the camera's screen when any one of the remote button is pushed. If you do see the flashing on the camera, then the problem is in the TV IR receiver or the main logic board; more troubleshooting with scope will be needed to look at the signals.
Parts: www.shopjimmy.com
www.remotes.com
http://www.remotecontrolscenter.com
http://www.newremotecontrol.com/
http://www.replacementremotes.com
http://www.newtvremotes.com
http://www.everytvremote.com/
Jul 01, 2011 | Toshiba Televison & Video
I have an aqualink RS8, which controls the on/off timing of the pool/spa, fountain feature, solar heater and yard lights. 1 - the display reads "6520 rev hh" 2 - the spa has been turning on by...
first disconnect the spa side remote if they go away replace the spa side remote if they don't go away go to system setup and go to programs either cancel if all button or delete or edit if one touch or PDA
May 25, 2011 | Jandy Aqualink Rs4 One Touch Control...
Televison & Video Logo
100 people viewed this question
Top Televison & Video Experts
