Question about Nintendo DS Lite Console
Clicking D-Pad I let my brother borrow my DS Lite, and since I got it back it's been making an unusually loud clicking noise whenever I press left on the D-Pad. Is there anything I can do to fix it?
  • 85 Answers
If you can take it apart and clean it. something may have gotten stuck in the d pad. the worst thing is that you will have to send it in to fix it.
Posted on Aug 10, 2007
My Jandy lite 2 natural gas heater has a loud clicking noise. It fires up and heats my pool nicely. My problem is.... as it is heating there is a loud clicking noise from the gas valve area. It acts a
I would suspect that it is not the valve making the noise. I would bet it is the thermal expansion of the metal that you are hearing. Other than that, I have seen cases where there is a flow control valve, and depending on its operation, when it opens or closes on spring power it will over shoot and make a loud clicking noise as the clutch overshoots. This will usually only be about 2-4 clicks though, and around pool equipment I doubt you would hear much of it. I would bet more on the thermal expansion. Kind of like the clicking noise you will hear after you have parked your car and the engine is cooling down.
Apr 10, 2013 | Jandy Laars Lite 2 Pool Heater 250,000 BTU...
make sure pressure switch is good and wires are tight sounds like pressure switch cutting in and out opening and closing gas valve also make sure wires to gas valve are tight
When I go to print or copy the machine makes a loud clicking noise and then says paper jam. Brother MFC - 8460 N
The loud clicking noise is either the toner cartridge or the paper feed. If the jam occurs in the drum and toner cartridge then I recommend changing the toner.
If the paper is not being fed at all then you need to have the paper feed kit replaced.
Thanks,
Pat
May 11, 2010 | Brother IntelliFax-2820 Laser Fax
Loud clicking noise from dash whenever heat
I have and 2002 with rear air and had the same noise and problem in the back. There is motor in the back that moves a flapper door open and closed to blend the hot and cold. The motor has plastic gears in it and they strip out making a clicking noise when the motor cannot hit the point that the heat control dial is being set too. Probably the same set under the front dash. You will more than likely need to by a new motor assy.
Mar 27, 2010 | 2003 Ford Explorer
My MFC8460N Brother won't print. It makes this
Gears on the tray is broken, or the gears that lift the tray. (thus the clicking noise). And the no paper is due to the actuators underneath not being activated because of the non lift.
Feb 12, 2010 | Brother MFC-8460N All-In-One Printer
Intermittent, random, loud popping noises.
you have a problem with your amp. most likley the finals are passing dcv intermitently to the load.
May 28, 2008 | Audio Players & Recorders
When in standby mode light flashing very fast and making a clicking noise
its most likely you might have put an option that does that you should take out yur gamecard and go to settings try to customize the settings if it doesn't work then i think you should get go to www.nintendo.com and get it repaired.
Rank My Solution
I tried :D
Apr 29, 2008 | Nintendo DS Lite Console
you should check the outline ctrl..for a mic...it could produce a noise...if you have your speakers connected to pc...check the position of the plugs and the volumen of mic put in down...
Nov 24, 2007 | RCA RT2760 System
Nintendo DS Lite Console Logo
95 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Zhenya Ogorodnikov
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
