Question about Sierra Wireless MP 555 Modem
Connecting when i push the connect button i get a valadating profile error
    Problem Solver:
  • 14 Answers
Re: connecting
--Are you using a connection that requires Authentication. --That means :- do ur connection requires a username/password --If it requires a username/password make sure that you are typing the correct one or else make it confirmed from your ISP B'coz the validating error indicates that you are missing out some info that you are updating in the modem/router
Posted on Aug 10, 2007
0 characters
3 Points
Wps light blinking
wi-Fi Protected Setup (WPS) is a standard for easy and secure wireless network set up and connections. Some of NETGEAR's products use the name Push 'n' Connect for WPS. To use WPS, your product must support WPS and be compatible with WPA security. WPS can automatically set up a random network name (SSID) and strong WPA wireless security for wireless routers, access points, computers, adapters, Wi-Fi phones, and other electronic devices. WPS lets you use a push button or enter a personal identification number (PIN) instead of manually entering a network name (SSID) and password:
  • Push button. The WPS button is either on the product or a clickable button on a wizard or utility screen.
Jan 22, 2013 | Netopia Motorola 2247-n8 Wireless Dsl...
TCP error 1001
This indicates an ip connection error.
Unplug the terminal. Wait 5 seconds. Plug back in.
After it reboots you will see two or more menu options. Select CommServer (instead of Credit/Debit) by pressing the function key beside it.
Select Troubleshoot to allow it run through the diagnostics. Push the purple button below "Print" to print the results.
Now select Repair by pushing the function key next to it. After the repair routine has run, press * on the keypad to return to the main menu.
Select Credit/Debit and then try swiping a card and performing a transaction. This hopefully will solve the problem for you. If not, call your merchant services provider's tech support and share the error message and tell them you printed the troubleshooting diagnostics report and they should be able to assist further.
Nov 12, 2012 | VeriFone Vx 570 Dual Comm Credit Card...
Verifone Vx570 given an error Modem Profile Not Set?
error modem profile not set appears when your Verifone VX 570 modem profile is not properly loaded or has been errased due to Tamper error or Bad RTC. Reloading back the modem profile will sometimes fix the error, but there is also a chance that your I/O module (form where you connect the power and telephone wire) is also bad, thats needs to be repaired or replaced. Call (775)358-2922 ask for Randy. Thanks.
Backside of the I/O module of VX 570
Jan 18, 2012 | VeriFone VX570 Credit Card Terminal (Dual...
Drivers for mmx 352g usb modem on windows xp/32bit
The software u are using might be out date,tries to upgrade the latest version of the software.Or the modem u are using might not be compatible with the Window 7 software.U might have to replaced and upgrade the modem itseft.
Oct 27, 2011 | Modems
Sir MMX 310G 3G usb modem, when i was connected, the message shows only "dial failed". My profile setting is right, but what's the problem.Please solve the problem. Connection Profile...
there would be some software problem.......... please reinstall the software and use your device......... dont forget to vote for me...........
Apr 04, 2011 | Modems
Shows error633
When you try to use your modem on a Windows computer, you may receive an error message similar to the following: Error 633 Modem is already in use, or is not configured for Remote Access dial out or The port is in use.
Try this one after the other
1. Verify no other applications that are using the modem. You can open Task Manager to check that by press CTRL+ALT+DEL. Another way to test it is reboot the computer.
2. This behavior may occur when another device with a driver, for example outdated Palm Pilot software, conflicts with the modem.
3. Telephone.ini or unimdm.tsp is missing or damaged.
4. Make sure the modem is setup correctly and may apply SP.
5. Removing and reinstalling it, or apply the new drive may fix the problem.
6. Make sure no two ISDN installed on the same machine and attempt to connect to the same server.
Apr 01, 2010 | Conexant All 56K Modems: Amigo V.92...
Help about lg ku 250 and vista
Using LG KU250 as a modem in VISTAMake sure that you are connected to internet.
First connect the ku250 in data service mode and connect it to computer.
Let the computer to search the driver and download and install drivers.
Right click LG PC SUITE setup select properties and select windows xp sp2 compatiblitiy mode.
The Run the setup as Administrator by right clicking the setup,
After installation there will be a error "Unable to find wdfusbus.inf".
Ignore it.
Run the PC Suite.
Close the connection wizard because it cannot detect the phone.
Select internet kit from file menu.
Click setting and create a profile and enter your settings.
Click Connect.
After you have connected there is a Set "Network Location" Window.Close it.
There will be a small error message Disconnect.
Open the browser and surf the internet.
Click disconnect after you have done.
Jun 08, 2008 | Modems
Fixing my connection
your new connection which will be set as the default can be found with you old connection whicj will notin
Tools///Internet Options///Connections ......choose your old connection by clicking on it then push the button "Set as default"
Feb 24, 2008 | Modems
Motorola sb5100 surfboard - ps3
Have you rebooted your modem after hooking it up? Each time you move your connection from your modem, it must be rebooted to issue new information specific to your equipment. Also, make sure you haven't pushed the "Standby" button on the top.
Feb 19, 2008 | Arris SB5100 SURFboard DOCSIS 2.0 Cable...
Error message during installation of SBG 900
Please check if your modem and change the config to static IP.
Sep 03, 2007 | Arris SURFboard SBG900 (49402201900) Modem
Sierra Wireless MP 555 Modem Logo
101 people viewed this question
Top Sierra Wireless Modems Experts
Brett Duxbury
Brett Duxbury
Are you a Sierra Wireless Modem Expert? Answer questions, earn points and help others
