Remove old unused thermostat from wall and parch
The remote i cant get it open without breaking it all i want to do is change the batteries
Please switch off power.
1.Remove cover from old Thermostat. If it it doesn't snap off when firmly pulled from the bottom,check for a screw that locks cover on.
2 Loosen screws holding thermostat sub-base wall plate or wall and lift away.
Dec 09, 2010 | Heating & Cooling
Trying to remove an old t87f2873 with heat-cool subbase from wall. which screws do you loosen to do this.
There should be three small slotted screws at 9 o'clock, 2 and 5. This will remove the thermostat. There will be two screws holding the subbase on the wall.
Feb 01, 2010 | Honeywell Heating & Cooling
Parches para flasheo sony ericson w200
What kind of patches are you looking for?
unlock patch?
debloquear?
Jan 10, 2010 | Sony Ericsson W200i Cellular Phone
What is easy way to replace the thermostate in
Hi, that thermostat should be a wall mount. This heater has only 2 wires and any "Heat only", "millivolt" thermostat will work. Remove the old T-Stat and mount the new one on the wall, only 2 wires and less than a volt so no shock danger, doesn't even matter which wire goes where. Good luck and comment back if you need any help.
Jan 09, 2010 | Cozy Heating & Cooling
Programmable thermostat
I am unsure of your question, but if you are just replacing your old thermostat with a new one, then connect the red wire to the Rh or R terminal and the white wire to the W terminal on the thermostat. Hope this helps
Jan 09, 2010 | Honeywell Electronic Programmable...
Have dayton model 2e215 mercury thermostat and trying to replace with programmable. How do I get the old one off of the wall. It looks like the mercury vial sits on a cover over the wires but I cant see...
There are either 2 or 3 small screws which hold the thermostat to the wall plate.
Remove these and the thermostat will come off to reveal the wall plate with the wiring connections.
Sep 06, 2009 | Heating & Cooling
Need to relace thermostat on kitchen aid wine cooler kuws246ebl2
Hi, The silver thing is not a wire. It is the sensor tube for the thermostat. The new thermostat will come with the sensor. Be sure and notice how and where the sensor goes in the wall. I hope this helps
Vic
May 20, 2009 | Refrigerators
Replacing a non-programable thermostat for electric baseboard heater with model CT410B. This is a 4 wire thermostat replacement for a previous 2 wire. Directions indicate that I can do this. I connect...
If you take thermostrat back off and connect the wires together will baseboard heater get hot. If not you may have bad heater. If it gets hot your new tstat may be bad. The way you have it wired is correct. Most line voltage tstats have a ground screw. Your 's may not but will work without one .
Jan 23, 2009 | Heating & Cooling
I bought a nokia 6233 mobile phone some days it is working correctly but suddenly i was blocked because it is blocked by pta what can i do to unlock this mobile phone is there any solution
hi sir,
are you parches a new cell phone
are you parches a second hand r used
if you parched a new then you need to contact to the company,
if you have parches a used cell you should be cont- were you parches it
possible it is a stolen cell phone
don,t west your time do it
thaknx for useing fixyha
Dec 15, 2008 | Cell Phones
How do i uninstall my old honeywell mercury thermostat
There are three parts to a T87F thermostat. Outer ring, thermostat body, and base mount. Remove the snap on ring that goes around the dial. Remove three screws from the thermostat that mount it to its base. Remove the thermostat. Disconnect and record what screws each wire attaches to. Remove the screws holding the base to the wall.
Jul 12, 2008 | Honeywell Heating & Cooling
Heating & Cooling Logo
55 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
