Question about Coffee Makers & Espresso Machines
Krups ea8005 Clean light and on button flashes, I don't know that to do in order to stop the clean light turn off. Coffee is impossible to make in this condition, steam also doesn't work.
  • 2039 Answers
SOURCE: Cleaning and descaling Krups Orchestro 889
take a descaler solution never mind vinegar not strong enought 1part solution 1part water put that in our water container start the machine open valve let it drip for a few second untill you see the solution leave it like that for 10 minute after open the valve and do it again untill emty after you emty the solution clean water container very good fill it with water open the valve rinse very good because that solution is very corosif enjoy cheers
Posted on Jan 19, 2008
SOURCE: Krups XP7240 leaks
The grind selector knob can be removed with the following steps: 1) Remove screw on side near grinder (do not let the screw fall into grinder, :-) ), 2) use sharp knife or similar to pry off cover with three dots. This should be easy. 3) Now you can rotate the grind selector and see that the white clear plastic does not rotate and the black does. There are two little pieces (one black, one clear plastic) on opposite side from grinder that slide over eavh other to keep this knob 'locked' into place. 4) again with a sharp pointed knife or similar you can separate these two pieces to 'unlock' them. This is made easier by lifting the side of the bean holder by the grinder gently and tipping it up. Be careful not to force anything too much. The black part should pop off. 5) Now you can lift off the clear bean holder.
After this good luck. We made it farther into the machine, but could never get to where we needed to go to fix our problem.
Krups must be congratulated for designing a machine that cannot be repaired and must be replaced with new purchases.
Posted on Jan 11, 2009
SOURCE: ge coffee pot model number 169165 clean mode botton wont shut off
fyi - manual is at
http://www.gehousewares.com/Browse_Product.aspx?content_id=332
Posted on Mar 05, 2009
  • 85 Answers
SOURCE: self clean light keeps blinking
Hello guindonlm,
I recently had this similar problem. Try the following.
Your described problem may be one of two problems. Let's start with the easier solution first. In the DCC 1200 there is a filter "stick or column" in the left rear. Pull it out and remove the clogged carbon filter(s) that are in there. Shine a light into the receptacle and remove the debris in the bottom. It is likely that this is causing the problem with you machine needing to be started on multiple times. See if this solution works. If it does, you might run 8 cups of water and 4 cups of vinegar through to help decalcify the units plumbing. Do this once or twice and then rinse with at least one pot run-through of clean water. If this works then you are good to go.
Next, if this does not solve your problem we can do the following: unplug the unit and lay it on its back. You will need a #10 torx driver (hardware store if you don't have one) to remove the bottom cover plate. There are 4 torx screws holding it on. When removed, you will find 2 orange hoses. Carefully attempt to remove the left hose without splitting. I used a eyeglas screwdriver to loosen it up. If it splits, just cut off the split and stretch it to reconnect when time comes. As you look into the hose you will find a little black valve inside as well a some gunk. Clean it all out with a fine wire as best you can. Rinse well. Attempt to reconnect the hose back onto the pipe. Slip the pipe clamp back into place. Replace the cover and screws and you should be good to go again. This is not as daunting as it may seem. You can do it. :o) Good luck! If this answer helps, please leave positive feedback for me. Much appreciated. Regards, NormanZ
Posted on Jul 08, 2009
SOURCE: The cleaning button keeps flashing after cleaning.
We have this problem as well. We simply clean it as directed once or twice with the vinegar and water mix and then unplug for an hour. This resets our machine for several weeks. Based on the number of comments I've seen on this issue, it seems that the "off" sensor doesn't work.
Posted on Oct 13, 2009
My orchestro 889 espresso machine light are flashing power cleaning
I have been through the book and it gives no information on flashing power and clean light together. Quite often a full dismantle, clean and lubrication of the brewing unit will make things better when they are acting incorrectly.
Oct 01, 2014 | Krups Orchestro 889 Espresso Machine
Grinder in Krups Espresseria EA8000 stops and whirrs.
Hi, i had similar problem on my Krups. Inner star plastic part which remove powdered coffee is maybe damaged. You need to replace or overhaul your grinder or you can replace inner star plastic part by yourself. Coffee grinder spare repair part plastic inner star Krups Mhle...
Feb 11, 2014 | Coffee Makers & Espresso Machines
GVX2 krups coffee grinder; how to open it?
I have the same issue. You need to take both dials off, then on the bottom, there are 4 tabs on the inside. Seperate the halves and you will see them. Towards the front and halfway back. Pry the halves apart enough to push the top towards the bottom and it slides apart pretty easy. The tricky part now is finding the replacement part. I have super glued my switch and I want to do something to try and repair it further. Maybe epoxy. I called Krups and they can't sell the part to me. I called one of their service centers and they can't sell the part to me. So, if someone knows where to get the part, I am all ears :)
Nov 25, 2008 | Krups Burr Coffee Grinder
I have a Krups Orchestro Model 889 which hasn't been used in a while. Now when I use it, the grinder works and the steamer works but nothing pours into the cup when I activate the machine. I think its an...
I had the same problem with my Krups Orchestro and today picked it up from service. There was nothing wrong except the internal filter was blocked and a manual clean by the technician fixed it. I think I exacerbated the problem by going to the finest grind over time the amount of liquid to the cup got less and less till it stopped.
Now I am using a courser grind - hopefully this will delay the onset of the problem. I was going to try a clean myself - but was deterred by the security oval head screws on the back. The repair centre told me they thought the Krups machine was a great product - and that I should expect many more years. It is essential though to perform maintenance (clean especially) as soon as prompted.
Jul 10, 2008 | Krups Orchestro 889 Espresso Machine
Self Cleaning feature
I copy pasted from the pdf..
Christian.
Self Cleaning:
If the Self Clean light begins to flash when
the coffeemaker is turned on, it is telling you
that the calcium buildup is interfering with the
functioning of your coffeemaker and the flavor
of your coffee. To clean, fill the water reservoir
to capacity with a mixture of 1/3 white vinegar
and 2/3 water. Press the Self Clean button.
When the self clean light glows, turn the
coffeemaker on by pressing the flip switch to
ON. The Self Clean light will shine steadily.
The coffeemaker is now in Self Clean mode.
One cycle should be sufficient to adequately
clean the coffeemaker. When the cycle is
completed and the five beeps sound, the coffeemaker
will shut off. Turn the coffeemaker
ON to see if the Self Clean light continues to
flash. If it does, turn it to OFF and then repeat
the cleaning procedure with a fresh solution of
vinegar and water.
If the Self Clean light no longer flashes, turn
the coffeemaker to OFF and then run one
cycle of fresh cold water through the unit
before using the unit again to brew coffee.
Notes on the Self Clean Function
Pressing the Self Clean button cancels all
other settings. If it is pressed accidentally,
press it again to return the coffeemaker to all
its previous settings. Pressing ON/OFF will
also exit the Self Clean Mode and turn the
coffeemaker OFF.
Feb 03, 2008 | Cuisinart DCC-1200 Coffee Maker
Krups ProAroma Type 314
Thermal fuse gets stuck, gently take it apart and reverse the thermal button over, clean the rust under the button
Oct 07, 2007 | Krups ProAroma 453-71 Coffee Maker
Coffee Makers & Espresso Machines Logo
119 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
