Question about Fuji FinePix S3000 Digital Camera
USB error message
Just recenbtly I tried to upload some pictures, which I have done successfully with the camera for 18 months, and I got a message on my pc saying there was a power surge on the USB port and that it could not support that amount of power. I bought a new USB cable but have the same message so I assume it must be the camera..has anyone had this problem? Thanks
    President:
  • 1,114 Answers
Have you connected any other USB devices to your PC? The USB ports can only supply a small amount of power and some devices especially USB connected hard drives consume more power than it can provide so they usually have an external power supply. Remove any other USB devices & try again. Did you have your camera connected before with a power adapter? Are you camera batteries fully charged? Let us know how you get on...
Posted on Aug 09, 2007
SOURCE:
Error message "unknown error has occurred"
how to transfer picturesd from digital camera to pc just watch video
Jan 07, 2009 | Sony Cyber-shot DSC-N2 Digital Camera
Pictur download to computer
maybe u have defective usb cable if u r using usb cable..try to upload ur pictures from ur memory card by using card reader...
Jul 10, 2008 | Canon EOS 400D / Rebel XTi Digital Camera...
D80 ERR & CHR message
Hello Michaela1,
There are a few things I can recommend:
1. Please check your card on some other camera to make sure the media is alright.
2. I am not sure if you take the SD card out of the camera and put it into a card reader (stand alone, in your laptop/PC) to read the images. As I understand, you first took out the card and then put it back into the camera to read from the camera once it did not work in the card reader. However, there are issues with doing both. I will outline them below.
  • Card Reader: At times, reading a card in a card reader will mess it up and it will remain unusable in the camera even if it displays photographs on camera LCD. Please note, this will happen even if you have only viewed the photographs on your computer and not saved them to your hard drive/media. The card will most definitely not work in camera if you delete photographs from the card or edit them on the card. The only solution to this is to format that card IN the Camera. The manual has instructions for the same.
  • In Camera: Other times, you may have connected the camera through the USB cable to a computer with the card in the camera. This problem may crop up IF you used your computer to delete images from the card whilst it was IN the camera. Again, the solution is to format the card. IN the camera, not from the PC.
3. Whether you use the USB cable or take out the card and put it into a card reader to save your photographs, always repeat ALWAYS format your card in the camera after transferring your photographs. This ensures card will not malfunction unless the media is corrupt. This also has the added benefit of not having the same photographs a few times over.
4. Try not to leave your images in the card after taking photographs. Try to save them to your PC at the earliest opportunity. Format after-wards (I can not repeat this point enough).
5. Use multiple cards of smaller capacity. They are cheaper to buy. Even if you lose one card to a mal-function, you still have photographs on others.
I hope this helps.
Satdeep
May 31, 2008 | Nikon D80 Digital Camera with 18-200mm...
Uploading pictures to my computer
Hi , in uploading picture let camera on ,plug usb , detection come in screen message , et camera button ignore it / click set camera ,select upload to camera, selection of pictures then okey.
Nov 02, 2007 | Fuji FinePix S3000 Digital Camera
Cannot Upload Pictures from Camera
Have you tried a memory card reader?
What software are you using? I would try Nikon View. If this is what you are using, make sure you haven't set some of the options in the download window, as you can choose to download only photos within a certain a date range, or photos with cetrain attributes. You get an error message somewhat similar to the one you describe if you've set these options and no pictures match them.
Nov 01, 2006 | Nikon COOLPIX Cameras
Fuji FinePix S3000 Digital Camera Logo
73 people viewed this question
Top Fuji Cameras Experts
Ekse
Steven Wander
Steven Wander
Azam Ali
Level 1 Expert
Are you a Fuji Camera Expert? Answer questions, earn points and help others
