Question about Fogel FOG-FLP4512 Undercounter Sandwich Prep Table 12 cuft
I looking for thermostat - Fogel FOG-FLP4512 Undercounter Sandwich Prep Table 12 cuft
Thermostat Replacement
If you look the model/part number of that thermostat you're looking for on the internet, you should be able to find a PDF file of the owners manual to look at the wire diagrams and it will also let you know if the thermostat is compatible with your current set up with the oil heating and central a/c w/3 zones. RC & RH should be explained in the thermostat manual if the new thermostat wiring has been reconfigured to accommodate your setup. Hope this helps.
Mar 05, 2014 | Honeywell RTH8580WF1007 7Day Touch...
Tip
How do I locate my thermostat?
In most cases, not all, follow the upper radiator hose to the engine. The hose clamp on the end is usually clamped to the thermostat housing (sometimes there's a metal tube, and another rubber hose, then the housing). Drain the coolant through the petcock valve on the radiator,or place a large pan under the vehicle to catch what escapes. It's usually easier to remove the hose from the thermostat housing (Get a flashlight and look inside, but make sure the engine is cooled off). If you can see the thermostat, then remove the housing. (put the thermostat back in the way it came out. Pointy end towards the radiator.) Clean off the old gasket from both surfaces, install the new thermostat, apply the new gasket. Reverse the procedure and top off with coolant.
Search under "images" and type in "thermostat" if you're not sure what it looks like. You'll be looking for the end with the point.
Easiest way for me to change my cars thermostat.
on Feb 27, 2010 | Chevrolet Blazer Cars & Trucks
Trying to locate the thermostat
If you trace your upper radiator hose to the engine, you will find where the hose connects to your engine with a clamp. Remove this clamp and take this end of the hose and move out of the way. If you look at where the hose went, inside the large hole, you may actually see the thermostat. What you are looking at is the thermostat housing. Remove the thermostat housing and then the thermostat will come out. It may be stuck in place, and you might have to pry it out. I will give you a few pictures to show you what your looking for.
Dec 06, 2013 | Cars & Trucks
Changed water pump,thermostat, top rad. hose. still leaking leaking antifreeze from what looks like below thermostat housing. have noticed super small hose from water pump to engine. looks hard to replace....
That is called the bypass hose. It could be leaking but I'd take a closer look at the thermostat housing. If you replaced only the thermostat and not the housing, the housing may be leaking. It's a common source of coolant leaks.
Apr 16, 2011 | 2000 Dodge Ram 1500 Truck
With fresh batteries, the thermostat works fine, but after two or three days, the thermostat fails to turn on the furnance after the temp drops below the setting. Replace the batteries, and it works for a...
If you have a spare wire (unused) in the thermostat wire sheath you can eliminate the batteries as the power source.
Turn off the power to the furnace.
Open the thermostat and look for terminal "C". If it is not being used,then
look inside the furnace for the thermostat wire terminals. Black or blue are probably not being used. Take one of these wires and strip insulation back 1/2 inch. Connect this wire to the COMMON (C)(-)wires from the low voltage transformer.
Open the thermostat and connect the same wire to the "C" terminal on the thermostat.
Dec 22, 2009 | Honeywell Programmable Thermostat Heater
Looking to replace a thermostat on a 87 Grand AM all I can see is a hose clamp going into engine and no gasget came with the Thermostat, they said there wasn't one needed. I'm lost
When you actually get the thermostat housing off you should see a "o" ring there and no gasket,if it has no tears in it then go ahead and make the swap,if it does the replace it.
Dec 08, 2009 | 1987 Pontiac Grand Am
Location of engine thermostat
It is located on thetop front of the engine. Look for a radiator hose running to the engine block. You will see a housing which the hose connects to. It will look similar to this. Remove the 3 bolts and lift the housing and you will find the thermostat.
Thermostat housing
Thermostat
Nov 28, 2009 | 1993 Oldsmobile Cutlass Ciera
Honeywell thermostat won't regulate temp properly
check to differential setting in the thermostat and are you saying the temp in the room and the set temp is being read from the thermostat or is there another thermometer in the room your looking at
Jun 25, 2009 | Honeywell Electronic Programmable...
Thermostat location on a 1999 cadillac deville concours
looked it up online and looks like it's on the front of the water pump in a thing called the coolant inlet housing. one end of it looks something like the letter y and the other end, where the thermostat is round. hope that helps
May 30, 2009 | 2000 Cadillac DeVille
Fogel FOG-FLP4512 Undercounter Sandwich Prep Table 12 cuft Logo
19 people viewed this question
Top Fogel Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Fogel Refrigerator Expert? Answer questions, earn points and help others
