Question about Whirlpool LHW0050PQ Front Load Washer
Washer will not drain, seems to be plugged
My washing machine is only a year old so i don't think it's the pump. Plus, when it's time for the spin cycle, i can feel the hose trying to pump something, but no water will drain. I've removed the back panel from the washer. Is there a safe, reasonable way i can remove the main black hose from the inside and clear it out? The build up seems to be in the elbow part of black hose coming right out the bottom of the drum.
I recently had the same problem.. There is a panel on the lower front right of the washer. I flipped open the panel door and removed the screw out plug. Make sure you have a floor drain at this point, as the water will come out when the plug is removed. This plug also contains a filter. It was plugged up with all sorts of debris... Lint, dryer sheets, rubber bands, a stick ect ect. I just cleaned the filter and plugged it back in. The washer worked normally after this. This is a simple thing to try before removing the back panel and drain hose to check for obstructions. The solution by jsrock516 would be the next logical solution. After that I would think that a faulty drain pump would be the problem. Hope this helps..
Posted on Sep 20, 2008
  • 5,911 Answers
Try using a wet/dry shop vac and see if you can pull water through the drain hose in the back. If you can, duct tape the vacuum nozzle to the drain hose to make a good seal. With the vacuum on, watch the drain hose under the tub. If it collapses, you have a clog somewhere. It may be easier to remove the hoses from the pump, first to see if there is anything stuck in the impeller. It doesn't take much to restrict water flow. If you need to remove the hose from the bottom of the tub, try to get as much water out using the method I mentioned. It may be slow, but as long as it can pull water, try to drain. This will save you from a big mess later. If there is a clog in the hose, all that water will gush out with the hose disconnected. You may want to have a few towels handy. Now...in some models there is a plastic ball valve in the drain hose connected under the tub. This needs to stay there, but may also be jammed with crud. Sand and dirt is notorious for clogging at this point in the drain system. This hose should come off with a simple clamp tightened with a screw. If you go through all the effort and find the lines clear, you may have a failed drain pump.
Posted on Aug 10, 2007
SOURCE:
Drum will not spin
did he run the diagnostics per the tech sheet within the machine?if it will do everything else but spin out,then the drain pump is plugged,as a plugged drain pump will shut down these front load units,you will need to remove hoses off pump and clean out pump and all hoses from tub to drain stand pipe,by running the diagnostics you can run each washer cycle and see what cycle isnt performing in a matter of 5 minutes versus 1 hour real wash time on some cycles
May 01, 2012 | Kenmore HE2 Plus Front Load Washer
HAV2360 Maytag does not drain before spinning. Drain cycle seems not to engage.
Unlike Whirlpol and Kenmore washers Maytag Washers drain and spin at the same time.
Apr 10, 2011 | Maytag HAV3460AWW Top Load Washer
Model - Maytag plus 2 speed. Will not spin everything else works. Machine ten years old
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Sep 08, 2010 | Maytag Washing Machines
I have a 4 year old Kemore HE2 that isn't spinning the water out of the clothes. I encountered this issue about a month ago and found a fix for cleaning out the hidden pump trap. After removing a large...
heatman101
Sep 07, 2010 | Kenmore HE2 Plus Front Load Washer
Washing machine will fill with water, but won't spin.
hi there.
If the washer won't drain or spin there might be a clogged pump or hose. It's common for small socks or other small clothing items to get into the water drain system and clog the hose leading to the pump or the pump itself. Remove the hoses from the pump in order to remove the article of clothing.16 Mar 2014
SOLVED: Why won't my washer spin or drain? - Kenmore 110 Series ...
or go to this link for more help.
Washing machine will fill with water but won spin Google Search
Nov 18, 2017 | Whirlpool 3.2 cu. ft. Plus Washer
Kenmore 70 Series Washing Machine Drains, But Won't Spin
Yes sir, a bad motor coupler could cause the machine not to spin. You did the right thing in checking out the lid switch and the pump first. It sounds as if the motor coupling is worn and may be slipping. I will attach a link to a video that may assist you. Hope this helps and best wishes.
http://www.youtube.com/watch?v=WLPGs2UMUJc
Aug 27, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Old Washer won't spin or agitate
You found a belt? Most w/p washer do not have a belt they are direct drive. take off the pump and motor to replace the motor coupling, 2 plastic pieces w/ a rubber in between
Feb 15, 2009 | Whirlpool Washing Machines
Cloths are still very heavy and wet
Sounds like a pump problem or a kinked drain hose. The machine cannot spin or spin properly until the pumps gets the water out of the tub.
Sometimes the drain hose get plugged or kinked and won't allow the water to be pumped out so make sure that is not an issue. But, I'm more inclined to believe this is a pump problem.
Dec 30, 2007 | Frigidaire ATF6000ES Front Load Washer
GE Top Load Washer 10 yrs. old, used for 3 years, stored after that
the water must drain out of the tank b4 it can spin make sure the pump is working ok
Nov 17, 2007 | GE WBSR3140DW Top Load Washer
Whirlpool LHW0050PQ Front Load Washer Logo
227 people viewed this question
Marvin
Marvin
Gerry Harvey
Gerry Harvey
jimorris77
