Question about Tilia FoodSaver V2240
Genesis Vacuum Sealer
I Bought a Genesis Vacuum sealer about 15 months back. ModelVPS201 from P&P Hypermarket, Fairy Glen Pretoria. I used the product about 4 times, now it only seals, no suction. Slip got lost. Please inform what can I do. Thanks
4 Suggested Answers
  • 87 Answers
SOURCE: My foodsaver Vac 420 Vacuum Sealer won't heat and
This is likely happening because the unit cannot detect that a vacuum has formed, and because of this, the unit will not seal the bags, with the gaskets around the vacuum channel being the probable culprit. The Foodsaver gaskets will deform and/or dry out with time, just like in any device, but you don't necessarily have to replace them. I've tried this inexpensive solution on my own Foodsaver V2490, and it works perfectly.
Buy some food-grade silicone grease and apply it to both the upper and lower gaskets. I remove the gaskets and coat both sides with a thin layer of grease before replacing them in their respective channels. And since this grease will be absorbed and/or dry out with time, you will have to do this occasionally, so I also flip the gaskets (i.e. turn them over) whenever I apply the grease.
You can buy a 2 oz container of silicone grease at any dive store, or you can buy it over the Internet by searching for "Trident silicone grease".
This is a link where you can buy it for around $7.00:
Dolphin Dive Center
I do not work at this dive center, but I am a scuba diver and already had some grease that I use for the numerous rubber gaskets in my gear. The 2 oz. jar will last you several years, and you will find many other uses for it around the house since the grease will last longer than a spray.
Posted on Aug 02, 2010
  • 87 Answers
SOURCE: Foodsaver Food Sealer Vacuum V2240 T: Foodsaver Professional II Turbo. Vacuum pump work...
This is likely happening because the unit cannot detect that a vacuum has formed, and as a result, the unit never "turns on" the heating element to seal the bag, with the gaskets around the vacuum channel being the probable culprit. The Foodsaver gaskets will deform and/or dry out with time, just like in any device, but you don't necessarily have to replace them. I've tried this inexpensive solution on my own Foodsaver V2490, and it works perfectly.
Dolphin Dive Center
  • 1739 Answers
SOURCE: I'm looking for a user
The Manual for your Tilia Foodsaver Food Sealer Vacuum V2240 is here:
http://www.foodsaver.com/Manuals/MANUALS/T000-32030_44_65900646.PDF
Posted on Apr 02, 2011
Cannot get it to vacuum.
Does it try to vacuum but never flattens the bag? Make sure the bag you are using is completely sealed on the opposite end. Otherwise, the seal on the sealer is probably allowing air to leak into the sealer. If it has a foam sealer, I've found it sometimes helps to run the foam sealer under water, squeeze out the excess water, reinsert the foam sealer (make sure it is seated all the way) and then try again to seal the bag.
Mar 07, 2016 | FoodSaver Food Saver Vacuum Sealer...
It won't vacuum. Why?
vacuum sealer won't pull vacuum - GardenWeb
forums.gardenweb.com > Garden Forums > Harvest
Nov 9, 2008 - I know many of you use vacuum sealers, so hope you might be able to help. I have a FoodSaver Pro Sport, it's probably about three years old.
How to fix Food Saver - Vacuum Sealer? - Instructables
www.instructables.com/.../How-to-fix-Food-Saver-Vacuum-...
InstructablesMar 2, 2012 - I have a Food Saver brand Vacuum Sealer, that all of a sudden stopped ... If it won't heat up to seal the bag, then you probably have a break in
vacuum sealers - Frequently Asked Questions
Feb 03, 2016 | Kitchen Appliances - Others
Door to my foodsaver is stuck on one side. It's shut. How can I release it? Is there a release button anywhere?
Trouble with Food Saver Brand - Survival Podcast
thesurvivalpodcast.com > ... > Food Preps > Processing Food For Storage
Aug 15, 2010 - 17 posts - ‎13 authors
We have been using our Food Saver Vacuum sealer we bought ... connects somehow got stuck open and therefore the bags would not ..... I've had the FoodSaver V3840 for about 10 months now and thus far it has been great.Missing: door
FoodSaver Repair - YouTube
? 8:22
https://www.youtube.com/watch?v=jguFiF0Rouw
May 21, 2014 - Uploaded by Kelly Kimble
Repair a FoodSaver that isn't drawing out air anymore. In this case, its ... Vacuum Sealer Troubleshooting - Duration: 10:25. katzcradul 52,345 views. 10:25 ... How to Food Saver Lemon Juice or Other Liquids - Duration: 4:56.
[PDF]Use and Care Manual - Home Depot
Jan 25, 2016 | FoodSaver Vacuum Food Sealer - V3840
After hands-free red light for sealing turns on, why does it take a long time to start sealing?
Seal-a-Meal FSSMSL0160-000 Vacuum Sealer - Amazon.com
www.amazon.com > ... > Vacuum Sealers
Amazon.com, Inc.Handy indicator lights for "Hands-Free" and "Sealing", plus Open/Cancel button. Keep your busy kitchen running smoothly with help from this easy-to-use Seal-a-Meal ... With its sleek, straightforward design, the compact appliance effectively ... After completing the vacuum sealing cycle, both the motor and the "Sealing" ...Missing: red
Amazon.com: Rival Vacuum Sealer: Kitchen & Dining
Amazon.com, Inc.
Rating: 3.6 - ‎233 reviews
Online Shopping for Kitchen Small Appliances from a great selection of ... Rival FSFGSL0150-015 3 Step Vacuum Sealer w/ Bag Starter Kit ... You push down....wait for Hands-Free light & Sealing light to go on....let go....wait for lights to turn off. ...After a couple of bags were done, I started having an issue in which the unit did ...Missing: red
Amazon.com: FoodSaver FSFRSH0051 FreshSaver ...
Dec 25, 2015 | Kitchen Appliances - Others
Why there say tray full red light
The tape trick didn't work for me. Had to cut the wires. Works for now.
Sep 27, 2012 | FoodSaver Smart Seal Vacuum Sealer V3825
Birth day gift 6 months ago. last took it out and use. vacuum motor is not working on the brand new machine?
Is it working at all or just no vacuum. Try blowing thru the device. I have used water to get mine going before thru the plastic hose coupling.
Nov 02, 2010 | Rival VS230 Seal A Meal Vacuum Food Sealer
Oil pan leak
buy a tube of sealer called Right Stuff
1. Remove the flexible exhaust pipe
2. Disconnect the downstream catalyst monitor sendor (OXYGEN SENSOR)
3. Drain engine oil
4. Remove the 15 bolts and the oil pan
5. Clean pan & surface area.
6. Apply sealer 10mm (0.40 inch) diameter of sealer
7. Position oil pan and hand-tighten the oil pan bolts
8. Start with front of oil pan tighten each bolts going around oil pan till all are tighten up.
9. Install exhaust flexible exhaust pipe
10. Connect OXYGEN SENSOR connector
11. Lower the vehicle.
12. Fill oil 5w20 (Spec)
Feb 10, 2010 | 2001 Ford Escape
How do I work a Salton vacuum bag sealer (Model BS-20)? I can not figure out how to get the air out of the bag.
This style of vacuum sealer has to use a special bag with a " dimpled " surface to let the air escape through the pinch jaws of the vacuum sealer.
The folowing web site has bags and rolls that can be cut ro make any size of bag you require. You can buy on line direct from the manufacturer as well as purchase more industrial vacuum packers
http://www.foodmc.co.uk/Category/113-textured-bags-for-external-bag-machines.aspx
Jun 14, 2009 | Vacuums
I purchased a toastess vacum bag sealer at Canadain Tire two months ago. I only had it about a month when the sealing wire broke. I returned it to the store and they replaced. One month later the same...
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=578564
Generic problem for all Vacuums
I purchased a toastess vacuum
posted by carmelwhiffe on May 07, 2008
I purchased a toastess vacuum bag sealer at Canadian Tire two months ago. I only had it about a month when the sealing wire broke. I returned it to the store and they replaced. One month later the same thing happened again, but because it is more than 30 days I can not return it to the store this time. I have misplaced my bill of sales. Where do I go from here.
Carmel Whiffen
Marystown NL
AOE 2M0
(709)279-3149
I’m sorry that I cannot help you with this, this particular site is for vacuum cleaners only and you may want to check with the manufacturer of the vacuum bag sealer to try to help you on this matter, or check with Canadian Tire to see if they have a phone # to the factory or manufacturer. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
Don – The Vac Man
Go Ahead. Use Us.
May 07, 2008 | Vacuums
Tilia FoodSaver V2240 Logo
269 people viewed this question
Top Tilia Kitchen Appliances - Others Experts
Lee Eismann
Mike Squire
Ed Mac
Are you a Tilia Kitchen Appliances - Other Expert? Answer questions, earn points and help others
