Question about Simplicity 9,500 BTU 3-in-1 Portable Air Conditioner SPAC9507
Simplicity portable air conditioner manual
Control panel not working right. Frozen mode.
MY SIMPLICITY MODEL SPAC6077 PORTABLE A/C HAS LOST ITS COOLING POWER, ANY TIP TO SOLVE THIS PROBLEM?
sorry to say but it might be time for a new one because when they sit for a long time and are not used the seals wear out and go bad . then the Freon leaks out so no more cold air only fan.
Jul 25, 2016 | Simplicity 6,000 BTU Portable Air...
Need to fix leaking on my simplicity portable air conditioner 6077 and how the drain works
If it is water in a thru window installation you will need to tilt the unit up a little so the condensate water drips outside. I hope this helps! Thank you and please leave feedback.
Jul 11, 2016 | Heating & Cooling
My kenmore 12000 btu portable air conditioner keeps switching to DH mode out of AC mode
That means that it is dehumidifying. Is the air coming out still cold? I assume you have tried using the mode button to switch it back? Is the air extremely humid? Perhaps it is humid enough that the machine needs to dry the air before safely operating as an AC. The manual is available here:
http://www.sears.com/kenmore-portable-room-air-conditioner/p-04272012000P
Jul 05, 2015 | Kenmore Portable Air Conditioner 10000 BTU...
Error code P1 what does it mean
look in the owners manual can be found online
May 30, 2014 | Simplicity 6,000 BTU Portable Air...
I bought a 7000 BTU Simplicity portable air conditioner as is from Canadian Tire. It's only sold with the system unit. I don't see any hot air hose, but I also don't know where the hose would attach to the...
The hose has an adaptor, which is recantgular in shape, that attaches to the grill in the back, right side facing. If you do not have this adaptor you would have to order it from an appliance repair depoe, as well as the hose. Good luck. Google, simplicity spac7088 owners manual and you will see what i mean. gdm1454@yahoo.ca
Sep 02, 2010 | Danby Portable Air Conditioner
Searching for manual for my simplicity portable air conditioner
Yes can you please provide the make and model # so We may help more.
Jun 13, 2010 | Heating & Cooling
Danby-Simplicity SPAC 1220081 - manual gives no indication on how to activate the ionizer function, ie: get the light to turn on suggesting its working. Any ideas? kms. Oops - typo in the model # correct...
I talked to the Danby rep and he said you activate it by pressing the 'fan' button on the control panel for 3 seconds until the ionizer indicator light activates/deactivates. I haven't tried it yet (I'm at work) but I'll give it a shot when I go home.
Jun 23, 2009 | Danby Portable Air Conditioner
DPAC 13009 portable air conditioning problem
Remove your remote control on the unit, follow the manual step by step. First, do the emergency on/off button, then operate the air conditioning using the remote control, follow the procedure of your manual.You may notice a clicking sound of your remote control. The yellow/green color of your emegency on/off button will turn to blue. Do not put it back your remote control on the unit because he may sense the temperature of the vent, and your air conditioning will not stay on, it will shut off every five minutes. Your problem is solve.
Regards,
Cesar
May 24, 2009 | Danby DPAC12031 Air Conditioner
Manual for Akai reverse cycle airconditioner remote control
I have a Akai AC-GP10HRCI model portable air conditioner. We have lost the manual. It shows F8 on the display panel board and is not working at all. Please help. Thank you!!
Jun 08, 2008 | Heating & Cooling
Simplicity 9,500 BTU 3-in-1 Portable Air Conditioner SPAC9507 Logo
37 people viewed this question
Top Simplicity Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
Are you a Simplicity Heating and Cooling Expert? Answer questions, earn points and help others
