Question about Garden
How to adjust a carburetor on a Polaris Predator 90 ATV
SOURCE: how do you adjust chain on polaris atv
I have polaris 250 trailblazer,2001. If you'rs is like mine, you have to loosten those 2 vertical bolts behind the axel on the very back of the swing arm, I don't know if you have to or not but I removed the brake caliper & loostened The 2 bolts holding the protector plate. Then you turn the axel between the 2 vert. bolts. Remember, When you'r machine is in gear the chain is tighter than when not in gear so leave a little play. Good luck, & be safe!
Posted on Apr 12, 2009
SOURCE: will not start. no power to lights, starter.
NOT SURE IF THIS WILL HELP BUT I HAVE A 2004 POLARIS PREDATOR 500 AND IT HAD THE SAME PROBLEM! IT TURNS OUT THAT IT WAS A RELAY BOX LOCATED ON THE BATTERY TRAY.
Posted on May 18, 2009
  • 3 Answers
SOURCE: ATV will not start. no power to lights, starter.
make sure that your battery terminals are clean and are making good connection, sometimes when alot of mud builds up on my bikes battery it wont start also try to start it by the recoil is it has one or the kick start cuz when the battery is dead and you stuck in the trails you can start it by this and it should start
if this doesnt work let me no
Posted on Jul 23, 2009
SOURCE: atv is not charging atv is a polaris 90
polaris 500 charging problem at idle 11 to 12 volts, at a reeve only 9 volts
Posted on Dec 26, 2009
  • 5 Answers
SOURCE: won't start after pulling safety tether Polaris Predator 90 2006
as long as the tether is back in correctly it should start. try checking the battery. if the battery is fine then look at the battry and make sure your tether wires arent shorted anywhere
Posted on Aug 21, 2010
Whats the float sit n on 08 outlaw 90
Hi, Nikki if you hold the body at an angle that the float needle just barely touches the seat without compressing the internal spring at this point you want the bottom of the float to be parallel with the gasket surface of the of the carburetor body, if necessary bend the float tang carefully to achieve the desired level, sorry you can't find the first and best tool you ever bought for your Derbi despair, not for a mere $5 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please visit the websites below. Good luck and have a nice day. Adjusting Carburetor Float Level
https://www.tradebit.com/filedetail.php/118370607-polaris-predator-50-outlaw-90-
Polaris OEM Parts Accessories
http://pi54.com/corp/Manuals/Owners/9920868r03.pdf
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Mar 05, 2016 | Motorcycles
What is the idle r.p.m on a predator 90
Idle should be set at about 1300 rpm with a warm engine. Usually you can tell when the headlights start getting bright. Daniel
Sep 05, 2014 | Polaris ATV
Adjust carburetor polaris atv
turn mixture screw all the way in, and back it out 1-1.5 turns
May 04, 2013 | Polaris 2004 Predator 90
Polaris predator 90 runs but has no power under a load.
This this is a multiple solution situation, does it roll with ease without the engine running and the unit in neutral and the brakes off ? With the unit in neutral and the engine running does the engine response follow the throttle position ? Is there any signs of black or blue smoke coming from the tail pipe ? And when was the last time the drive belt and pulleys were inspected for wear and proper operation ? Any of these areas can prove to cause loss of power on the polaris atv's especially with the drive belt powered transmissions.
Dec 19, 2011 | Polaris ATV
Can i put a flyweel from a 2003 polaris predator on a 2005 polaris predator? i recently bought an 03 and i have an 05 and i am wanting to make one complete bike out of the two
If you have a 2005 ATV A05GJ50AA PREDATOR 500 and a 2003 same size..then YES, the flywheel is part# 30878055 and WILL fit in either model
if you have a both PREDATOR 50 or 90 the the flywheel is the same as well for either year.. part#...0450525
Hope this helps
Good luck
Thanks
Please rate FIXYA
May 21, 2011 | Polaris ATV
Predator 500 chugged and quit nothing at all no starter no lights
my predator did this same thing i took it in to polaris to get fix but havent heard back yet what was it with yourS?
Mar 06, 2010 | Polaris ATV
Won't start after pulling safety tether Polaris Predator 90 2006
Apr 02, 2009 | Polaris ATV
2004 polaris predator 500 3 new batterys dying can't charge them
I hope you got this problem fixed, just happened to my predator, it was indeed the voltage regulator. I picked up a service manual that includes part numbers and installation procedures from www.promanuals.net for 15 bucks.
Mar 21, 2009 | Polaris ATV
Will not start. no power to lights, starter. Battery fully charged. ATV is a 2006 polaris Predator 500.
Mar 06, 2009 | Polaris ATV
Garden Logo
183 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
