Question about Garden
Pro 1600 pwa
As soon as i fit a lance to my pressure washer the motor cuts in and out continuously. if i take the lance off the motor runs perfect
  • 92 Answers
SOURCE: pressure washer
Dear Davidpaulson,
There are many reasons why there is no pressure. The simplest one is try a new lance. The lance you say it is not blocked, but it could have a wider hole with wear and tear.
The second most possible reason is, faulty valves. The suction valves are the most that give low pressure when they are faulty. To check the suction valves, put on the machine in the normal way and as it is working, disconnect the water supply. Than check if air or water is blowing out from the inlet. This is not 100% but you can have a picture of the function of the suction valves.
On the other hand if you do this exercise with the outlet, after removing the gun, you can check for the delivery valves. If you feel suction at the outlet, than the delivery valves can be faulty.
If all is correct, than there must be a fault in the swash plate. This could become loose and so the pistons will stop moving. Also another fault could be broken springs.
Also if the machine is leaking, the high pressure and low pressure seals are damaged. This also lowers pressure.
Other faults are related to the famous spill valve. Also faults could be to internal water leakages, due to corrosion in heads. Finaly I like to add that a faulty electric motor, could also not deliver enough rotation and power, and this also reduces pressure. This could be rewinded or changed for a new one.
Regards,
MG.
Posted on Nov 05, 2008
  • 389 Answers
SOURCE: Sporadic pressure
OK. Pulsing on and off is quite common. Unfortunately, it can have several possible causes.
If the  machine pulses while you are squeezing the trigger, and there is water coming out of the jet, then most probably the jet is partially blocked. It may or may not be possible to clear it...
If the machine pulses when you are not squeezing the trigger, then there is a leak somewhere. And this is where it can get complicated because there are several points in the pressure system where leaks can occur. The simplest to diagnose (and quite common) is a leak in the trigger itself. If you've got even the slightest drip from the jet while the trigger is closed, then this is the cause of the problem. On some guns you can change the trigger, on others the whole thing must be replaced.
If there's no drip from the jet, the next question is: is there any leak coming from the machine itself? Again, even a very slow leak will be sufficient to cause the problem. Basically, a pressure seal has failed and, depending which one (or more), this will allow water to leak from the high pressure side of the system either externally (in which case you'll see it) or internally (back in to the low pressure side, which you won't see).  You may need a professional to sort this out for you.  If so, don't be surprised if they change all the seals in one job because the parts are cheap compared with the labour.
I hope this helps. post again if you need more details.
Posted on Mar 22, 2009
  • 83 Answers
SOURCE: honda pressure washer cuts out when lance trigger released.
You most likely need to set your valve clearances. If it is hard to pull over or the recoil snaps back after starting your valves need to be set for sure. This may not be the entire problem but it is a good start. Also change the spark plug, a bad plug will cause odd problems and is too cheap not to eliminate as a source. In addition check your fuel, pour a little out into a white container (I like spray paint can caps for this) and look at the color. If it is yellow to orange it is bad. You can pour it into you car, the car electronic sensors will compinsate for it quality but a small engine can't. Use a NGK BP6ES or BPR6ES plug.
You need:
Feeler gages
10mm open end wrench
14mm open end wrench
1 long shaft screw driver or rod
1 spark plug socket and ratchet
Remove the spark plug and the valve cover. Pull the recoil over slowly until the intake valve opens (intake is closes to the carb and it will go down when it opens). Now put your long screwdrive down the spark plug hole. Slow pull the engine over until the screwdriver handle is at it highest point, this is top dead center. It may take a few attempts. Now check your valve clearance between the rockers and the top of the valve. The intake should be .006 and the exhaust .008, both can be +/- .001. To adjust: hold the large nut with the 14mm then loosen the small one with the 10mm. Lefty loosey. Now turn your large nut until you get the correct setting and then tighten the small one the lock it in. It may take a few attempts and alway reverify your setting after you lock it down. Once done, find top dead center again and reverify. Now your valves are set.
Posted on Mar 31, 2009
  • 32 Answers
SOURCE: Karcher Motor Pulese On and Off
hi mark, you do have a problem with the lance.
you need to disconnect the lance and straighten a paper clip and insert down the nozzle end.
use the machine to wash the dirt in the nozzle backward down the lance.
Dirt only in nozzle end.
if still no good, purchase some nozzle cleaners and file out nozzle very slightly.
Posted on Jul 04, 2009
  • 8 Answers
SOURCE: i have a petrol pressure
Your unloader on your pump is working but when you ask for the engine to work it struggles I would check the air cleaner the passage in the carburetor could be slightly plugged starving the engine for fuel check and make sure the choke is fully opened your problem is for some reason the engine isn't providing the horsepower needed maybe try backing off the pressure regulator.
Posted on Feb 05, 2011
I switch the pressure washer on motor starts pressure builds up motor stops. OK pull the trigger on the lance the moter starts sounds different water pressure low. Release trigger motor still runs.
It isnt very clear your explanation of the problem but what type washer do you have first? It sounds like you have a bad unloader or need a new variable nozzle tip. Can you explain in more clear detail. Thanks
Feb 16, 2015 | Garden
How do i fit a new lance to Challenge MH02-1610GO pressure washer
Just the lance or trigger gun! Best of luck to ya!
Sep 23, 2014 | Garden
I have a pro 1600pwa no22049022491 and it leaks from the gun i took gun apart to find that the small tube comes up the handle inside bends then gos on the end of the trigger in the bend ther is a small...
No parts for the gun. I'm not sure what model you have for sure, I don't recognize 1600 PWA, see link.
http://www.ppe-pressure-washer-parts.com/job-mate-1600-power-washer-parts
Apr 19, 2014 | Garden
Pacific hydrostar 68333 1500psi pressure washer...motor keeps cutting out, but reset breaker does NOT trip.
dont know the model or if it has a pressure switch inside the box but try and remove your lance and just operate the gun... if it runs ok your last could be blocked
Aug 21, 2013 | Pacific Hydrostar Pacifichydrostar...
I have a petrol pressure washer, it runs fine but as soon as i pull the trigger on the lance the motor really struggles then cuts out after a little while
Feb 03, 2011 | Garden
I have tried to use my Karcher washer model 411A using the suction tube which is immersed into Patio cleaner bottle but it does not work what am I doing wrong
you have to lower the pressure at the lance for the detergent to be drawn into the hose. It works on a venturi principle.
on the lance you will have to twist or pull back the end for it to go into low pressure mode.
the easiest way to check it is working is to take out the lance extension , the bit that fits into the trigger on a bayonet fitting. run the machine and see if it then draws in detergent.
If it doesnt draw detergent then look to see if there is a detergent valve fitted to the filter that goes into the bottle and check that it is fully open. sometimes ther is a non return valve fitted into the filter too.
it could be that this non return valve has stuck. A poke with a bit of stiff wire should free it off its seat if it is that problem.
hope this helps a little
Jul 17, 2009 | Alfred Karcher Pressure Washer
Craftsman model 580.752020 electric pressure washer. First time I used it worked for about three minutes then the motor stopped. I cannot get it to start again. Plugged into a 15 amp gfi circuit which did...
turn off water and machine electrics.
remove high pressure hose from front of machine, this may be tight if there is still pressure in the system.
turn on water, when water comes out of machine hose outlet turn on machine. does the machine turn on and water flow increase, if so you probably have a blocked lance jet or trigger.
remove lance extension if fitted and fit hose back to machine, try again. If its ok then this proves you have a blocked lance jet, maybea poke about with some stiff wire will free the obstruction.
If this doesnt bring on the machine you probably have a jammed pressure switch on the pump.
this pressure switch turns on the pump when the trigger is pulled and switches the motor off when the trigger is released.
hope this helps.
Jul 16, 2009 | Electric Garden
Jun 29, 2009 | Garden
Garden Logo
149 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
