Question about Kohler K-560-VS Bellera Bellera Pull-Down Kitchen Faucet, 7-7/8" Spout
Slight drip from aerator
How do you get it to stop dripping from a newly installed faucet
SOURCE: dripping faucet
Take a cloth and lay over the top of the stem so as not to damage it. With pliers, grasp the top of the stem and turn it a quarter turn counter clockwise. The stem should lift right out.
Posted on Mar 14, 2009
01fordeb
  • 1033 Answers
SOURCE: Faucet installed 9/94 and still looks like new.
Try tighten the hoses, if this don't work the seal in hose connectors may need replaced, very simple and cheap to replace. over time the hot water will wear down the seal it will go bad with pressure and water period. It's a good thing to change these all while you are there.
Posted on Jan 18, 2010
  • 100 Answers
SOURCE: I had a dripping Kohler Finial kitchen faucet
Any bit of dirt or grit in the line will get caught in the cartridge if not flushed properly.
Posted on Apr 19, 2010
txpipelayer
  • 20 Answers
SOURCE: I have a Koiler A112.181M or 157-076-ST kitchen
If there is a hole on the spout itself then you should go ahead and replace th.e whole faucet. This will save you both time and money in the long run
Posted on Sep 16, 2010
  • 4341 Answers
SOURCE: Hi, my shower faucet /head
You need to order seals and replace them. Typically, dirt in the water system damages the rubber (neoprene, plastic) soft parts. Sometimes the damage wrecks metal parts, but this is less common.
Posted on Oct 05, 2010
Leaky kitchen faucet
What kind of faucet? (single handle, double hndle, kitchen, bathroom) Where is it dripping from? (handle, aerator or faucet head, under the sink) There are many types of faucets and many types of leaks. Sorry to be so vague but there's a pretty wide spectrum of possibilities, a little more info will go long way.
Feb 04, 2013 | Plumbing
Blanco alt drips
The drip may be caused by poor design. The aerator may have been installed incorrectly by the plumber.
Sep 25, 2017 | Blanco Classic Single Handle Faucet with...
Faucet leaks. Replacing cartridge does not fix it.
Well let's go over the cartridge install. Did you flush out the valve body and clean any and all debris from the area before putting in the new one. If there were any sharp deposits of lime buildup they may have cut one of the O-rings or seals. Did you use plumbers lube on the O-rings and seal before installing the cartridge?
I ask all of this as you should not have this problem after a new install.
One other thing if the leak is only for a little while and then it stops, take off the aerator and clean it. If it is filled with debris it will hold water and drip for some time.
Hope this helps and good luck.
Feb 06, 2011 | Kohler FortĀ© Widespread Lavatory Faucet...
I have a Danze Opulence kitchen faucet, i have replaced the aerator and cartridge, the faucet still drips,any ideas,thankyou.
below the cartridge should be some rubber washers if its the model im thinking of, try those. if not sounds like the whole valve needs to come out....
Jan 26, 2011 | Danze Plumbing
Danze faucet and soap dipenser drip
it could just be a defective unit,it is not unheard of.i have run into this myself alot of times.if you can take it back and get another unit.
Jul 08, 2009 | Plumbing
Kitchen faucet leaking pull down sprayer spout type
try tightening the nut that attaches the flex line to the pull out spout
May 04, 2009 | Price Pfister J103-BC 100 Series Kitchen...
Kitchen facet has been losing water pressure.
Faucets are normally fitted with an aerator that screws on. These can get clogged with minerals from hard water and cause the problem you're having. Try unscrewing the aerator and removing it. It may be pretty tight, but it will come off. Slip-joint pliers with the jaws wrapped with vinyl tape to prevent scratching the chrome can help.
Once the aerator's off you'll probably find the water works properly. It might be possible to clean out the aerator, but the best solution is to get a replacement at a hardware store or big-box home improvement store. They're only a couple of dollars and a new one will be more reliable.
Please take a moment to rate this solution, and thanks for asking here!
Mar 01, 2009 | Price Pfister Plumbing
Leaking faucet
The faucet is slowing wearing out. You can live with this little drip or have a repair kit installed in the faucet. If you are handy you can do this yourself.
You must be sure to get the repair kit that matches your faucet. good luck
Jan 17, 2009 | Plumbing
Kohler K-560-VS Bellera Bellera Pull-Down Kitchen Faucet, 7-7/8" Spout Logo
43 people viewed this question
Top Kohler Plumbing Experts
Mike
Donni Steen
Are you a Kohler Plumbing Expert? Answer questions, earn points and help others
