Question about Philips E-Box FTR9965 DTV Receiver
No signal from FTR 9965
Hi When I turn my TV (screen) on it says no signal on VGA1. The led on the TV is green and on the FTR its orange. After a while the led on the FTR starts to flash between green and orange. The TV then switch itselfs off and the led on the TV is red. Then the FTR becomes orange (the led). Then the TV sometimes starts itself and after a while it turns off. When I try to connect a computer directly to the VGA1 on the TV (screen) it works so I think the problem is with the FTR. Anyone have a clue? Thanks in advance!
  • Kelvin R Jan 05, 2008
    I have the same problem. When the EBox is turned off, the LED goes out, but I'm sure it used to go red. It doesn't seem to detect a VGA input either.
2 Suggested Answers
SOURCE:
SOURCE: Looking for where to find this part
You need to fix power supply module (replace electrolitic capacitor on PCB) in your plasma. It's very frequently failure for this device.
Posted on Jun 09, 2008
Philips FLAT TV FTR 9965 Receiver flash red light
Apr 15, 2010 | Philips E-Box FTR9965 DTV Receiver
What does it mean when that blinking green light turns to orange one in lp 350?
Hi
This would be "Standby"
When you press standby, the display and audio turn off and a blank screen is displayed for 15 minutes.
You can change the amount of time the projector stays in standby mode; see “Standby Time” on page 27 for details.
The LED lights orange while the projector is in standby.
• If you press standby again within 15 minutes, the projector returns to normal operations immediately. The LED changes from orange to green.
• If you press standby again after 15 minutes, there is about a 60 second delay before the lamp turns back on. The LED flashes green while the lamp is re-lighting.
• If you don’t press standby again, the lamp turns off after 15 minutes. The LED lights orange while the projector is in standby.
The full manual can be found here:
Infocus customer support
Infocus LP350 Manual
I hope these help
Mike
Sep 18, 2009 | InFocus LP350 Multimedia Projector
FTR 9965/12 The screen will not come on, no VGA signal! We have looked over the connections and can´t find anything wrong!
Hi there ,
What you can try is to boot in SAFE-Mode, by pressing the F8 key on your keyboard more continiously when turning on your pc, If you are able to view the desktop in safe mode, then you must set your screen resolution lower, but if still no display, then your display adapter might be faulty, check your RAM, remove and re-insert them into the motherboard...try that......Let me know how it went
Regards
Techmor
Jun 17, 2009 | Pc Ware M748LMRT Motherboard
TV won't power on, repeating doulbe red light blink
Question Television is not working, screen is black, blinking red led.
Answer Television is probably malfunctioning due to electrostatic discharge. Try resetting the television by unplugging it from the power outlet for 10 seconds.
  1. Make sure that the power cable on the display and the VGA cable with trailing audio cables are connected correctly (use the originally supplied VGA cable.) between 'MONITOR' of the TV and 'VGA1' of the display.
  2. Make sure that the display is switched on.
Jan 24, 2009 | Philips 37PF7320A 37 in. HD-Ready LCD...
Lead from receiverbox 9965 to tv
I have a philips E box w/ pixel plus. my tv died. i paid over $400 for the flat tv receiver FTR 9965. send me an email and i will gladly sell for $100. [email protected] 813-477-4517 i have just placed it on craigslist in Tampa, FL
Rick
Jan 11, 2009 | Philips E-Box FTR9965 DTV Receiver
Nov 20, 2007 | Philips E-Box FTR9965 DTV Receiver
Neovo x17a monitor
Are the settings on the video output correct? Is there a green or orange light illuminated. There is a difference between the Power LED and the Signal LED which is green. If you have no signal the LED will remain orange or yellow but not green. If the LED is green, then a signal is getting from the PC but not necessarily good. Check the signal with another monitor or TV if you can. Check the cable.
Aug 15, 2007 | Neovo AG 17" LCD Monitor
Phillips FTR 9964 Blinking Green/Orange Indicator Light
PHILIPS 42 WILL NOT TURN ON,WITHE FTR9964 RECEIVER
TO BLINK ORANG /GREEN AFTER 40 SEC ORANAGE
May 23, 2007 | Philips E-Box FTR9965 DTV Receiver
Philips E-Box FTR9965 DTV Receiver Logo
77 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
