Question about Honeywell Programmable Thermostat Heater
The display on my CM921 is only partially showing. The boiler is still coming on and off as programmed. I tried changing batteries, but makes no difference. Is the display panel just dying.
3 Suggested Answers
  • 587 Answers
SOURCE: I have a cm921 thermostat with the correct
HONEYWELL WEBSITE:
Go to honeywell.com
Under red welcome sign
Bottom red highlighted box literature/image search
Type in thermostat model number
Click on arrow to right
Then click on the PDF files owners manual / installation instructions
If you can’t find what you want, the bottom left and bottom of web
Page, they have homeowners assistance and Home products to get the help you need.
Posted on Mar 16, 2010
  • 90 Answers
SOURCE: i've got a honeywell programmable
used to work on honeywell a few years ago and don't know how different controls are now but you need to find out what connections on controller which are closed contact till desired temp is reached then open contact (a good way to test thermostat is with a heat source like a hair dryer we used these to trick reverse cycle heat pumps into cooling when there was no pump down switch). Then connect the thermostat to your furnace where it is mrked (most furnace's have t/stat marked in thier electrical box) or wire straight into main power feed so that it cuts power to furnace when desired temp is reached they can be wired into heaters various ways and to do the main feed way really needs a qualified sparky but they have trouble sometimes working these things out as they usually only run cables to on/off switch's (which a thermostat basically is) and light fittings and power points i found that qualified refrigeration mech. usually have the know how for these controllers as they work with them all the time so hopefully helped you there, and the t/stat should click in and out even without being hooked into system you can also test these with a beep test on multi meter as temperature goes up and down past set temp the multimeter will beep when contact is made and stop when no contact but check all connections to t/stat as you from memory you can wire it back to front so its on when it shouldn't be and visa versa so it'll pay to write it down what you find as you go for refrence when connecting in
Posted on Nov 19, 2010
No back light implies no power but batteries recently changed and new sets tried to no avail
Contact the manufacturer, perhaps there's a recall or they may be able to resolve the issue for you through phone support.
Feb 20, 2015 | Heating & Cooling
I have a Honeywell CM921 thermostat. I stupidly let my young daughter play with it but shes now changed something on it and i haven't got a clue how to change it back as i don't know what the problem is TO...
Press the time button once. The display will show 'RESET PROGRAM'.
Press the or buttons to select the preferred setting (0=user program,
1=factory program) and the display will flash, indicating a change has been
made. To confirm this change press the green button.
and don't let your kid play with it again until next year when her grasp on technology exceeds the current model smart phone... LOL
Dec 13, 2014 | Heating & Cooling
Hw can I repair my LCD Display?
No the unit will have to be replaced
Aug 30, 2014 | Heating & Cooling
CM921 LCD figures breaking up
Hi There - I have a similar problem to the one described by yourself . Did anyone offer any help or assistance on this at all ?
Many thanks
M Hudson
Jul 15, 2013 | Honeywell Programmable Thermostat Heater
The wifi connection from worcester boiler to room thermastat Honeywell Cm921 , boiler not receiving signal
Can't help you directly, but Honeywell will have user instructions on their website.
It's something like holding the 'stat within a metre of the boiler when the batteries are inserted. Best to RTFI.
Jan 27, 2013 | Heating & Cooling
I have just had a new boiler fitted and wanted to run the thermostat (honeywell cm921) on auto, the electrician set the timer to come on at 1 & off at 2 disabled at 3 & 4 and on again at 5 and off...
Complicated because I need more info....but in General a Boiler should not be on a Programmable Thermostat as it takes too long to heat etc...do you have Radiators in your house???Or ductwork for heat???It will make a difference...if you put the boiler on a program it may come on anyway as some boilers maintain there own internal temperature regardless of the thermostat.....if you want to run it on a program adjust the temperatures so there is only about a 2 degree swing....70...down to 68....back to 70.....etc...there should also be a switch in the thermostat to set for Boiler...or Electric heat...make sure that switch is on...otherwise its difficult to give you a more conclusive answer
Nov 11, 2009 | Honeywell Programmable Thermostat Heater
Honeywell CM921 Showing room temp at -24 degrees, How do I reset?
Heya this is a manufacturing fault from honeywell them selves when it comes up -24 basically it needs to be replaced there is no way around in if you get in touch with honeywell they are generally good about it also if you provide them with the date code and model code they will be greatfull as it seems they have sent out a "bad batch". you locate this by:
A) Move the slide in to the off position
B) Press and hold i for 5 seconds
C) Unit will enter settings mode
D) Press and hold the i button and the + and ¿ button together
E) The unit will hold the relay on for 5 minutes and you can view by pressing the down arrow twice for model id/date code (ww/yy)
I hope this helps
Nov 11, 2008 | Honeywell Programmable Thermostat Heater
HONEYWELL CM921 ROOM THERMOSTAT
Remember the is a time and temperature controller if you want to use as an ON/OFF controller please ensure you OFF times are set to LOW temperatures for example at 8:00am I want the boiler firing to 21°C at 10:00 I want the boiler to go OFF at 5°C so ensure all so called OFF times are set to LOW temperatures.
Oct 26, 2008 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
Brandon Berry
Brandon Berry
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
