Question about Samsung SGH-d807 Cellular Phone
Samsung sgh-d807 does anyone know how to disassemble the phone. i need to change out the ribbon cable but i cant figure out how to take it apart. thanks
  • ridehard Aug 11, 2007
    thanks i got it apart... now i just gotta fiigure out how or where to get a new ribbon cable... any suggestions??
I just ordered one from ebay.
The ribbons tapes dries and rips bc of old age...
I wonder if covering it in liquid tape would make it last longer.
Posted on Oct 20, 2007
I just finished disassembly and it wasn't that bad. Take off all four screws around the battery, then carefully but forcefully take the plastic casing off. Then, take the 2 screws on the main circuit board. That will reveal one connection for the ribbon cable, take that off. Under that is the backplate sliding mechanism of the phone. There will be 6 screws on this assembly, one of them under cable the connects to the keyboarb (bottom right). You will have to take off a green tape and also a gold padding to get to this final screw. After that is off, you will see the other half of the ribbon. Take that one off also, just yank it off. Install the new ribbon tape, make sure you don't rip it, and you're set. good luck. EE
Posted on Aug 11, 2007
2 Suggested Answers
  • 3 Answers
SOURCE: samsung sgh-d807
Remove battery cover and battery. There are four small screws visible on the rear cover, remove those. Wiggle and distort the back cover a little at the bottom of the phone until it pull partly free from the phone, slide a guitar pick or small flat blade screwdriver between the phone and the rear cover, at the side of the phone, pry this cover off until it snaps free. You will see the main board now. Remove the two screws holding this board on, carefully fold it back towards the battery area. The main ribbon cable is visible now. Remove a green tape on the socket where the ribbon cable joins the board. pull the ribbon away from the board gently and use a screwdriver or something else to cut the adhesive between the board and the cable. The socket has a hinged brown piece closest to where the cable comes in, that flips up to release the cable. The small cable coming from the number pad is removed by gently prying up the rectangular connector from the board. Now with the board free you can remove six screws from the plastic backing plate, and remove that plate from the slider assembly (one of the screws is hidden by a piece of green tape). On the front half of the phone there are six small screws on the rear side (the camera side). Four are visible, two are hidden behind rubber plugs at the top of the phone. Separate the chrome trim from the backing plate by starting at the bottom of the phone, by the key pad, and it may be stuck from a little day-to-day dirt but separate it there, then swing the bottom end out and release the front cover from the two clips that hold the top end together. You now can separate the ribbon cable from the screen assembly in a similar way as you did with the other end of the cable. Reassembly is the reverse of disassembly. Be sure to replace the pieces of tape, and the wire mesh shield attached to them, they serve to prevent radio frequency interference between parts of this device, and between this device and others.
Good luck, and happy dreams.
Posted on Dec 06, 2007
The light does not light when the slide is open nor when any buttons are touched.
Hello Sir.
Welcome To Fixya's Community.
Its My Honor To help You Sir.
The problem with your Phone is related to The Flex Cable.
Flex Cable:
The Part that connects the LCD to the Keypad (Motherboard).
Its defective after a big times of Opening\Sliding The Phone
The Solution:
You Should Replace that part its easy and quick:
First You need Buy that Part.
Buy Samsung SGH-D807 Flex cable.
Take the Phone apart and locate the flex cable; its Flexes!
Ask me if You JNeed anything Further.
Please Honor me With Your Rate.
Thank You For Using Fixya!
Jun 17, 2009 | Samsung SGH-d807 Cellular Phone
Want e book reader
source the internet for that software
Nov 08, 2007 | Samsung SGH-d807 Cellular Phone
Samsung sgh-d807
Nov 05, 2007 | Samsung SGH-d807 Cellular Phone
Changing a ribbon on my samsung e 900
http://www.excelldirect.com/images/samsunge900gallery/myalbum.html I'm sure you will know how to use this page.There are pictures how to disassembly and assembly E900. If you don't have a soldering iron you can cut off those soldered pieces (even I hate people what do this :) ), but take care about flex cable. Enjoy and take care, mate ;) Level4 tech.
Sep 23, 2007 | Samsung SGH-E900 Cellular Phone
Turning on my phone
call cingular and they will give u the code
Sep 16, 2007 | Samsung SGH-d807 Cellular Phone
Ribbon Cable LCD
yes you can still do that but i think it would be best for you to take the phone to a professional mobile service center and have them replace it for you.
Sep 03, 2007 | Samsung SGH-d807 Cellular Phone
Need to Transfer Everything ontp SIM card
It's the ribbon cable, I've already posted how to disassemble the phone and put in a new one. Costs 4 dollars on Ebay.
Aug 09, 2007 | Samsung SGH-d807 Cellular Phone
Samsung SGH-d807 Cellular Phone Logo
386 people viewed this question
Top Samsung Cell Phones Experts
Felizardo Erilla
Felizardo Erilla
Bill Long
Donni Steen
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
