Question about Pool & Spa
Purex triton 5000 series pool filter
I do not know how to open the exterior
3 Suggested Answers
  • 8404 Answers
SOURCE: Pentair sm2-pp3 valve, triton II filter. Upon
Lots of sand? You may have a broken lateral in your filter.
To repair, you will have to remove all the sand from the tank to physically inspect.
Might you have changed the sand this year? (top 1/3 needed to be changed every 3 to 5 years normally) If you changed the sand ... did you put water in the filter tank first? If not ... there is a good possibility you broke a lateral (a small pipe with slits in it) when you put the sand into the filter.
It could be that you have too much sand in the filter. Check the owners manual for the clearance - top of sand to top of filter.
Thanks for your interest in FixYa.com
Posted on May 16, 2010
jharwell668
  • 640 Answers
SOURCE: can't get my creepy crawler to work in my pool, i
It sounds like your automatic pool cleaner might have a leak that is causing the pump to lose its prime. Check the hose to make sure that there are no leaks or cracks. Check the vacuum connection. It should be submerged so no air enters the system. Look and check the pump basket lid for looseness, cracks, and worn or missing O-rings.
Posted on Mar 08, 2011
Exterior measurements 1050B
Gary, I do not know what a 1050B is.
But Google can be your best friend.
This may help:
RIGHT-Click on this: Google and select Open link in new Tab.
In the search-box which opens, enter:
Exterior measurements THINGY 1050B where THINGY is replaced with the the name of the "thingy" you have.
Hit enter.
Now you may find more than you ever wanted to know about the 1050B.
Good luck and have fun.
Heinz
Sep 09, 2016 | Microwave Ovens
Exterior release for trunk won't open trunk. It only opens with remote.
Remove lining to trunk door and look at the linkage from the exterior release to the lock for damage or missing part
Mar 16, 2015 | Cars & Trucks
How to fix a velux exterior shutter which is stuck half open, half shut
I am a Velux installer I am assuming you are discussing an exterior shade on the outside of the unit rite?
Mar 31, 2014 | Velux VSE-S01-2104-RM Copper Frame VSE...
How to backwash purex triton fns pool
fns sounds like cartridge have to take out and clean if no backwash on a multiport
Jan 11, 2014 | Pentair PUREX MINIMAX HEATER; THERMOSTAT,...
VW Jetta 2012 exterior handle will not open door; however, interior handle will open the door.
Remove the inner door panel and make sure the actuator rod for the exterior handle is still engaged. If it is then the handle itself needs to be replaced.
Oct 29, 2013 | Cars & Trucks
Triton Purex minimax 400
dan i belive you have a faulty thermastat switch
Apr 01, 2012 | Pentair MiniMax CH Natural Gas Pool...
My 2002 nissan altima exterior door handle's latch rod came completely out of where it came from while i was attempting to change the exterior door handle. i can't figure out how that latch rod...
Think there may be a bushing missing and that's also how you make adjustments as well. Below are some pictures I had from my service manual. It wasn't much but I hope it helps.
May 31, 2011 | 2002 Nissan Altima
I have an older pool, and it has a purex triton whisper flo pool pump and don't know how to back wash. I am not seeing anything that says backwask or a lever to turn. I need to back wash because my...
You can not backwash a catridge filter. If cleaning them doesn't work they need to be replaced. A common 'issue' with cartridge filters - replacing the expensive elements every few years. There is no other way to clean them that will not in turn destroy the filter material in the process so new ones are your only choice.
John
Jan 14, 2011 | Pentair Plumbing
Pool & Spa Logo
240 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
