Question about Husqvarna Riding Lawn Mower 46 Cut Kohler Yth21k46
Lawn tractor won t start
The break is set the battery is charged and the blades are not engaged and the lawn tractor will not start no clicking or anything when i turn the key
  • 41 Answers
SOURCE: blades not engaging
Tim, first turn key on engage and disengage blade button. See if you can hear the clutch making a clicking noise. If not check switch., if not your problem is in the clutch.
Posted on May 29, 2009
lester482529
  • 226 Answers
SOURCE: mowing deck makes ticking noise when blades are engaged.
A FEW THINGS TO LOOK AT ARE ,1THE PULLY SHIELDSMAKE SURE THEY AREN'T BENT TO CLOSE TO THE PULLEY'S.2 THE PULLEY BEARING'S MAY BE WORE OUT AND TO BREAK .3LOOK UNDER THE DECK TO MAKE SURE YOU DIDN'T GET SOMETHING TRAPED IN THE CUTTING DECK.HOPE THIS HELPED.
Posted on Jun 11, 2009
  • 127 Answers
SOURCE: Husquavarna tractor battery won"t start engine
YOU NEED TO REPLACE THE SOLENOID IT IS SHORTING OUT AS TO THE GAUGE THEY WILL NEVER MOVE AS THE GENERATOR CHARGES ONLY WHEN THE BATTERY HITS 9 VOLTS THEN IT ACTIVATES TO CHARGE BACK TO 12 VOLTS BUT IN SMALL INCREMENTS
Posted on Jun 26, 2009
  • 202 Answers
SOURCE: Husqvarna yth2448 pto switch kills motor/battery will not charge
you may hav a bad alt. problem with the mower dying when you engage the pto is most likley a bad sensor or wire unplugged on the seat sensor.the way it works is if the blades are turning and it dosent sense you being on the seat the mower shuts down.this has been standard on mowers for quite a few years now. it keeps the blades from cutting you up if you fall off the seat while mowing. as for charging i would try cleaning the battery connections and get the battery checked first.
Posted on Jul 19, 2009
  • 56 Answers
SOURCE: I have a Husqvarna 21 HP Lawn Tractor and I went
Check your charging system as purplewg recommends. Remove the battery, bring it to full charge and take it to an automotive store or battery shop and have them load test the battery to see if it will hold the full charge. Most places will do this free of charge....if your battery is more than two years old it probably needs to be replaced anyway....Autozone carries a really good tractor type battery for about 35 to 40 bucks that has a lot more amp hours power than most batteries you can buy...if you have to replace the battery get one of these....you'll be glad you did !!! I bought one for my personal mower which sees a LOT of use, and it's been in my mower for three and a half years and going strong...Hope this helps...;-D
Posted on Jul 21, 2010
Wont start no power to switch
I'm not familiar with your brand and make of lawn tractor but here's a few basics many of them have in common.
Any one of several safety features on newer lawn tractors will prevent it from starting.
Assuming your battery is fully charged, here's a few basic things to check, depending upon your level of skill and motivation:
1. Parking brake: A switch must be engaged when the parking brake is set. Most newer lawn tractors have to have the brake set to allow the starter interlock relay to energize the starter.
2. Blade engagement PTO: The blade PTO switch or lever must be OFF or the tractor starter won't energize.
3. Seat switch: Some (not all) newer lawn tractors won't start if the operator presence seat switch is not closed. (you have to be sitting in the seat or the starter will not be energized.)
4.. Corroded/loose battery terminals or wires. Remove the battery leads and clean the terminals. Check and make certain the battery leads are tight.
You can do some investigative sleuthing by using a multimeter, set in the OHM position, to test switch continuity. Locate and unplug these switches from the wiring harness, one at a time. Insert the meter's test leads into the switch plug's terminals; not the wiring harness. Activate the switch. If your meter shows current pass-through or continuity, the switch is working. If the meter reads OL (for digital meters) or stays at zero, that switch is bad.
If your safety switches are good, you'll have to look deeper.
Some lawn tractors have a fuse panel to protect the electrical circuits and components.
1. If you have a fuse block on your tractor, remove the plastic cover. Most of the fuses in today's tractors are the color coded, plastic cased, automotive type. Remove each fuse and inspect their filaments one at a time. A blown fuse will be easily identified. Replace any blown fuse.
2. The starter interlock relay may be faulty, or have a disconnected/broken wire. Check your wires and terminals. The starter switch itself may be faulty. Use your meter in the OHM setting, put your leads on the starter switch terminals with the switch disconnected and off. Turn on the ignition switch and turn the switch to the start position. If the switch shows current pass-through, the switch is good. If not, replace it.
3. Is your battery discharged? Do you hear a "click" when you try to start your tractor? If you hear a "click" when you turn your key to the start position, and your battery is charged, there's a strong likelihood your starter has malfunctioned and needs to be replaced. (or your engine is seized) If you hear absolutely nothing while trying to crank over the engine, it's a safe bet you're not getting power to the starter because of a safety switch, bad fuse, starter interlock relay, or a broken/disconnected wire somewhere.
Sep 20, 2015 | Cub Cadet LTX 1042 KW 42" 18HP Kawasaki...
Blade engagement lever won't disengage
If this is a manual engagment system all the lever does is to pull a jockey wheel into the back of the belt to tention it thus starting the blades to turn, so either the cable is jammed that pulls the jockey wheel in, or the jockey wheel arm is seized and needs freeing off to allow the jockey to to move to the relaxed position.
Jun 23, 2012 | Craftsman 20 Hp 42" Deck Lawn Tractor
Blades fail to engage (using pto) after tractor has been running for awhile.
bad wiring to the charging system or the alternator is bad
May 03, 2012 | Garden
I have a Husqvarna 21 HP Lawn Tractor and I went out to start it and the battery was totally dead, so I jump started it. It started but died out a couple times. So I got it going again and drove it up the...
The electric clutch needs full power in the battery to stay engaged. I would recommend you check your charging system before replacing the battery. Put a digital volt meter across the + and - terminals of the battery and while running at about 1/2 throttle you should be over 13 volts DC. Probably around 13.5 or so. If not you have a charging problem. Lawn mower batteries I have seen seem to last only 2-3 years. I would also recommend a trickle charger for extended periods of non use. Don't forget the Stabil also.
Hope this helps.
Jun 27, 2010 | Husqvarna Lawn Tractor - 54in. Deck, 26...
Mower blades willnot engage
make sure the battery is fully charged, check all electrical connections and clean them with vinegar and rinse well with demineralized water afterward.
May 26, 2010 | Husqvarna Lawn Tractor - 54in. Deck, 26...
My huskee lawn tractor will not turn over! The battery is fully charged, it is a 25hp with a 50inch cut, i replaced the selnoid last year!
The arm that engages the cutting blade tends to wiggle. Make sure it is pulled toward you (unengaged) before trying to start.
May 09, 2010 | Husqvarna Lawn Tractor - 54in. Deck, 26...
Mowing deck makes ticking noise when blades are engaged.
Jun 11, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Battery?, wiring??
If your Alternator didn't charging the battery, even though you brand new battery will not last. So there is two possible cause, 1) Your Alternator is not functioning. 2) there is a wiring problem that causing your battery to discharge easily, but you check it after you switch off the key remove the battery negative terminal then touch it back to batt term. and see if there is little blue spark, if does your wiring system got problem. If not, so your Alternator do not charge the battery.
Jun 01, 2009 | Husqvarna Lawn Tractor - 54in. Deck, 26...
Husqvarna Riding Lawn Mower 46 Cut Kohler Yth21k46 Logo
19 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
