Question about Consew 206RB
Free Sewing Machine Manuals
Needle shaft/clean out
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Consew Master
  • 102,366 Answers
Posted on May 05, 2013
How to change Brother compal galaxie 870 sewing machine needle default that starts on the left to default to the middle
Some machines have the left setting as the default. Those machines have the bobbin case that is installed from the left side of the machine. For most purposes, this default cannot be changed to center. Machines that have the bobbin case installed from the front of the machine generally have the needle center default position. However, it appears to be a newer model machine (post 1970), so there is a good chance your machine has a needle position setting.
Brother Compal Galaxie 870 Service Manual free download schematics...
Brother Sewing Machine Manuals Instruction and Repair Manuals
Feb 10, 2017 | Brother Sewing Machines
I would like an instruction manual
[PDF]5, 6, 8, 10 Stitch Sewing Machine - Singer
www.singerco.com/uploads/download/448_5_6_8_10_slide.pdf
exclusives, like a removable extension table ... This Singer Sewing Machine was tested according to. European ... Read all instructions before using this machine. ....The needle and thread you choose will depend upon the fabric being sewn.
Instruction Manuals ' Singer Sewing
www.singerco.com/support/instruction-manuals
Our replacement instruction manuals are provided in a downloadable PDF file ... To download a manual, you will need to know your machine's model number.
[PDF]INSTRUCTION MANUAL 9960 - Overstock.com
www.overstock.com/.../Instruction_Manual_14253523.p...
Overstock.comThis sewing machine is not intended for use by young children or infirm persons without ... The wrong plate can cause the needle to break. 12. Do not use bent ...
Free Sewing Machine User Manuals ' ManualsOnline.com
homeappliance.manualsonline.com > Household Appliance
Find the user manual you need for your home appliance products and more at ManualsOnline. ... First Virtual Communications Sewing Machine Manuals.
Manual Finder « Sew it Works!
Jan 07, 2016 | Sewing Machines
Needle shaft stuck. Machine won't work.
It's possible that you have threads wound somewhere inside the machine. Likely places are the tension unit and near the hand wheel.
Sep 17, 2015 | Singer 6038 Mechanical Sewing Machine
How to free a seized main shaft
Sounds like the clutch: here is a link to the instruction manual:
http://www.aisin.at/assets/manuals/RSSDENG.pdf
It has a fault fining section page 50
Jun 12, 2014 | Toyota STF17 Sewing Machine
Can lint get up inside the shaft that raises and lowers the needle?
the needle bar is not hollow,
Skipped stitches
1. The needle is not inserted correctly
Remove needle & reinsert needle( flat side towards the back of machine)
2. The needle is damaged
replace with new needle
3. The wrong size needle is being used
Choose a needle to suit the thread & fabric
4. The foot not attached correctly
Check & attach correctly
May 01, 2012 | Singer Confidence 7463 Computerized Sewing...
I was trying to sew fleece and the machine started jamming and I cleaned out the bobbin casing and also changed the needle and it still jams.
correct needle insertion is mandatory for the proper use of the sewing machine. Raise the needle bar to the highest position, then loosen the clamp screw to remove the old needle. place the new needle in the clamp with the flat side of the needle facing the back of the machine. or if your using a round needle the groove in the needle should face away from the shaft.push the needle all the way up to thestop or as far as it will go & then tighten the screw
also if the thread comes off the thread take up lever it will cause the machine to jam up-i've had that happen more times than I can count
also clean under the needle plate for lint
Sep 11, 2011 | Kenmore 19233 Computerized Sewing Machine
How do i thread the needle on a Brother IS-2125i sewing machine?
the thread goes in the front thru the eye of the needle & out the back of the needle
The brother website has free operation manuals
On the home page,, on the left hand side down towards
The bottom look for PRODUCT MANUALS
Click on it & it will take you to another page where you can
Pick your model number & download the manual
Jan 21, 2011 | Brother LS-2125 Mechanical Sewing Machine
Singer 8280 will not zig zag
If your machine has been sitting and not being used, try oil and taking a hair dryer to your needle shaft. This may free it up so that you can adjust your width and length. Another thing could be that your needle shaft is bent. I hope that the hair dryer does the trick for you.
Dec 08, 2010 | Singer 8280 Mechanical Sewing Machine
Janome SD-2014 sewing machine dogs fails to operate in reverse
The grease has hardened and that is what makes it not work. You need to remove the spring and clean all the old grease off it. You can put new grease on if you want but it isn't necessary. The machine should be lubricated with a good quality sewing machine oil(not 3 in 1). You need to oil any place that moves and rubs, This includes the ends of each shaft, the needle bar and the cinnecting links that drive the needle bar. Nothing is permanently lubricated.. you'll find this machine will run much smoother and quieter with fresh lubrication.As a matter of fact, if you use the machine a lot, it should be lubricated once a year and never less thanonce every 5 years.
One more thing. If it is on the main shaft that it has hardened you can spray it with a mixture of fantastic, water and some ammonia. Free it up and give it a light shot of oil.
sewman7
May 02, 2009 | Sewing Machines
Consew 206RB Logo
222 people viewed this question
Top Consew Sewing Machines Experts
Michael Galve
Michael Galve
Oloyede Monsuru
Irene Tulloch
Are you a Consew Sewing Machine Expert? Answer questions, earn points and help others
