Hotpoint aquarius wlm520
Hi, belt keeps coming off? plz help
  • 958 Answers
SOURCE: Hotpoint Aquarius WMA 32
please check the outlet hose of the detergent drawer. it could be clogged with soap.
Posted on Feb 13, 2008
  • 10 Answers
SOURCE: hotpoint aquarius drive belt wont go on
hook the belt around the motor spindle first then get the belt as far round the pully as you can once at that stage hold the belt firmly as you can on the pully and turn the pully round making sure that the belt does not slip off keep turning the puully round till the belt is fully on once on spin the drum around by hand to make sure that it is on the pully square with motor spindle. job done. if this helped please leave feed back.
Posted on Feb 24, 2008
IFIXALL
  • 868 Answers
SOURCE: HOTPOINT AQUARIUS WF440 BEARING REMOVAL/REPLACEMENT
Are you talking about the main tub bearing?If so I dont recommend replaceing this bearing,because the problem will only keep repeating itself.
Posted on May 24, 2008
  • 100 Answers
SOURCE: hotpoint aquarius wash system plus ultima 1200 wm72
it's a motor problem. could be as simple as the brushes or could be the circuit board at fault.
Posted on Jan 27, 2009
barkencoa
  • 3463 Answers
SOURCE: fitting new belt
Remove top cover and lower rear panel of washer
With some help, tilt washer forward, and fit belt round motor pulley first,slowly ease belt onto drum pulley and feed slowly round, turning pulley at same time, it will be very tight, so watch your fingers, you can align the belt after it is fitted. Please rate my solution.
Thanks.
Posted on Aug 19, 2009
Hotpoint aquarius wd420 cannot stretch drive belt on there is no slide bar on motor which is fixed solid even after bolts are lossened its a washer drier no obvious way of attaching belt
There is no adjustment provided for tensioning belt as it is a stretch belt.
Best way to do it is to remove the rear panel, tilt the weaher forwards, get someone to hold it for you.
Put belt round motor pulley first, then slowiy feed it round the drum pulley, turning the drum pulley at the same time, it will be very tight, so watch your fingers, just keep going until belt is on, if it comes off, just start over
You can line it up properly in the motor pulley grooves once you have got the belt on.
Thankyou.
Feb 25, 2010 | Hotpoint Ariston Aquarius WD420 Front Load...
Hi could anyone help me please..My Hotpoint WMA52 keeps flooding
It is not draining properly, or overfilling due faulty pressure switch.
Try cleaning the filter first.
Remove lower rear cover of washer.
Remove large black hose onto bottom of drum.
Remove and clean filter inside hose.
Remove hose onto pump, and check for obstruction here and in the pump.
Hope this helps.
Dec 07, 2009 | Hotpoint Aquarius WMA52 Front Load Washer
Hotpoint aquarius tumble dryer, drum not going round but still
If you can hear the motor going, then the belt probably needs replacing, if no motor action, then prob is more serious.
Thanks.
Jul 15, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
The belt in my washing machine just broke
Try this number; 0818 313413
This is Hotpont service in Dublin.
Plz rate my soution.
Thanks.
Jan 14, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint washing machine belt come off
To refit belt, remove top cover and rear lower panel at bottom of washer.
Tilt the m/c towards you.,you may need assistance to hold m/c.
Put the belt round the motor pulley first, and then fit it on drum pulley, slowly turn the pulley feeding the belt round as you go, it will be very tight, so be careful not to trap fingers., just keep going until belt is on, there is no adjustment needed as belt is self tensioning.
The belt needs to sit in the middle of the pulley.
Plz rate my solution.
Thanks.
Jan 10, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint aquarius 1100 bangs while spinning
Several possible reasons for this. M/C not level, causing it to move about.
Overloading of m/c.
Loose concrete balance weight, there is one at top and one at bottom.
Suspension spring broken or unhooked.
Suspension leg loose or broken.
Main drum bearings worn, to check this, turn drum by hand and if it feels noisy or rough , then bearings have gone (expensive repair).
There are other possible causes, but these are the main reasons.
Thanks.
Dec 29, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Thermostat keeps blowing on Hotpoint Aquarius dryer
Remove the filter completely from the bottom left of m/c
Wash out thoroughly under running water.
Reach in with your hand and clear any fluff and gunge you can find there.
At the rear of the filter housing there is a small drainage hole that blocks up.get a plastic bag tie or similar and poke it clear. Also there is a float chamber and some times the float sticks, this being the case , then it involves a complete strip down to clear prob.
Hope this helps
Plz rate solution
.Thanks.
Dec 29, 2008 | Hotpoint TDC32 Electric Dryer
Hotpoint Washing Machine (W540) stopped working, LEDs flash....?
You must get the filter out, as there is a very good chance that this is the prob, keep unscrewing it and try to move it about, then screw it back in again , and then out again, hopefully this will dislodge whatever it is that is holding the filtter in.
Plz rate thiese comments.
Thanks.
Dec 27, 2008 | Hotpoint Aquarius WD63 Front Load...
Hotpoint Aquarius belt slippped
Hi.
It sounds like your washer may have a major problem.
If it was so noisy, it sounds to me as though the main drum bearings have gone, or the motor bearings, that being the case, I woukld recommend that you do not use the washer until it is checked out.
Hope this helps!!!
Nov 14, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint aquarius drive belt wont go on
Feb 23, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Washing Machines Logo
22 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
