Question about Refrigerators
GR-5512gc refridgerator Door cool beam fan noisy
4 Suggested Answers
  • 72 Answers
SOURCE: ice build up in bottom of refridgerator, loud fan noise
check gaskets for air leaks or blocked drain in freezer section
Posted on Jun 07, 2009
heatman101
  • 43501 Answers
SOURCE: LG Refrigerator Model GR-721R
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Posted on Jul 12, 2011
imufo2
  • 3773 Answers
SOURCE: fan not working infreezer when
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
First I would check cold control. Thats where you turn it off, if your temp is not warm. it can
be defective and not shutting off. If your temp is warm proceed with the following.
I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if FREEZER CONTROL is turned WARMER WHICH MAKES THE REF COLDER AND VICE-VERSA. SEE?
The ref. temp should be about 33-35
The Freezer temp should be 0 to 10 Any thing below these temps is overkill and a waste of elect
The higher the number you turn it up to is the coldest
Also this might be a common Defrost problem, Ice
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
Make sure back cover is on the fridge. Some take them off and throw them away.
make one out of cardboard if its gone, using the holes of the old one.
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
NOTE: This
Check Temp inside freezer. It has to be down to about 10 or 15 degrees
This can cause slow ice making if its too high even tho its freezing everything else at 25 degrees
The icemaker is 110v
See if water is in icemaker.
Pour water in Ice Maker and wait to see if it ejects.
If it ejects thenyou need to replace water valve in rear bottom of fridge(Its the part that
attaches to water line out of wall)
If it doesn't eject then it is a faulty Ice Maker.
If its leaking or no water at icemaker or door either one, then the valve at the rear bottom of ref needs replacing
First I would check the fan in the freezer. Listen to see if it is running
Then check to see if freezer control is turned WARMER, which makes the Ref. colder
Also if it is getting drinking water to the door but not to the icemaker (or vice versa) Then you need to replace
the water valve at the bottom rear of the fridge. It is a double valve and one side is not working
If you still have trouble GO HERE:
http://www.applianceaid.com/procedures.html
Thanks
for using fixya
Leo Ponder
imufo2
PLEASE GIVE A TESTIMONIAL AND VOTE FOUR THUMBS UP IF THIS WAS HELPFUL
MORE TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
ITWILL BE MUCH APPRECIATED.
NOTE: This
For
extra help go here:
Thanks
for using fixya
Leo Ponder
imufo2
Posted on Aug 18, 2011
When we shut the fridge door a loud continuous humming noise comes from the fridge. This seems to be activated by the door light switch at the top. Thank you
There are 2 possibilities I can think of for the hum. When you activate that door switch it activates 2 fans and the compressor. There is one fan located on the compressor and one located in the vent system in the fridge. The second fan is used to circulate cool air evenly through the fridge. I would recommend holding your finger on the door switch and listen carefully whether the noise is coming from inside the back of the fridge or from the lower bottom. Lower bottom could indicate compressor cooling fan or compressor. They would need to be inspected. If it sounds more like the other fan mentioned above it would again need to be inspected. The compressor cooling fans can get stuck or become noisy due to bearing failure. The vent fan can get stuck or noisy but also in some cases if the defrost circuit is not working can chock up with ice and create a buzzing noise as the fan blades strike the ice.
Jan 13, 2017 | Refrigerators
The beam in middle of refridgerator where both doors rest against while closed is too hot to touch
Is the cooling fan for the compressor working? There is a coil of the condenser line that runs around the freezer side. This will get hot but the cold freezer side keeps it form not getting too hot. It could get very warm if the freezer is not cold yet.
Sep 10, 2014 | Kenmore Refrigerators
Hi my name is Anne Have just bought second hand fridge about a month ago the model is a LG GR-5512GC. Ihave just noticed its leeking,wateris sitting under crisper bottom of fridge is their a way it can be...
clean out the drain hole with neat clorine bleach,then check door seals fit flush to frame,make sure you cover all food with clingfilm to cut down on condensation..
Aug 25, 2010 | LG Refrigerators
Refridgerator and Freezer Not Cooling (2 year old fridge)
Some of these had problems with the door light switches between the doors. They also control the fans. The top and bottom both have fans in back. Try opening top door and holding door light switch in. Wait for a couple minutes to see if fan comes on. Try with freezer too. If not coming on may need switch.
Jun 02, 2010 | Samsung RB215LASH
Kenmore refrigerator with bottom freezer. freezer works,refrig does not. Can you help me find the problem .Also, bar between the upper doors gets real hot.
I had this problem. The Evaporator fan in the freezer was working but no air would be circulated from the freezer into the refridgerator. To test this you open the door of the freezer, and depress the door button(s) of the upper refridgerator doors so that the light extinqueshes in the refridgerator. This will engage the evaporator fan in the freezer. You can check to see if air is venting from the freezer into the refridgerator by feeling the holes at the top most part of the multi-air flow channel in the refridgerator. If air is comming out when the freezer door is open, close the freezer door and feel if air has stopped. If you have kept the upper door buttons pushed in on the refridgerator and now have the freezer door closed, you should still hear the fan running, but may have not air flow with the freezer door closed. The cause of this is the air return channel from the refridgerator to the freezer is either frozen or clogged. My return-air channel was not frozen but clogged by a residue from something that spilled inside of the bottom of the refridgerator. The return-air channel has two vents in the rear-bottom of the refridgerator that exit into the freezer behind the evaporator (cooling coils). You can't see it even if the back interior panel is removed from the freezer compartment.
The bottom line here is that if air is prevented from moving from the refridgerator, back down to the freezer, then your refridgerator will not cool, but your freezer will work just fine. You will not need to replace the fan, unless the fan is not functioning. You may need to check the dampener, to ensure that your multi-air flow channel is open - (allowing air to come into the refridgerator). The multi-air flow channel is easy to remove once all of the shelves are removed from your refridgerator. Only 2 screws holding it in (securing the center rack top and bottom). The top screw is located behind a small plastic cover that can be removed.
That's what worked for me.
Jan 12, 2010 | Kenmore 24.8 cu. ft. TRIO Bottom Freezer...
Noisy motor on fridge side which whirred to a stop
Hi, It sounds to me like the evaporator fan motor is faulty. They will quit working after they make a noise like that, bearings and windings.You have a door switch that stops the fan when you open the door, that opens the contacts on the motor. It should have come back on when closing door. Now you say it has quit cooling,so if this motor has not come back on and is not running quietly, it will need to be removed and replaced.It may be difficult for you if you are going to do this yourself, but if your up to it, you can save yourself some $.You can buy a new one at an appliance parts house, or get all of the info from you're unit and go online to order one.They have universal motors to fit also.It would be a 120volt sealed motor with a plastic or aluminum blade.Try and remove it yourself if you are able, if not you will need to call out the tech which can get costly. Best of Luck to you and please keep me posted.Have a good night, Sincerely,
Shastalaker7
Dec 06, 2009 | Washing Machines
Door ajar alarm ringing and refridgerator not cooling enough
it sounds like either a defrost problem or damper door problem it is very well worth fixxing
Dec 28, 2008 | Samsung RS2630SH Side by Side Refrigerator
Maytag refridgerator model MSD2651HEW refridge not cooling properly
my water dispencer has a low flow after an initial regular flow. why?
Jun 20, 2008 | Maytag MSD2651 HE Side by Side...
My LG LRBN20514ST Fridge is not cooling
where to look for the defrost timer on the LG top freezer modle
GR-S392GCA
Aug 26, 2007 | LG LRBN20510WW Bottom Freezer Refrigerator
Refrigerators Logo
16 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
