Question about Home Security
Safeguard sd101t The combination lock is very stiff and hard to turn. This has happened over time, it used to turn freely. Any ideas?
I have a 2002 mitsubishi Lancer manual oz rally edition and I'm having trouble switching gears, like it's hard. Any idea what this might be?
If the shifter moves freely when engine is off. Its possible that the clutch is not fully dis-engaging causing stiff gear changes. May be time for a clutch
Apr 04, 2015 | 2002 Mitsubishi Lancer
Gear problem on ar5516
Remove the tank & pure down all the developer, use brush or a vacuum blower to remove the residual developer on the two sides joints
where the roller rolls on the tank then turn it freely with your hand.sure. sieve your developer before you pure it back . thanks
Aug 11, 2014 | Sharp AR-5320 Black and White Copier
Is my crankshaft suppose to be stiff or turn freely
It can turn but it should be pretty hard. The only time it should be easy is with the belt and the spark plugs out. If it is real easy with nothing removed then it may have low compression.
Jul 14, 2014 | Cars & Trucks
I just bought a rebel been sittin for a few years i cleaned rust out of tank. when i open the valve gas should flow freely or does it get sucked in be carb? number two is my throttle action is extremely...
Gas flows by gravity to the carbs so it should flow freely to it at all times.
Remove the cable from the carbs to see if the cable is stiff. If so replace it. If not service the carbs and linkage. Sitting all that time will make it stick
Jul 13, 2011 | 1999 Honda CMX 250 Rebel
Trying to get my challenge mini fan to work. Will oscillate but fan not blowing. not used for couple of years cant remember if i have to use a combination of buttons to get it working properly. cant find...
un-plug it first and then try to turn the fan blades with your finger if there stiff to turn its seised up and a good swilling with wd40 may fix that the fan must spin freely,,,
Jun 26, 2010 | Dryers
1992 toyota corolla, stiff brakes after driving several miles in
remove the master cylinder and check the plunger projection make shore it is with in specs, using a vacuum pump check condition of capsule see if it holds the preasure and its not leaking off. if its leaking change capsule and check valve
Sep 24, 2009 | Toyota Corolla Cars & Trucks
Eo1 comes on says take out battery and put back in should work but donot need to use camera now.
JVC camcorders are known for having safeguard problems.
mine was locked into safeguard the second time i tried to use it at 1 month old. i had it repaired and it came back eating the tapes. eating the tapes was blamed on old, or improper tapes. they were all brand new never used JVC tapes.
it came back from service locked in safeguard mode.
i got it back the fourth time and it worked for a few days, then went back into safeguard mode.
the shop had it more than i did during the first year.
when it locked the next time after the warranty was out, i was told the estimate for repairs was $300.00.
unless you want to try to risk taking it apart, the only 2 options you have is to send it in for repairs which is not cheap, or throw it away and never buy anything from JVC again.
i chose option 2.
Aug 27, 2009 | JVC Everio GZ-MG130 Camcorder
Harldline safe not opening
Sure blame the poor kid.
Think about it, what good would a safe be if by pressing a few keys the combination was changed?
As with any combination safe you need to clear the combination by turning one, two or three times in the opposite direction before entering the combination.
Now say your sorry to your kid.
Jul 24, 2009 | Safe International Digital Electronic Safe...
SD102 missing the key
Hi.
Yes, you need the key to open it.
Your code is 4 numbers (one or two digits each).
First turn the knob several times counter clockwise To "reset for starting)
Turn the knob clockwise. Stop when you hit the first number the fourth time. Then counterclockwise, and stop when hitting the second number the third time. Counterclockwise again until you hit the third number the second time. Counterclockwise, and stop when hitting the fourth number the first time.
Now you need the key. The safe opens when you turn the key clockwise. I don't know where to order a new key, but I suppose the manufacturer can help. Your key number should be engraved ON the lock. Mine has four digits lock/ key- number.
I have not been able to find the manufacturers web page...
I wish you luck!
Stein/ Norway
Jul 08, 2009 | Safe International Digital Electronic Safe...
Door locked
Hi sometimes they become stiff dont worry about breaking it they are pretty sturdy just try giving it a hard pull their should be no reason why its locked as their isnt an electronic lock keeping it closed maybe their is a air vacume and its just stuck with air so try giving it hard pull let me know what happens.
Maybe the seal has become stuck to the door but it still should open ok
Jan 22, 2008 | GE Profile JGS968 Gas Kitchen Range
Home Security Logo
20 people viewed this question
Top Home Security Experts
Lawrence Oravetz
Are you a Home Security Expert? Answer questions, earn points and help others
