Question about Dewalt DXPW3835 - 3800 PSI Professional Gas-Cold Water Pressure
Delayed pressure when trigger pulled
This is the second PW in 2weeks same pw when the trigger is pulled the pressure takes 30 to 45 seconds to come out I know I'm getting more than enough water at the intake over 5gpms the other dewalt 3800 did the same thing can someone tell me whats wrong and how to solve this if not I'll take back to DH and try another brand Thanks Joe.
  • 1388 Answers
SOURCE: I have a dewalt 3750
I worked at a tool rental center while attending college and learned many tips and tricks about Dewalt and other brand pressure sprayers. Your machine probably has a 13 hp honda and has max pressure of about 3500 to 3700 psi. Most of the problems that customers had were engine related due to severe working conditions including totally wet engine /plug, wet air filter, and or other problems that were easy to remedy. We would set the pressure regulator to minimum pressure and explained to the customer how to increase the pressure as necessary but only after the engine was completely warmed-up to running temp to prevent engine stall. Your machine has a throttle lever between the tank and carb that should be set to max if you are going to set pressure at or neer max range. Most cleaning jobs do not need much pressure. Use lowest pressure to get the job done. Your engine developes around 13hp at about 3600rpm. If you want to maximize the life of you sprayer, then use your machine at about 70% of capacity or about 2000 to 2500 range that will allow you to run your engine slower increasing lifespan. Your sprayer is likely rated at 4 gallons per minute so make sure that the tip is that capacity. The tip has the size stamped which would show the fan degree and flow in gpm. The wrong tip, say a 3.5 gpm will strain the engine to point of stop because the smaller tip increases pressure. Most engine stall is due to high pressure setting on new machines. Lower pressure when warming-up machine and use max pressure rarely when necessary to max life. Please email for other information/questions or simple tests to determine faulty parts, good luck.
Posted on Jan 30, 2009
harlan301
  • 205 Answers
SOURCE: I have purchased a Dewalt 3800 PSi cold water
check to see how hot the water can be, ti should be on the unit or in your book. also your amps should be no less than 15amp, long core can over heat the motor. if your unit can't handle hot water it will melt the valves
Posted on Oct 12, 2009
  • 243 Answers
SOURCE: low pressure
hi some valves at cat pumps need a 100 psi pressure to open and close correct. when there is air in the pump the valves wil not open and close till air is bleeded. take of highpressure hose, open watertap and bleed pump till no more air comes out. reconnect all hoses and try again. if there is no more air in the pump and its still not working, i should think its the pump.
Posted on Feb 16, 2010
puertobori
  • 7733 Answers
SOURCE: Dewalt 3800 PSI operates great
When you pull to start squeeze the water hose tigger until start.
Posted on Oct 03, 2010
  • 57 Answers
SOURCE: what type of oil do i use in a dewalt 3800
in the enginge you can use a standard 4 stoke engine oil.
in the pump you can use hydraulic oil
Posted on Dec 20, 2010
No pressure!!
You have an air lock. Here's how to fix it:
1. Connect the hoses, and turn the water on. Work the supply hose in such a manner as to displace any air in high points in the hose through the pump. Let the water run for several minutes, then connect the gum. Turn the water back on and let the PW come up to 'house' pressure, and pull the trigger to depressure the system rapidly. This displaces any trapped air. Do this several times, until you get no traces of air at the gun. Crank the PW; it should come up on full discharge pressure. If it does not, shut the engine off, and repeat the displacement maneuver. This time, start the engine while holding the trigger of the gun down. This will act as an unloader, and should give you full pressure.
Best regards, --W/D--
Aug 08, 2009 | Honda Garden
How to unlock Nokia 6300 phone
Try code number 7 first. If it does'nt work, try code 1. Different codes work on different phones. Remember that you only have 5 tries.
To enter the code:
1. Push #
2. Push * 3 times in one second. (p will show)
3. Push * 4 times in one second.(w will show)
4. Push * 2 times in one second(+ will show)
5. Enter the code from below.
6. Push * 2 times in one second.(+ will show)
7. Enter the code number
8.Push #
Now a message like "Sim restriction off" should be displayed. That means your phone is now unlocked.
Your code's are:
#pw+228875557620475+1#
#pw+436867161410263+2#
#pw+494327720215623+3#
#pw+315916340311414+4#
#pw+183024315162023+5#
#pw+947802170570602+6#
#pw+493267323124160+7# <<
Feb 12, 2009 | Nokia 6300 Cellular Phone
Thanks, my imei number 355547011058691. The phone is a Nokia 6288 made in Germany, currently locked to O2 network.(United Kingdom)
IMEI: 355547011058691
You should use code number 7. If it does not work, try code 1. Different codes work on different phones. Remember that you only have 5 tries. After that you have to leave it to an unlock shop.
To enter the code:
1. Push #
8.Push #
Your code's are:
#pw+043163773133660+1#
#pw+314136445273437+2#
#pw+428347756625340+3#
#pw+986262613464563+4#
#pw+937402062526307+5#
#pw+772210000054510+6#
#pw+718040540672647+7#
If it doesn't work the phone will have to be connected phisically to a device (unlock box) and to a computer.
Aug 25, 2008 | Nokia 6288 Cellular Phone
Plz help me to unlock my mobile
To enter the code:
1. Push #
8.Push #
Your code's are:
Aug 14, 2008 | Nokia 6300 Cellular Phone
Nokia N95 8GB locked on 3G (UK)
These are the correct codes, but there's no guarantee that they will work. Some newer phones have to be connected to a PC to unblock them.
To enter the code:
1. Push #
8.Push #
Your code's are:
#pw+174004504262100+1#
#pw+913002445162104+2#
#pw+004853234210451+3#
#pw+735210065354410+4#
#pw+744160273203361+5#
#pw+794960222221767+6#
#pw+085803410330405+7#
May 19, 2008 | Cell Phones
N70 unlock
for N70 unlock codes can't be calculated by IMEI. You must go to a repair shop for make unlock of that phone.
May 18, 2008 | Nokia N70 Cellular Phone
Nokia 6233
You should use code number 7. If it does not work, try code 1. Different codes work on different phones. Remember that you only have 5 tries, after that you have to go to a repair shop.
To enter the code:
1. Push #
8.Push #
Your code's are:
#pw+434257063264651+1#
#pw+449037370732335+2#
#pw+892411220036617+3#
#pw+025903455301702+4#
#pw+846551371427355+5#
#pw+129954654711654+6#
#pw+336916660471213+7#
Now a message like "Sim restriction off" should be displayed. That means your phone is now unlocked. Check this after each code you try.
Feb 17, 2008 | Nokia 6233 Cellular Phone
To enter the code:
1. Push #
8.Push #
Start with number 7, then 1, 2,3...
you only get 5 tries
Your code's are:
#pw+292045124002041+1#
#pw+478347103655247+2#
#pw+317566145517666+3#
#pw+193004123122202+4#
#pw+446167073433567+5#
#pw+777160502533260+6#
#pw+245955770321157+7#
Jan 27, 2008 | Nokia 3230 Cellular Phone
Help unlocking nokia 6300
To enter the code:
1. Push #
8.Push #
Your code's are:
#pw+493267323124160+7# <<<try this one first
These are the closest codes recommended.
Jan 13, 2008 | Nokia 6300 Cellular Phone
Nokia N73
hi, can you help me to reset the lock code of my N73 cell phone, i forget the lock code
here is my imei # 358973013593229
Jan 05, 2008 | Nokia 1600 Cellular Phone
Dewalt DXPW3835 - 3800 PSI Professional Gas-Cold Water Pressure Logo
Top Dewalt Garden Experts
John Trevino
JOHN LAPIER
Are you a Dewalt Garden Expert? Answer questions, earn points and help others
